Question about Samsung HP-P3761 37 in. HD-Ready Plasma Television
Samsung le40a766r no.1 fan fault. I removed the back of the tv and the fan was stuck so i cleaned it and it was functioning. so i replaced the back and the tv worked fine for about 30 mins. then the fault showed up again. please advise next step.
    Top Expert:
  • Samsung Master
  • 74,251 Answers
Replace the fan. Check the fan speed regulator circuit too. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
If the fan has gone to its efficiency, this kind of fault can occur.
Posted on Mar 17, 2014
What has to be rmoved on a 2003 Yamaha Kodiak 400 ATV to be able to remove the radiator fan motor ?
Usually the fan motor.remove the motor. take the 2 bolts out that hold the back plate with the brushes off. If the brushes are stuck in,clean and oil them. Replace the plate and check the motor with a battery charger.
Aug 23, 2014 | ATVs
Is there any solution for "check fan 1" Samsung LN40A650A LCD TV
Just fixed my Samsung LN40 check fan #1.Unplug, Take the back off (like 20 screws were hard to find them all) fan is exposed in the middle. Unscrew fan, used q-tips and nozzle tool on vacuum cleaner to remove built up dust gunk. Blew in center of fan to dislodge dust. Screwed fan back on, plugged in to see if fan was spinning to cool TV. It was and the check fan message disappeared. Put the back on. Feeling Lucky no big repair.
Nov 26, 2011 | Samsung LN40A650A LCD TV
Where is fan 1
If you have a fan error i would replace them all.
You can get get parts for this tv at www.interliquidparts.com
Error message check fan 1 on my samsung 7 series lcd tv
remove back cover and clean fan with q tip and alcohol also vacuum all around do not use compressed air to blow on it
Sep 03, 2011 | Samsung LN40A650A LCD TV
I have a Samsung DLP 50" HDTV HLS5086w, and I need to know how to find and remove fan # 2 from inside the TV so I can replace it but when I open up the back I can't see it anywhere. Only fan 1 is...
Fan #2 is the fan that blows air accross the lamp itself. It sits in the far upper right corner covered by a shroud. The ONLY way to remove the fan is to remove the complete light engine itself. I would recommend a technician to do so : )
Jul 27, 2011 | Samsung HL-S5087W DLP TV
Samsung HL-S5087W (" CHECK FAN # 1") is displayed
hello Harley,
Lamp # 1 is lamp fan, Lamp # 2 is DMD board fan.
Lamp # 1 is located behind the lamp.
Pull assy angine out you will fine fan # 2 , clean it or replace it if not rotate properly.
Fans displayed on screen because fans are dirty or air flow not smoothly.
Good luck.
Mar 30, 2011 | Samsung HL-S5087W DLP TV
Tv dosnt stay on
This is one of many protection circuits built in to prevent damage. If the cooling fan fails, the set will shutdown to prevent overheating or fire. There should be venting on the bottom of the set, try using either a vacuum or canned air to move air into/from those vents. It is possible that dust has accumulated and is blocking the airflow sensor. You may need to remove the back and clean the fan(s) or replace them.
Dan
Apr 16, 2010 | Samsung LN-S4041D 40 in. LCD HDTV
My Samsung 50'' DLP msg "Check Fan No. 3"
You can attempt to remove the back cover, but there is a very delicate mirror in the back. I'd just move it away from the wall, used compressed air to clean out the fans, and put everything back together. Just make sure you don't damage the color wheel or light engine.
Feb 04, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
HLS5087W DLP Samsung Fan problem
Replace it if fan to Lamp stops running this will fix problem Call Mats 1-800-628-1118
Sep 16, 2009 | Samsung HL-S5087W DLP TV
Samsung HP-P3761 37 in. HD-Ready Plasma Television Logo
50 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
