Why my laptop shut down quick
Why it shut
    Top Expert:
  • Computers & ... Master
  • 21,561 Answers
Many reasons could be the cause. Overheating, Low battery, software issue, hardware issue ...
More information please.
Posted on Mar 17, 2014
Thermal shut down of next book ares 11A ... Happens after 10 minutes of use. How do I fix this?
Sounds like the cooling fan has failed if it shuts off that quickly. Most laptops will require a certain amount of disassembly to replace the cooling fan. Do you hear the fan when it is running before it shuts down?
Oct 07, 2016 | Computers & Internet
Tip
FAST SHUT DOWN
To shut down your windows XP PC or Laptop quickly just press the start button+W+W keys continuously and the system shuts down automatically.
on May 16, 2011 | Computers & Internet
My laptop has a black screen and i cannot give it any command and have to force shut it down
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Apr 07, 2013 | HP Pavilion DV6500Z Notebook
Latitude D830 starts then shuts down quickly.
1. Make sure you are plugged into A/C.. Your battery could be running low.
2. Make sure there is nothing blocking the heat vents. This symptom is typical for overheating processors.
Mar 17, 2013 | Dell Latitude D830 Laptop Computer PC...
My hp ez4400 starts up but quickly shuts down ,
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
If this did not work, try also disassembling the laptop & make sure that all main components are seated properly. Also make sure that all ribbon cables interconnecting the various components of the laptop are tightly connected.
Dec 28, 2009 | HP Computers & Internet
I have an HP Pavillion dv9500 laptop. After shutting down, all the keyboard lights to the right of the power button stay lit. This shows the power is not shut off but should be. Any solutions?
First of all, is the laptop on charge? Usually when the laptop is on charge there is a light somewhere that remains on until it is charged. After charging, the light goes of and if the laptop is not used for a long time, the battery usually discharges a little and the system senses this and recharges it as top-up and the light comes on, then goes off once charged. If your laptop is not on charge, then there is 2 things that could be the cause. 1) It is not shut down properly (on stand-by). 2) It may be downloading updates and it would probably shut down later, depending on the size of the update, it may take a few minutes or up to 1 hour. If in 1 hour the light is still on, then there is a problem with the laptop and need to be checked by a professional, or, altermnatively, turn it off a second time and see if the light still remains on. Lastly, you did not state what kind of lights remain on, Power, Charging, Standby, etc. it is difficult to help you with your query as the problem could be the laptop itself. There are other things that could keep the laptop on, and that may be if your laptop is connected to a network. Regards.
Sep 27, 2009 | Computers & Internet
Turn off problem
Check device manager for any driver update. Also perform sfc /scan now using run command.
Jul 25, 2009 | Lenovo 3000 Y410 Notebook
Systemax laptop not shutting completely down
Try this ;
Buried deep inside Windows XP lurks a little-known program called shutdown that shuts down your system in a very fast � but orderly � way. Here's how to put an icon on your desktop that'll shut down your machine quickly:
1. Right-click any empty location on your desktop.
2. Click New, Shortcut.
The Create Shortcut Wizard appears.
3. In the Type the Location of the Item box, type shutdown -s -t 0.
It's important that you put spaces before each hyphen, that you have no spaces after each hyphen, and that you use a zero at the end.
4. Click Next. 5. In the Type a Name for This Shortcut box, use a name that will remind you that this button is for a very quick shut down.
6. Click Finish.
Jan 15, 2009 | Systemax AOL Optimized PC (100607) PC...
Laptop shutting down
A quick fix is to blow back into the vents to blow dust out.
May need to dismantle though and clean fan and maybe even remove heatsink and renew thermal paste.
Jan 06, 2008 | Computers & Internet
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
