Question about AEG 23 in. Favorit 44070Vi Built-in Dishwasher
Favorit 40010 vi dishwasher the machine door opens during the wash except on eco 50 wash
  • 1,511 Answers
Strange it remains closed on one stage? Usually a door that opens by itself is due to misalignment, and then gain water will leak onto the floor. If someone banged into the side of the door and moved the washer a slight bit, the locking tab under the work counter may not be in a positive position. If the tab is bent slightly up, the door may barely make contact and lock when in operation. A simple movement of the washer could pop the door open. Other than that, any electrical dysfunction would require a professional servicemans attention.
Posted on Mar 18, 2014
5 Suggested Answers
SOURCE: Integrated dishwasher door fitting
open the front door. On each side of the inside of the door are various long screws, unscrew these and the old door will fall off. discard the old door and follow the same steps in reverse to put the new door on. It took me 10 mins to do. Hope this helps
Posted on May 22, 2007
SOURCE: Detergent Dispenser does not open
The door often sticks because of hard soapy deposits jamming the hinges from moving freely. Just use some warm water and a toothbrush and/or toothpick to dislodge the deposits. Then remember to do this once or twice a year (depending on use of course).
Posted on Jul 28, 2008
SOURCE: Ontegrated dishwasher door fitting
Just fitted on of these & found the door very easy to fit.
The instruction sheet is actually a template as well. Attach it to the back of the door & where indicated drill 2mmø holes to a depth of 14mm. Firstly then screw in the 2no. screws that go into the door slots, the actual screws are easy to spot as the screw thread finishes approx 5mm from the head.
Once that is done you need to offer the door to the front of the dishwasher & slot it into place. Once done you have to fix the door in place with the 6no. longer screws. To do this you must remove 4no of the screws which are holding the front of the dishwasher together, the other 2 screws go through empty positions at the bottom of the dishwasher door.
To help with this process I would recommend you use a soft jawed clamp to hold the door in place whilst you screw it in place.
There are also 2no. angle brackets that fit into 2 slots on the top of the dishwasher which are then used to hold the dishwasher in place under the work top.
Hope this helps.
p.s. one last thing, the thin strip of steel that comes with the kit fits onto the underside of the worktop in the position shown, I believe this is a steam deflector to protect the underside of the worktop
Posted on Nov 10, 2008
joe_lishman
  • 192 Answers
SOURCE: aeg favorit 86070 vi fully integrated dishwasher
This is typical of the anti-flood circuit that opperates once it detects water on the base of the machiene and is a polystireen float that activates a micro switch. This puts the machiene in pump out mode only. You need to determine if the water at the base of machiene is caused by a small leak or is it a customer spillage. Clearing the water (tip to side) or dry with paper towel and inspect for leaks. Rectify the leak and this should solve the problem.
Posted on Jan 19, 2010
I have a AEG Favorit 65011 VI (dishwasher) which stops in the middle of a programm an shows error ",60" that is not mentioned in the Users Manual. Can you please help me?
The temperature must increase by a certain amount at each step.
If there is no temperature increase during three minutes, the electronics will generate "Heating Time Out" or fault code i60.
In this case program will continue to the end without heating and the washing result will probably be unsatisfactory.
Could be: Heating element faulty; intervention of safety
thermostats (open); faulty wiring; NTC sensor (poor
thermal contact); insufficient water circulating in the
tub; washing faulty pump (impeller stripped); circuit
board faulty.
Dado
Mar 10, 2015 | AEG Dishwashers
When I start the normal 50 button, the top and middle lights blink three times. Then after few seconds the normal 50 and bottom lights start to blink
Start the wash programme
1. Check that when the dishes and cutlery are loaded in the dishwasher
the spray arms are free to rotate.
2. Open the water tap fully.
3. Shut the door.
4. Press the ON/OFF button. ON/OFF button indicator comes on.
5. Press the button for the programme required (see "Programme Table"). The programme indicator lights up. One or two lights will flash in the multi-display. During this time it is possible to reselect the programme. The selected washing programme begins after approx. 6 seconds. The current wash programme stage will always be shown in the multi-display.
3 If the top light and/or the middle light in the multi-display flash after
the programme has started please read the section "What to do, if...".
Dado
Jun 13, 2014 | AEG 24 in. Favorit 40630 Free-Standing...
New AEG dishwasher wont fit in existing space that housed our old Favorit 44050 VI
The space underneath the dishwasher, or cabinets, is referred to as the kick space. It is where your toes fit under the edge of a counter and they are typical of cabinets and dishwashers alike. You should not expect a wood trim piece to fit underneath the dishwasher and not all dishwashers will accommodate one. It is fair to say that all dishwashers will come complete with a trim piece to cover this area, since some have venting and others do not; some have a door that extends down further and some do not. Generally speaking the variation people concern themselves with is in dishwasher's width and not in the door configuration. So having said and in consideration of your (assumed) desire to retain the wood trim, I suggest you retool the wood trim piece to work/fit with the dishwasher you decide you want. This is what I did rather than use the provided black metal panel. I have attached photos.
d8c6be34-1c2a-482c-8f06-f609e72b619c.jpg 9cc1da12-62a1-4b9c-9bc2-5a2b06e4845b.jpg
Mar 11, 2014 | AEG 24 in. Favorit 44050 Built-in...
Fisher and Paykel Nautilus Dishwasher 01 error approx. 15 mins after starting
01 is a door switch fault. it is possible that the switch is corroded and the moisture is causing it to fail, making the machine think the door is open, and it will stop and tell you this.
if you can open the door, and inspect the switch, see if it clicks when pushed.
Oct 25, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
In which way can i reset my dw AEG favorit F 86050 vi?
There are 6 program buttons on the right side of the On/Off button.
Press and hold button 1 2 ( 70
Sep 04, 2010 | AEG 24 in. Favorit 86050Vi Built-in...
Cycle seems never-ending
on the ECO 50 cycle dish washer will not stop. have had to switch it off, when try to restart it automatically goes back to the ECO 50 programme. Can you please help. The Serial No. is ADP 2440 WH.
Nov 24, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
I had this problem - the dispenser only opens if there are small items in the rack in front which don't come up to the same height.
Jan 08, 2008 | AEG 23 in. Favorit 86070Vi Built-In...
GE Monogram DIshwasher
Before taking anything to bits, check you aren't just loading the machine in such a way that something (for us, it's usually a frying pan) is stopping the soap dispenser from springing open all the way. A.
Apr 21, 2007 | GE 24 in. Monogram ZBD6880KSS Stainless...
Apr 12, 2007 | AEG 23 in. Favorit 50750Vi Built-in...
Open Questions:
See all AEG 23 in. Favorit 44070Vi Built-in Dishwasher Questions
AEG 23 in. Favorit 44070Vi Built-in Dishwasher Logo
155 people viewed this question
Top AEG Dishwashers Experts
paulcarew
Kolbrun...
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
