Question about Cameras
Pcc error code on my stealthcam trail camera
Trail camera just displays 'pcc' error code all the time
My tasco trail cam boots up with 4 dashes on display. Nothing else.
When you hit enter does it change the dashes to zeros? Default code is 0000
Apr 27, 2014 | Bushnell Trail Sentry 11-9200 Digital...
Date time displayed wrong but programmed right
Has this to do with difference in europeen and american time and date?
Like europ: DD/MM/YY
american: MM/DD/YY
europ has 24 hours clock america 12 hours with AM and PM.
Nov 03, 2013 | Moultrie Game Spy D555i Trail Camera
Lost security code for stealthcam
check the owner manual--most have a default that will always work or Contact maker for assistance.
Nov 06, 2012 | Stealth Cam STEALTHCAM STCZ3IRTL CORE...
What is the sc 422 error on a RICOH AFICIO 6513?
SC422 PCC leak - Timing & Condition -
When the current leak is
detected for 2 seconds,
and the leak detection
started 1 second after the
PCC turned on. This leak
signal is monitored twice a
second. If it is detected
twice in a row, this SC is
displayed.
• PCC unit not properly
installed
• Broken corona wire
• Defective high voltage
supply board
(T1/PCC/BR)
• Defective I/O control
board
• Defective main control
board
Sep 02, 2011 | Ricoh 6513 Copier
I got my Bushnell Trail Sentry Digital Trail Camera and the code does not work so what is another code.
the first time the camera is used the code should be 0000 unless previously changed,try removing and reinstalling the batteries,this hould start your set up again.
press and release the power button and wait for 4 H's,"HHHH" to appear,this may give you another chance to use 0000 or whatever you chose as your password.press enter after each digit,then press enter again.the indicator should display PASS.if it displays ERRO then it is the wrong password.there is a password recovery service provided by Bushnell at 1-800-423-3537 and press option 2,you will need to provide your serial number to the representative.
hope this helps.
Jan 09, 2011 | Bushnell Trail Sentry 11-9200 Digital...
I just bought a Tasco Digital Trail Camera - 119223C . During the setup my camera display also shows Loc and the SD Card flashes. The instruction manual does not reference this setup code. Does...
I just bought,last August, a Tasco Digital Trail Camera - 119223C . Took pictures until Jaunary 2011, my camera display shows Loc and the SD Card flashes. The instruction manual does not reference this setup code. Does anyone know what 'Loc' means? I tried to reformat card, I also so not get a Y/N option for formatting. I bought a new card and changed batteries. no change!
Nov 14, 2010 | Bushnell Trail Sentry 11-9200 Digital...
Password Error
To reset the password:
Turn unit on and wait for password prompt
Depress the and hold the enter button until camera
switches into 5-digit password mode _ _ _ _ _.
Trail sentry systems will not indicate 5-digit mode on the screen, but will indicate _ _ _ _ instead of HHHH .
Press enter to confirm 5 digit mode
Enter 5-digit code 66214 and press enter button( trail sentry cameras will accept a 5th Digit after the 4th digit is entered in the _ _ _ _ screen.
Camera will now go into operating mode, and user can now program a new password from the setup mode
Mar 18, 2010 | Bushnell Trail Sentry 11-9200 Digital...
Bushnell Trail Sentry camrera will not accept any code
If the Bushnell Trail Sentry 11-9200 is turned on without an SD Card in place, it may need to be reset. Reset it by pulling one of the batteries out partway, insert a new or empty SD card, and put the battery back in place. Read this Set Up Guide for instruction how to set up your passcode.
The camera will not Make sure the power is off before installing or removing the SD Card. If you forget, you need to do the reset procedure above.
Buy Name Brand Trail Scouting Cameras here.
Feb 07, 2010 | Bushnell Trail Sentry 11-9200 Digital...
Error code sc 422
422 D PCC leak
When the current leak is detected
for 2 seconds, leak detection
starts 1 second after the PCC
turns on. The leak signal is
monitored twice at 1-second
intervals. When the leak condition
is detected twice continuously,
this SC is displayed.
1. Check if the PCC unit is properly installed.
2. Replace the corona wire if it is broken.
3. Check if the connectors on the terminal and
high voltage supply board (T1, PCC)
are
properly connected and if the cables are
damaged.
4. Clean the receptacle.
5. Replace the high voltage supply board (T1,
PCC)
6. Replace the I/O control board.
7. Replace the main control board.
- Signals to Check -
[A258/A259/A260]
Leak Detection:
CN227-B1 on I/O control
Board
[B017/B018]
Leak Detection:
CN221-B1 on I/O control
Feb 10, 2008 | Ricoh Aficio 450 Copier
Error on display
either bad carriage or trailing cable if you've already tried new inks.
Jan 16, 2008 | HP DesignJet 750c plus InkJet Printer
Cameras Logo
122 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
