I have a Panasonic RF-D1 portable DAB radio which comes up with the error code F26 DAB DDOWFIC can anyone help me?
3 Suggested Answers
VOTIT
  • 2071 Answers
SOURCE: since a storm the dab
It is a loose connection or cold solder and cleaning problem this is the main caused of no sound..Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the receiver turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have surmised, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing....
Good luck:
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Aug 10, 2008
SOURCE: Panasonic DAB RF-D1 Radio..
The internal 5v battery is flat
Posted on Sep 04, 2008
What does f26 mean for siemens washing machine
F26 come up This error code indicates that the door needs to be opened and closed.The F26 code may appear the first time you try to use the washer. Open and ...
Jan 03, 2016 | Siemens Washing Machines
F26 code
Unplug it and wait a while, the door may finally release the lock. Then google the problem to see what F26 is.
Nov 25, 2013 | Hotpoint Ultima WD72 Front Load...
My maytag commercial washer display a code F26
The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and the condition above has been checked, call for service.
Oct 23, 2012 | Washing Machines
Error code F26
If opening and closing the door does not remove the error display, press Pause/Cancel twice
Oct 22, 2011 | Whirlpool WFW9200S Front Load Washer
Washer says f26 and won`t spin the clothes out. is there anything i can do?
If opening and closing the door does not remove the error display, press Pause/Cancel twice.
The above procedure is the specified way by whirlpool technicians to clear the error code.
Feb 02, 2011 | Washing Machines
F26 Error - Door Switch?
when you hear clicked can you open the door?its should be locked...
Oct 12, 2008 | Kenmore Elite 45986 Front Load Washer
Aug 31, 2008 | Audio Players & Recorders
Since a storm the dab function on my SC-EN29 COMES UP DAB AUTO SCAN F26 DAB DDOWFIC i cannot get any stations
Good luck:
Regards,
VOTIT
Aug 10, 2008 | Panasonic Audio Players & Recorders
Panasonic RF-D1 code f76 pdet
Seems to be a problem with a Transistor BD244c PNP. Old problem of 3years plus wich means are the goods fit for purpose as defined by The Sale of Goods Act/ If not even if they are out of warranty you should get a replacement or your money back
Apr 12, 2008 | Audio Players & Recorders
Error Code F26
Here is the link to the user manual if you need it; http://service.us.panasonic.com/OPERMANPDF/RXED707.PDF although of course it doesn't list that error code and panasonic no longer support the model on their site except for the user manual. If you don't mind paying $19.50, then these guys have the service manual available which almost certainly will list the error codes and their solutions; https://www.manualsparadise.com/ShowProductsForModel.do?model=M91217722 Sorry I had no luck finding that one for free. My guess is that the lens needs cleaning, and that the error code simply means "bad disc" or something similar. Best way to clean the lens is with a cotton bud/ Q-Tip moistened (not wet) with gin - nothing else works as well or as safely. This should be easy to do as you have direct access to the lens, just be gentle. If you get no luck from that then the best i can suggest is to contact panasonic direct; http://www.panasonic.com/support/ and see if they can tell you what the code means, if they do, and you need help solving the problem, please ask again. Good luck, I hope this helps
Jun 23, 2007 | Panasonic RX-ED707 Boombox
11 people viewed this question
k24674
jasbo
jasbo
