Question about Car Audio & Video
Wiring diagram rectifier in raider 150 - Car Audio & Video
2 Suggested Answers
  • 132 Answers
SOURCE: wiring diagram for a ford raider
According to FCC law all aftermarket sterio equipment has to have the same code, they may be diffrent
as for the ford
Black Wire - Ground Black With White Stripe Wire - Right Rear Speaker Light Blue With Red Stripe Wire - From Light Switch To Radio (light) (Headlights) Light Green With Yellow Stripe Wire - Hot At All Times To Radio Orange With Black Stripe Wire - From Light Switch To Radio (Light) (Parking) Orange With Red Stripe Wire - Right Rear Speaker Red Wire - To Ground With Black Wire Yellow With Black Stripe Wire - Hot In Accessory Or Run To Radio
Posted on Jan 03, 2008
Wiring diagram raider j
Hi, Benjardie for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Suzuki, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Wiring diagram raider Google Search
Motorcycle Electrical Wiring Diagram Thread
Techy at day Blogger at noon and Hobbyist at night
Suzuki Raider 150R parts pdf
Suzuki Raider 150 FU150SC Owner Manual
Jul 10, 2016 | Suzuki Motorcycles
Need a wiring diagram on suzuki raiderj 110. Please. Tnx.
Maybe you can use these codes taken from:
http://www.motorcyclephilippines.com/forums/showthread.php?120554-Motorcycle-Electrical-Wiring-Diagram-Thread
This is a Wiring Harness Guide for Suzuki Smash, Raider J, ShogunR/Pro Motorcycles. It may also be applicable to Hayate, Step, Mola and Raider 150.
CDI
ORANGE - from Ignition +ACC
BLACK/swhite - Ground
WHITE/sblue - to Ignition Coil
BLUE/syellow - to ENGINE Stator side
ENGINE - Stator Single Phase
WHITE/sred - To RECTIFIER
YELLOW/swhite - To RECTIFIER
BLUE/syellow - from CDI sensor
ENGINE - Transmission Gearbox
GREEN/sblue - 1st Gear
YELLOW/sblue - 2nd Gear
WHITE/syellow - 3rd Gear
RED/swhite - 4th Gear
BLUE - Neutral
ENGINE - Rear Side
PINK - Odometer Speed Sensor
ORANGE/sred -
ELECTRIC Start RELAY
YELLOW/sgreen - form Starter Switch
BREAK - Foot pedal
ORANGE - From ignition + ACC
WHITE/sblack - to Break light
BREAK - Hand Lever
ORANGE - from IGNITION + ACC
WHITE/sblack - To BREAK Light
FUEL Sensor
Yellow/sblack - to Console
REAR - Lights
WHITE/sblack - form BREAK foot/hand
GRAY - From Night Switch
BLACK - from Left Turnsignal
LIMEGREEN - from Right TurnSignal
Signal Flasher Relay
ORANGE - from Ignition + ACC
LIGHTBLUE - Signal SW
RECTIFIER
WHITE/sred - From STATOR
YELLOW/swhite - From STATOR
RED/sorange - BATT+/HEAD LIGHT
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
GREEN - from HORN Switch
ORANGE - Ignition + ACC
NIGHT Switch
RED/sorange - From Rectifier
GRAY - To REAR LIGHT/HEADLIGHTThis is a Wiring Harness Guide for Suzuki Smash, Raider J, ShogunR/Pro Motorcycles. It may also be applicable to Hayate, Step, Mola and Raider 150.
CDI
BLUE - Neutral
ENGINE - Rear Side
ORANGE/sred -
BREAK - Foot pedal
BREAK - Hand Lever
FUEL Sensor
REAR - Lights
RECTIFIER
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
NIGHT Switch
CDI
BLUE - Neutral
ENGINE - Rear Side
ORANGE/sred -
BREAK - Foot pedal
BREAK - Hand Lever
FUEL Sensor
REAR - Lights
RECTIFIER
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
NIGHT Switch
Dec 27, 2015 | 2006 Suzuki Stratosphere
Noise inside engine side of my suzuki raider 150 r when i put pressure on clutch
It may need adjustment
PDF]Suzuki Raider R150 owners manual (eng).pdf - Moto TH
mototh.com/.../suzuki/Raider-150R/Suzuki-Raider-R150-Owners-Manual...Your Suzuki dealer has experienced technicians that are trained to provide your ... The frame and engine serial numbers are used ..... PART ADJUSTMENT AND.
Apr 28, 2015 | Suzuki Motorcycles
Hard starting engine of suzuki raider 150
nag spin ang motor engine ko pero ayaw mg start, maitim ang spark plug then amoy gas yung lumalabas sa muffler
Sep 24, 2012 | 2010 Suzuki Sixteen 150
Suzuki raider 150 after market carburetor bad idling
you can turn the idle speed up with the brassy looking screw on the side of the carb. It attaches to the part the throttle cable turns.
Aug 16, 2012 | Cars & Trucks
Yamaha raider wiring diagram
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Yamaha raider wiring diagram Google Search
Yamaha Motorcycle Wiring Diagrams
Yamaha XV19SW Service Manual
OEM parts for Yamaha
YAMAHA XV1900A Owner Manual
Feb 16, 2012 | 2011 Yamaha Raider S
Aprilia 150 leonardo, flat battery and not charging, only 11.5 volt when running. Is it the rectifier and where is it fitted to bike? Thanks
Hi, J33pkk and the usual suspects are:
1. Voltage regulator/rectifier not grounded.
2. Engine ground wire loose or broken.
3. Faulty voltage regulator/rectifier module.
4. Loose or broken wires in charging circuit.
5. Faulty stator and/or rotor.
For more information about your issue, please visit the websites below. Good luck and have a nice day.
DOWNLOAD Aprilia Leonardo 150
Jul 07, 2011 | Aprilia Leonardo 125 Motorcycles
Wiring diagram for a ford raider
as for the ford
Nov 30, 2007 | Clarion DRX5575
Car Audio & Video Logo
22 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
