Question about Intel Computers & Internet
1. How to indent a motherboard?
Intel
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Intel Master
  • 2,226 Answers
On the board by the pci slots or the cpu socket
Posted on Apr 03, 2014
All mother boards have its number printed on it. With that number, you can Google to know its details, and specifications.
Gopakumar Gopalan Google
Jul 04, 2014 | ASUS P8P67 PRO - ATX - INTEL P67 - SOCKET...
The way you are using the term 'Indent' is confusing.
Clarify your statement.
Post back in a Comment.
Regards,
joecoolvette
Apr 22, 2013 | Intel Computers & Internet
Look for a group of numbers on the motherboard. They vary from manufacturer to manufacturer. But if you have an intel motherboard you probably have a manufacturer built system. Just type the model number of the Tower into your search engine and add motherboard after it.
I have Intel E210882 motherboard.Which is the chipset?
http://www.amazon.com/Intel-Desktop-Board-D845PEBT2-E210882/dp/B009B5L0OA/ref=sr_1_3?ie=UTF8&qid=1353781789&sr=8-3&keywords=intel+e210882
http://www.intel.com/support/motherboards/desktop/d845pebt2/sb/cs-012740.htm
Click on Product Specification (PDF)
Product Guide (PDF)
http://downloadmirror.intel.com/15337/eng/D845PEBT2_ProductGuide_English01.pdf
The motherboard chipset is an Intel 845PE.
Intel part number - Intel 82845PE - on Northbridge chip;
Intel part number - Intel 82801DB on the Southbridge chip,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_4_chipsets
The Northbridge chip is under the tall aluminum finned Heatsink, that sits between the processor socket, and the bottom of the motherboard.
The Southbridge chip, Intel 82801DB, sits down towards the bottom of the motherboard.
For additional questions please deposit $30,000 in unmarked bills......................OH, I'M JUST KIDDING!
Post in a Comment.
Regards,
joecoolvette
Nov 24, 2012 | Intel Motherboard
What cpu can the motherboard 661M03-G support?
Vendor Type FSB Frequence
Intel Pentium Northwood 400MHz 2.0, 2.5GHz
Intel Pentium Northwood 533MHz 2.4-3.06GHz
Intel Pentium Northwood 800MHz 2.4-3.0GHz
Intel Pentium Prescott 800MHz 2.8GHz
Intel Celeron Northwood 400MHz 2.0-2.4GHz
Intel Willamette 400MHz 1.8GHz
Intel
Jan 30, 2010 | Foxconn 661M03-G-6EL Motherboard
Got 3 long beeps, have changed good memory, same problem. Took out battery short the battery terminals for 30 seconds and re-install battery, still got the same problem, any ideas?
Look at the capacitors on the motherboard. They all should be indented inward. If any of them are bowled upwards, then you have a faulty motherboard, and the reason that your RAM isn't working on it.
or
Take out all the RAM and only try to boot with one RAM chip installed at a time.
Maybe the RAM is incompatible with the motherboard?
Dec 15, 2009 | Intel D945GNT Motherboard
HOW TO INSATAL PROCESSER IN OMTHERBORAD
Hopefully you got the Intel 775 pin processor line but the installation should be pretty straight forward.
Looking at the motherboard where the CPU would go, there is a metal lever type of locking mechanism that extends the length of the processor space. You'll want to first move it to the side, then rotate it up toward you.
This will loosen up the brace that would apply pressure to the CPU, locking it down into place. Open this door/brace up and (if a new motherboard, remove the black plastic protector inside the door) and you'll notice the pins are located on the motherboard themselves. [ Older motherboard/processors had the pins on the CPU ] If you look along the plastic edge of the where the processor would sit in the motherboard, there are little tabs protruding out toward the pins.
Now in looking at your processor, you'll notice that there are also two indentations on the edge of your processor. You'll match these indentations and tabs up so that the processor will sit nice and cozy inside (remember, you want the gold dotted side DOWN).
There will a little play in the processor itself once you set it down which is normal.
Close the door/brace and bring the locking lever down. It may require a good firm force to pivot the lever down but once you get it down far enough, move it over slightly to the side (opposite of how you removed it) and then lock it into place. (you'll notice that there are small plastic brackets that hold this lever down in place to lock it.)
Now that the CPU is locked down, its time to put some thermal paste down on it. (most CPU coolers already have the jelly on the bottoms... a grey jelly material)
Depending on how big of a cooler you have for the CPU, for the larger ones, I always do an eyeball test fit... just to make sure that I have it rotated and fitted correctly before setting it down and locking in the screws.
Don't forget to plug up the CPU cooler/fan to the motherboard CPU_FAN plug.
Apr 18, 2009 | ECS 945GZT-M (V1.0) Motherboard
I need intel d865 motherboard drivers
download realtek AC'97 Audio driver from here
http://www.realtek.com.tw/downloads/downloadsCheck.aspx?Langid=1&PNid=14&PFid=23&Level=4&Conn=3&DownTypeID=3&GetDown=false
Nov 08, 2008 | Intel D845GVSR Motherboard
Rebooting
Hi, Even with just 128mb of memory, you should be able to complete the XP install albeit a bit slow. If system reboots in the middle of an install, there can possibly be 4 problems: 0. Video card - if an add-on PCI-E/AGP video card is present, it may be defective or overheating; 1. Memory - you may need to try a different memory (not necessarily bigger but of course that would be better); 2. Hard Disk - heating up after some time and becomes unrecognized by the motherboard; and/or 3. Motherboard - overheating component, CPU chipsets (if new, claim warranty replacement). Could also be a fan problem or CMOS/BIOS setting for CPU fan temp control. Most common I've run across with are blistered, swollen, burst capacitors. These are the cylindrical components that comes in varying diameters and heights. Very near the CPU itself would be a couple of these components. Normally the top should be shiny, very flat with an X or Y indentation. Those swollen, burst or show signs of brownish stain are defective and can no longer hold a charge and do its function/purpose. Unfortunately, the normal course of action is to replace the motherboard. The capacitors themselves can be replaced but that would require a very very patient and careful tech who is very familiar with soldering, desoldering pump and knowledge of PCB layouts. Hope this be of some idea/help. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 18, 2007 | Intel Motherboard
Computers & Internet Logo
37 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
