Question about Sharp LC32LE700 Aquos 32 inch LCD 1080p HDTV
Doesn t work
Grin led lite, but black skrin. no sound.
    Problem Solver:
  • 14 Answers
Check the +12v and -12v on smps if the said voltage are present the pcb main are defective
Posted on Apr 21, 2014
Red light on not green
helllllo.........red lite......[a] red lites means during the update if it lite red remove the thumb drive from the system ,unplug it from the wall outlet one minute +..then plug back in.make sure the system is power on[ showing green led] insert thumb drive....if problem persist call bose @ 1-877-335-2073us/1-877-701-2175canada.......bose-on see me on amazon for bose remotes bookbundler
Sep 01, 2014 | Bose Solo TV sound system - Black
I have a 40" LED slim westinghouse tv..one half of
It sounds to be a backlight problem. Might be a fault to its inverter board, that lights up one half part LEDs. Contact any service technician. If you're sound in electronics, and wish to get more details to such problems, http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Jul 07, 2013 | Televison & Video
Yellow alarm light on
1.)Turn off the printer .
2.)Press the Stop button for 2 second and hold it.
3.)Press the On button hold it and release the Stop button.
4.)Press Stop button 5 times then release together with the On button.
5.)Led skrin will blank and now reseting.
6.)Computer will detect new hardware juz ignore it.
7.)Turn off the printer then turn it On now the problem solved.
try it works !
Jan 30, 2013 | Canon Pixma MX340 AllInOne InkJet Printer
Sounds works, image doesn't come on for several minutes
Send your tv back for professional repairs as this is the first sign of failing LED's somewhere in your tv. I hope this helps
Aug 25, 2012 | LG Televison & Video
My laars lite heater pilot is on, but no ignition on burners, the black coated box led light is off. What can I do prior to calling a service technician model LLG325N-C
It sounds like there is ethier no power to the heater, or the flame sensor is ethier dirty Or faulty. You can try to clean the flame senor with a small wire brush , or some Sand cloth if it is accesible enough to do that. Be sure to shut the gas and power Off before trying this.
Aug 09, 2011 | Lite On Laars Lite 2 Heaters: 250,000BTU...
When i putu the power cable on, the led light blink once and goes off. the screen is black. no fan is moving or any sound.
You should try to start your computer without the battery installed. If that doesn't work, you should try another power supply. If that doesn't either do the trick, it could be the motherboard causing the trouble.
Jun 14, 2011 | HP 530 Notebook PC
I have a sharp 37" lcd tv,model # lc37sb24u. no pix or sound, power lite comes on about 10 seconds then power and opc lites alternate on and off. thanks RON
This problems very common in Sharp LCD tvs.The Tuner signal board have problems,every times the power LED,OPC LED lites up,just push the power button on again,wait see if the LCD backlight lite up and works,not the Power lite and the OPC lite LEDS flashes again.You,just have to push the power button again,sometimes u have to push the power button at least 6 or 7 times to get the Power LED stable,and then LCD backlight,come on than the tv work.Not sure,but if the Power and OPC lites keep flashing,after u pushes the power button at lest 10 or 12 times,and the LCD backlight dosen't come on and the tv don't work.I think,it time to change the Tuner board is completely dead.I have a Sharp LCD tv, I do this everytimes pushing the power button at least 3 or 4 than the power LED stable,and the LCD backlight come on than the tv work.Not a plaw in the power supply like those capacitors in many LCD models tvs,but some included Sharp Tvs is the Tuner signal board is not very good in design,use the tv awhile the Tuner signal board have problems recieving the power to it Tuner board components.
Apr 15, 2010 | Sharp LC37SB24U 37 in. LCD TV
Black going through the screen
It sounds like the LED picture plate has been damaged, like it was either dropped, got liquid in it or stepped on. There isn't much that can be done to repair these. You can try to carefully remove the plate-it sits on 2 rubber looking strips, and clean things up with alcohol. Put it back together and if all goes well it will work.
Jan 01, 2009 | Nintendo DS Lite Console
Hanging problem
D845GBV no display in skrin.bib tone continuously for 03 times nonstop, after which nothing happens except for cpu fan running.
Sep 03, 2008 | Intel D845GVSR Motherboard
Sharp LC32LE700 Aquos 32 inch LCD 1080p HDTV Logo
44 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
