Question about Gateway MX6453 Notebook
Gateway MX6453 fan does not start until 70 degress celsius
Fan does not start until 70 degrees celsius and then shuts off at 60 degrees.
  • adamstask Jun 14, 2009
    I have a Coolmax cooling pad with two fans. It is not bringing down the temperature of the MX6453.
  • Gateway Master
  • 3,866 Answers
This would be due to a faulty sensor if it does not reboot and overheat then leave it be and buy a cpu cooler that goes underneathe the unit there around 20 bucks.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Jun 14, 2009
Why cools the ac only 1 hour full power and never reaches the set-point temperature ?
check that all the doors and windows are closed as ac units do not work well when trying to cool the world
is the ac unit too small for the room size
I suspect that because it is working the problem is outside the ac control
is the inside fan working and blowing out cold air
May 22, 2016 | Heating & Cooling
Electrolux ewx14440w washer dryer will not heat water
Hello - Hot water is most often 10 degrees colder when it arrives at your machine from when it leaves your hot water heater. In general hot water is 130 degrees Fahrenheit (54.4 Celsius) or above. Warm water is between 110 and 90 degrees Fahrenheit ( 43.3-32.2 Celsius). Cold water is generally between 80 and 60 degrees Fahrenheit (26.7-15 Celsius). If cold water is below 60 degrees Fahrenheit (15 Celsius), clothes are unlikely to be cleaned very well. After confirming information and it proves to be ineffective contact a professional to move forward accurately. Unit could possibly be experiencing a defective timer, temperature sensor, or water valve.
Oct 28, 2012 | Electrolux EW1000i Front Load Washer
Where is the the thermostat on a 2.0 , 2000 vw beetle ? Thank you
First time you might check the thermostat operating.
Heed of antifreeze coolant temperature!!!
The thermostat location for 2000 VW Beetle 2.0L is on back of the alternator at the bottom side of the bracket.
IMPORTANT NOTE: It is NOT necessary to replace the alternator if you want to change the thermostat !!!
Thermostat checking:
1. Cold engine. Start up the engine and watch of the water temp indicator. After first value 60 Celsius Degree you still warm up the engine until the lifter (pointer) reach 80 C deg. (second mark after 60 C deg.). At this time you let engine running at idle speed and check with your hand the thermostat plastic housing and hose temperature in bottom left side of the engine. Heed of alternator driving belt and ventilator fan !!!
2. If the thermostat is good the hose must be cold until the water temp indicator reach almost 90 C deg.
3. The thermostat opening temperature is 87 C deg.
4. If the hose is already warm the thermostat is out of order.
Thermostat location, Part number: 050 121 113 C, in german - "Kuehlregle".
Remark: 87 ... 102 Celsius deg.
Price around $35:
Important note: Always replace the thermostat seal, position 7 in the above picture.
Sep 27, 2011 | 2000 Volkswagen Beetle
Water too hot
Jul 20, 2011 | Washing Machines
Desktop will shutdown as Windows XP screen comes up. Shuts down while trying to load into all safe modes. The computer is a custom built computer, and I have cleaned the inside of dust, and tried to...
I would start out by getting a power supply tester (which can be picked up fairly cheaply on Ebay) and checking out your power supply. If it is anything deeper than that, I would look into having a TECH look at it since it could possibly be a ground in the motherboard. You may also want to check and make sure that any expansion cards (memory, video) are seated correctly. If you don't have any expansion cards, it may be your onboard video going bad.
Aug 24, 2010 | Computers & Internet
What temperater should fan turn on and i know the problem isnt the fan what should i check next
the temperature of speed motorcycle is over 100 degrees Celsius. Between 100 and maximum 110. In cooling system you must have antifreeze all the time, because this boil higher than 110 degrees.
If the fan start higher than 100 degrees, is ok. But i guess until 110 degrees. Search by internet the manual for full specifications.
Cheers.
Apr 13, 2010 | 2002 Suzuki GSX-R 600 M
Dell Inspiron 530. Started shutting down on its own a few days ago, sometimes just completely shutting off, sometimes going through the whole 'logging off' and 'shutting down' process. Have tried a...
hello, i don't know from wher u can get a button but u can try somthing else; try to see if your cooler it is working properly ( look in bios and see what's your CPU temperature is after 15 minutes of working; if it is over 60-70 celsius degrees then u need to change the cooler)
Dec 28, 2009 | Dell Inspiron 530 Desktop Computer
Reset Heating/ AIr cond temp display as well as EXT temp ????
the temp display can be switched between celsius and farenheit readings, since the car is from europe the default is celsius, The manual has instructions on changing back, You have to hold 2 buttons on the display per the manual.
May 07, 2009 | 2003 Land Rover Discovery
Problem of frequently shutdown unexpectedly for m6810 laptop ........When fan starts after some temp. goes up to 53 C. it causes....
laptops/notebooks tend to overheat more quickly the desktop resulting in shut down, try a laptop/notebook cooling fan
Feb 27, 2009 | E-Machines M6810 Notebook
Gateway MX6453 Notebook Logo
247 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
