Question about Corby Pants Presses Corby 4400 Pants Press w/ 15/30 Min Timer, 17-7/10 in. W x 5-1/2 in. D x 43-3/10 in. H, Walnut
My heating pad worn(corby trouser press)
Heating pad worn because i have used machine for along time
Brakes are squealling
Two possible causes
Worn brake pads so Metal on Metal - leads to rotor damage leading to re machining of rotor (the big metal disk that the pads rub on )
Or Rotor has been worn down from machining and rotor is not dissipating heat and over heating
Apr 06, 2017 | Cars & Trucks
Please advise me on problem with corby trouser press I purchased this and fitted it as suggested switched it on it looked fine but after a couple of miniuts it shut off i checked the fuse and it had blown...
if the purchase was recent -- put back in its box and take it back to the store. If it is not feasible to return it to the store, call the manufactures customer service section and tell them you have and electrical fault within in the press. They should replace it no cost to you. If you cannot get satisfaction - file a complaint with Fed Gov Consumers watch dog
Jan 29, 2015 | Irons
Hard stopping the 1992 venture yamaha when coming to a syop the bike doesnt brake well
check the brake caliper pistons are free ! push pads back and press lever to see they move back against the pads , also are the pads worn out as they will over heat , check this and are you using 60 % front and 40 % brake pressure when riding ?
Feb 13, 2014 | Yamaha Motorcycles
Heating pad is wrinkled so clothes come out wrinkled
I thought my old one was faulty so I bought a new one and still experience the same wrinkling problem!
Dec 22, 2013 | Corby Trouser Press 7700
I have a Corby 7700 pants press that does not press the pants
Here are the instructions for this product:
http://www.corbyofwindsor.com/store/uk/info/292/TrouserPressInstructions
Feb 14, 2013 | Corby Trouser Press 7700
Corby 7700 will not heat up enough to press pants
Here are the operating instructions for this product: http://www.corbyofwindsor.com/store/uk/info/292/TrouserPressInstructions#Operating_Instructions
My samsung corbi s3653 tuch pad dont work
If you can get the keypad up pres *#0*# and check the lcd test, if you cant press the touch pad you need to call samsung on 1300-362-603 for service booking
May 02, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
I am use samsung corby from last five month.but now the touch screen not working prppley
You need to calibrate the touch pad. I believe you can locate that in the settings of the phone. Then calibrate it. Just follow the cross lines by pressing the center of the cross line.
Jul 13, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
Corby Pants Presses Corby 4400 Pants Press w/ 15/30 Min Timer, 17-7/10 in. W x 5-1/2 in. D x 43-3/10 in. H, Walnut Logo
82 people viewed this question
Top Corby Pants Presses Home Experts
Donni Steen
Tom Chichester
Are you a Corby Pants Presses Home Expert? Answer questions, earn points and help others
