Question about Box Cargo Van - 4700 Dt466e - Truck
Coolant in oil - Box Cargo Van - 4700 Dt466e - Truck
  • 68 Answers
Coolant in your oil usually means you have a blown head gasket.
Posted on Mar 20, 2014
I have a slight amount of oil in my radiator, I had this years ago and my dealer fixed it and said it was something small. Anyone know what it maybe or had the same experience. Thanks
This is a concern that requires immediate attention. Oil in the coolant or coolant in the oil is an indication that the integrity of the engine has been compromised and a passage has developed between the oil and coolant.
Installed in some radiators is a transmission coil cooler that is connected usually at the bottom of the radiator by two metal tubes. A failure internally of the radiator could breach the separation.
Head gaskets that have coolant pass through openings can also be a failure allowing the liquids to mix.
Look for coolant in the engine oil.
Check for oil level overfull
Look for steam from exhaust
Hope this helps.
Have repair done ASAP at qualified shop
Water in oil
Oil in water
Head Gasket Failure
Oct 16, 2016 | Cars & Trucks
Engine oil mixing into coolant
The only place, oil and water share a gasket is the cylinder head gasket, oil and water galleries run through the engine block and head via the head gasket. The cylinder pressure will be OK, it's the oil pressure that's putting the oil in the coolant, the gasket has gone between the water and oil galleries or there is an internal crack (unlikely). A coolant pressure test should show it up.
Jan 23, 2014 | 2012 Kia Sorento Base 4dr SUV 2.4L 4-cyl....
97 mercury mountaineering has oil in the radiator and coulant. Help please!
OK, lets figure out what's happening here. You are seeing "oil" in the radiator and coolant. Chances are it is not engine oil. The inly way engine oil can get into a radiator would be if a head gasket was blown. Even then, oil at those locations is not under as much pressure as the coolant is, so when a head gasket blows, what usually happens id that the coolant ends up in the motor oil and oil pan. Verify this by looking at the dipstick to see if it is extremely full. The oil could look like choclate milk. Also, open the oil filler cap and look for signs of chocolate brown goop. I'm betting you won't find that. This is good, but also bad. What you probably have in you coolant is transmission fluid. The transmission oil is circulated through a cooler located inside the radiator. If this cracks or breaks the transmission oil can leak into the coolant. However, at different times the transmission oil and the coolant are at odd with one another pressure-wise. This means that if you have transmission oil in the coolant, you probably have coolant in the transmission oil. This is very very bad, You will need to have the transmission serviced and possible overhauled to repair the damage. You will also need to flush the trans oil from the coolant system. This will require you to replace the radiator, ALL HOSES as well. Coolant hoses do not play well with transmission fluid . The inside of the hose sort of melts and gets real soft and gooey. Changing the hoses and radiator and flushing the motor should work once the transmissionhas been serviced.
Nov 12, 2013 | Cars & Trucks
99 MALIBU HAS OIL IN THE COOLANT RESEVOUR
this oil is usually from the trans cooler in the rad that helps keep the trans fluid at operating temperature by the engine coolant absorbing the heat from the trans fluid .the cooler is a steel tubing in the rad tanks that the engine coolant runs around and absorbs the heat.when the cooler rusts through the trans oil seeps into the coolant.if it was motor oil it could be caused by a head gasket were the oil passage is next to the coolant passage in the gasket and it seeps into the coolant passage.however the coolant pressure is alot higher than the oil pressure and the coolant usually enters the crankcase.
Oct 19, 2011 | 1996 Buick Century
I have a 2001 Ford windstar, I was told while having my oil changed that there was oil in my coolant, yet when my we removed the coolant from the reservoir and waited for it to separate it never did, which...
In my opinion, if you drained the coolant and there was NO OIL in it or any evidence ( an oily film in the reservoir), you were the poor victim of a dishonest oil change facility.
Just watch your coolant and oil level daily for the next week or so. If any milky residue appears on the inside of the cap where you add oil, or any oil film builds up on the coolant reservoir, then you might have a problem. Most likely a head gasket has failed.
when oil mixes with coolant it sill stay suspended for a long time. Water and oil don't mix but coolant and oil will due to the chemical properties of the coolant and it can take days to seperate.
Sep 23, 2011 | 2001 Ford Windstar
Win i start the car and look under the hood, there is oil coming out of a box that is, on the side of the block. But above the oil filter ?? . How do i fix that, is it a gasket or what ??
That is the engine oil cooler. There is a 'O' ring between it and the oil filter mount. They harden and crack.
Ask your dealer for the large Oil Cooler 'O' Ring.
Remove oil filter. Remove exposed pipe nut holding oil cooler to housing. If nessacary, drain coolant so you can disconnect coolant hoses from cooler or catch coolant as hoses disconnected. Swing oil cooler away and remove old 'O' ring.
Place new 'O' ring with grease on oil cooler it to hold it in place and reassemble. Tighten oil filter pipe nut to around 18 ft lbs .
Refit oil filter. Refit coolant hoses and top of oil and coolant.
Run engine to check for leaks and allow to cool. Top of coolant to COLD level if required.
You will need hose clamp pliers and wrench for oil cooler pipe nut. Pliers can be obtained from most parts stores.
Jan 12, 2011 | 1996 Volkswagen Jetta
2000 vw jetta 2.0 checked oil no oil showed on dip stick. saw that oil leaked into coolant system. replaced head gasket w/ new head bolts. flushed system, drained oil, new filter. after all done no oil...
Most likely place for oil into coolant is oil cooler, the aluminum box that mounts between the oil filter and a flange that comes off the block.
Jan 10, 2011 | 2002 Volkswagen Passat
Car overheated once. added more coolant. Now coolant level goes down gradually from time to time, but engine oil seems to be rising. no coolant on the ground that I can tell. whats the problem?
have you noticed some coolant in your engine oil? it will make some bubbles/foam in your oil. If so, the engine head might be cracked and your coolant is mixing with your engine oil. That would explain the reason why your coolant goes down and your oil level goes up.
Nov 30, 2010 | Buick Rendezvous Cars & Trucks
Transmission fluid level need regular top up and there is no external leak.Fluid color looks white.
If no external leak and the transmission fluid colour looks white, the problem belongs to the automatic gearbox oil cooler. The oil cooler has broke mixing the gearbox oil and coolant causing this milkshake. It's a small radiator core type oil / water heat exchanger. It is cracked inside and transmission oil is mixed with engine coolant. Because the transmission oil pressure is greater than engine coolant pressure, the transmission fluid level drops. See also the coolant colour inside recovery coolant reservoir inder bonnet! It could be like this:
The automatic gearbox oil cooler type oil / water heat exchanger (oil cooler):
(In the picture above the transmission oil pan was removed for oil filter replacement).
Oct 29, 2010 | 2005 Audi A4
Where is coolant temp sensor located
Not sure of your engine size so please pick the appropriate diagram:
Coolant temperature and oil pressure senders-4.3L engines
Coolant temperature and oil pressure senders-5.0L and 5.7L engines
Coolant temperature and oil pressure senders-7.4L engines
Coolant temperature and oil pressure senders-6.2L and 6.5L diesel engines
Sep 15, 2010 | 1994 GMC Sierra
Box Cargo Van - 4700 Dt466e - Truck Logo
59 people viewed this question
Top International Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an International Vehicle Part and Accessory Expert? Answer questions, earn points and help others
