Question about JVC LCA10288-07D Refurbished Panel IF Assembly Digital Video Board for use with VM-42WV74 Plasma Display LCA1028807D LCA10288 07D LCA-1028807D LCA 10288-07D LCA1028807D-R
How to make tv jvc vm42v31 without receiver
I have'nt receiver for vm42v31 and i want to do thes like a terminal with pc
Have jvc rx-2020v receiver with mono rca out for sub and trying to hook it up with polk audio rm 1000 w sub woofer with +/- terminals for both left ane right channels plus blue terminal(?). How to?
Your Polk Audio subwoofer is a passive sub and your JVC mono output is for connection to a powered sub. If the JVC does not have an amplified output for a passive sub, you'll either need to get an amplified sub, a different receiver, or buy a dedicated mono subwoofer amplifier.
Oct 14, 2016 | JVC Audio Players & Recorders
JVC LT47 that picture goes black (sound fine) after being on for awhile. Can turn TV off, then back on & it's fine. But then happens again about ever hour or so.
Hello
Hello
It is due to some loose soldering points [dry soldering we say it technically], in the power supply section of the TV. Just check for it. Check the solderings of all components, that will heat up to an extent when the TV works on. Repeated heating and cooling may make solderings to the terminals of that components to get loose. Just resolder all the suspected solder terminals, by applying a little more solder, without making any solder bridge short in between adjecent solder terminals. This must solve the problem to your tV. OK.
Feb 11, 2012 | JVC Televison & Video
JVC AV-27820 turn on the a white line accross middle
Hello
Total failure of vertical sweep occured whic your JVC TV. There are mainly two resons for this fault.Loose soldering terminals of the vertical output IC is the first one. The second one is of failure of the vertical output IC itself. You have to locate this vertical IC. It can be located at the main board. Vertical IC will be screwed on to a metal heatsink to radiate heat from it while it works. You can identify it very easly, if you have knoledge in electronic circuts abd printed circuit boards.
Resolder all the solder terminals of this IC first, by applying a little more solder; without making any solder bridge short in between the close adjecent solder terminals, and see whether it helps you. If not replace it with same type and number. OK.
Oct 08, 2011 | JVC AV-20220 TV
I have jvc tv which has served me well for the past 11 years but off late it has been displaying some lines on the screen and losing colour when its on both tv and video mode,but when i touch the aerial...
Your TV have problem with cold-solder joints.Input terminals (inside TV ) need to be resolderd.After 11 years from internal heat of the TV solder becomes weak (dry out) and loses conntact from main board where components are soldered
Aug 22, 2011 | JVC Televison & Video
How to get sound to tv from JVC TH-M606 without sub woofer.Also trying to put in progressive mode without remote
  • If I understand your question correctly you want to listen your TV on your Stereo system thru your receiver,JVC TH-M606 ** you need to connect "Audio Output " RCA jacks or "Optic cable output" of your TV
** to "AUX input " or "TV" OR "Any input" of your receiver ( except Phone ) or "Optic Cable input"
** than just switch to respective mode on
JVC TH-M606 RECEIVER corresponding your RCA or Optic connection...
There you go..Your TV sound is on the
JVC TH-M606 Receiver..By this means whatever you watch on the TV (tuner, satellite , Xbox ) ,it's sound will come thru your stereo..
  • If you want to listen your receiver thru your TV, sorry but it is not a preferable attempt since TV sound system is not a HI-FI quality compare to your nice Receiver..if you really want to do it,try to do the connections given above in reverse..
  • And,best of my knowledge I am afraid you can not put in progressive mode without remote
  • Hope this helps!
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Jun 24, 2011 | JVC TH-M606 System
I am using an optical audio out from my tv to my JVCrx-7010v. I am using the TV in jack, cannot get any audio out let alone 5.1
Where does the digital audio REALLY originate - the TV or something higher up the food chain like a Cable Box?
Try getting it from the source to make sure it works. Then, if you REALLY think the TV needs digital 5.1 and an intervening run of cable before it passes audio to the JVC, connect it as the book says.
The TV can probably survive just fine with a simple RCA stereo audio patch from the cable box just in case you want to watch CNN without the JVC turned on.
Feb 05, 2011 | JVC RX-7010V Receiver
Hi, I have a brand new blu ray player, have set it to bitstream, and am attempting to use an optical audio cable, which does not work. The coax analog works fine but cannot get sound. I see in manual...
Instructions from manual
This receiver is equipped with two DIGITAL IN terminals-one digital coaxial terminal and one digital optical terminal.
You can connect any component to one of the digital terminals using a digital coaxial cable (not supplied) or digital optical cable (not supplied).
IMPORTANT:
• When connecting a video component using the digital terminal, you also need to connect it to the video jack on the rear. Without connecting it to the video jack, you cannot view the playback picture.
• After connecting the components using the DIGITAL IN terminals, correctly set the following if necessary:
- Set the digital input (DIGITAL IN) terminal setting correctly. For details, see "Selecting the Digital Input Terminals-DIGITAL IN" on page 16.
- Select the digital input mode correctly. For details, see "Selecting the Analog or Digital Input Mode" on page 17
The rest can be found on the link below. NOTE the page numbers referrer to the manual pages NOT the pages numbers on the site.
JVC RX 5032VSL Instructions Manual Selecting The Analog Or Digital Input...
Nov 10, 2017 | JVC RX-6030V Receiver
Cant get our HDMI to work on our JVC HD 58S998.
First, contrary to popular opinion, HDMI cables connect to a tv are not the best way to connect the two. The HDMI technology has flaws that often shows up as sound problems.
If your TV has the capability for component connections, use them. It will take 5 cables, 3 for video and 2 for audio. You will get superior sound and video. The 5 cables terminate in RCA type connectors and are much cheaper than an HDMI cable.
I hope this helps and solves your problem. :-)
Jan 03, 2010 | JVC Televison & Video
JVC Plasma VM35DX
i want to have the proper driver to use computers how to install the receiver and tell me how to download the driver
Sep 26, 2008 | Televison & Video
JVC LCA10288-07D Refurbished Panel IF Assembly Digital Video Board for use with VM-42WV74 Plasma Display LCA1028807D LCA10288 07D LCA-1028807D LCA 10288-07D LCA1028807D-R Logo
27 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
