Question about ASK Proxima Office Equipment & Supplies
Intermittent signal from Computer - ASK Proxima Office Equipment & Supplies
    Genius:
  • 1,552 Answers
Check the tightness of the video-cable connections at the computer and at the projector. Try a different video-cable. Set the computer video to 800-by-600-by-60-hertz. If that works, try 1024-by-768-by-60.
Posted on Mar 23, 2014
Why do I have an intermittent problem with ABS and power steering lights?
Bad or loose intermittent wire connections to and from sensors. Some unauthorised mechanic has been working on the car? Take it back and talk to the service manager, or the shop owner.
Apr 14, 2015 | 2010 Volkswagen Polo 1.2
What is code p0106
A P0106 could be caused by: Bad MAP sensor Water/dirt intrusion affecting MAP sensor connector Intermittent open in the reference, ground, or signal wire for the MAP sensor Intermittent short in the reference, ground, or signal wire for the MAP sensor Ground problem due to corrosion causing intermittent signal problem A break in the flexible air intake duct between the MAF and the intake manifold Bad PCM (do not assume the PCM is bad until you've exhausted all other possibilities)
Feb 19, 2015 | 2004 GMC Envoy
Why do my emergency flashers work, but turn signals are intermittent on 2004 ford expedition,what could be the cause of this ?
Cause could be from a worn out multi-function switch (blinker switch)
Filaments heat and expand and decrease in size as current runs to them, basically making and breaking a circuit several times, creating an intermittent switch that supplies current to the lights. These can go out, and will need to be replaced.
Jul 24, 2014 | 2004 Ford Expedition
Monitor intermittent power problem and horizontal green flickering lines
separate wiring. touching wires creates cross-talk of signals.
Jan 28, 2014 | Computers & Internet
Giving the code E.27
E27 Open Throttle Switch Signal here is a list of all codes E12 No Distributor Reference Signal E13 Oxygen Sensor Not Ready E14 Shorted Coolant Sensor E15 Open Coolant Sensor E16 Generator Voltage Out of Range E19 Shorted Fuel Pump Circuit E20 Open Fuel Pump Circuit E21 Shorted Throttle Position Sensor E22 Open Throttle Position Sensor E23 EST Signal Problem E24 Speed Sensor Circuit Problem E26 Shorted Throttle Switch Circuit E27 Open Throttle Switch Signal E30 ISC RPM Out Of Range E31 Shorted MAP Sensor Signal E32 Open MAP Sensor Signal E34 MAP Sensor Signal Out Of Range E37 Shorted MAT Sensor Signal E38 Open MAT Sensor Signal E39 VCC Engagement Problem E40 Power Steering Pressure Switch Signal E41 Cam Sensor Signal Problem E44 Oxygen Sensor Signal Lean E45 Oxygen Sensor Signal Rich E47 BCM to PCM/ECM Data Problem E48 EGR System Problem E52 PCM/ECM Memory Reset E53 Distributor Signal Interrupt E55 Closed Throttle Angle Out of Range E58 Pass Key Control Problem E60 Cruise - Not In Drive E61 Cruise - Vent Solenoid Problem E62 Cruise - Vacuum Solenoid Problem E63 Cruise - Set Speed vs Vehicle Speed E64 Cruise - Acceleration Too High E65 Cruise - Servo Position Signal Problem E66 Cruise - Engine RPM Too High E67 Cruise - Switch Shorted E68 Cruise - Command Problem E70 Intermittent TPS E71 Intermittent MAP E73 Intermittent Coolant Sensor E74 Intermittent MAT Sensor Signal E75 Intermittent VSS Signal E80 Fuel System Rich E85 Idle Throttle Angle Too High E90 Cruise - VCC Brake Switch Signal Problem E91 Cruise - PRNDL Switch Problem E92 Heated Windshield Request Problem E96 Torque Converter Overstress E97 P/N To D/R Engagement Problem E98 P/N To D/R ISC Engaged Problem E99 Cruise - Servo Apply Problem
Jul 31, 2013 | 1992 Cadillac DeVille
P0106
Bad MAP sensor
Mb Star C3 Pro with seven cable Fit all computer For BENZ Truck and Cars 2012.09
Dec 14, 2012 | 2011 Infiniti M37
Intermittent turn signal problem.
hazard switch is the problem
Feb 11, 2010 | 2002 Chevrolet Malibu
Turn signals don't blink,runnlng lights work intermittent no tail
Check your ground to the lights and or any other wires going to the lights and all connections
Oct 19, 2009 | 2001 Victory V 92 C Deluxe
Intermittent clicking of turn signal
these vehicles have a very common problem that allows the flasher to click even though the signal is not on.. this is an internal directional switch problem and can either be taken apart and cleaned or replaced to correct the problem...
Jun 13, 2009 | 2003 Pontiac Grand Am
Monitor goes to standby mode intermittent.
make sure the video cable is inserted firmly. is it is, the video cable wires are loose inside the monitor which it is not getting the signal, telling it to go on standby mode.
Jun 12, 2008 | LaCie Electron III 22" CRT Monitor
75 people viewed this question
Top ASK Proxima Office Equipment & Supplies Experts
jasbo
jasbo
240cpa
Lyle Siemens
Lyle Siemens
Are you an ASK Proxima Office Equipment and Supply Expert? Answer questions, earn points and help others
