Olivetti 8015 photocopy jamming problem - Office Equipment & Supplies
Olivetti printer shows bourrage error
Paper jam is the translation.
Remove the paper tray, remove toner cartridge if it has toner, and open any side or rear access doors. Remove what is sticking.
Dec 29, 2015 | Olivetti Office Equipment & Supplies
How do I fix a jammed ribbon guide on a Olivetti Letter 32? It won't move up when I hit a key.
Before you do anything rash check the ribbon color lever if it is in the white position the ribbon won't lift.
DickyO
Apr 04, 2015 | Olivetti Office Equipment & Supplies
My photocopier is just saying reset all originals in DP how do i reset
Open and close the document feeder (where you put your pages that you want copied), take out any papers on there and place them back in the document feeder. press the start button. Good luck !
Oct 18, 2012 | Copystar CS-2550 All-In-One Printer
How to unlock the shift lock?
Try without ribbon and L/O tape, check for bent or broken spokes on print wheel.
DickyO
Sep 09, 2012 | Olivetti refurbished etv2700 typewriter...
Cant find a manual for a brother galaxie 8015
http://www.sewingmanuals.com/Sewing_Machine_Manuals/Brother.htm
It is the second from the bottom.
May 09, 2011 | Computers & Internet
The Caps Lock/Shift key jammed on my Olivetti Lettera 32
Sounds like the shift key lock spring is broken or missing. Look ont he key and hook it up or find a tiny spring to install.
Dec 13, 2009 | Office Equipment & Supplies
Canon FC 120 Photocopier. Red Paper jam light keeps flashing
hi,clean any sensor & clear any hide misfeed sheet.send me result.
thank you.
May 31, 2009 | Canon PC-160 Black and White Copier
Olivetti 8516 photocopier quality problems
i face error 261 on olivetti copia 8516
May 16, 2009 | Office Equipment & Supplies
Olivetti ecr 350 cash register problem starting up
There is an ECR350 manual here that might help:
All of these manuals can be downloaded at:
http://the-checkout-tech.com/
olivetti CMS-140B User Programming
olivetti ECR-2100 User
olivetti ECR-2150 User
olivetti ECR-2200 User
olivetti ECR-2250 User
olivetti ECR-2300 User Programming
olivetti ECR-2350 User Programming
olivetti ECR-2400 User Programming
olivetti ECR-2450 User Programming
olivetti ECR-2500 User Programming
olivetti ECR-2550 User Programming
olivetti ECR-300 User Programming
olivetti ECR-350 User Programming
olivetti ECR-3550T
olivetti ECR-5000 User Programming
olivetti ECR-5100 User Programming
olivetti ECR-5700 User Programming
olivetti ECR-5800 User Programming
olivetti ECR-5900 User Programming
olivetti ECR-5920F User Programming
olivetti ECR-6100 User Programming
olivetti ECR-6700 User Programming
olivetti ECR-6800 User Programming
olivetti ECR-6900 User Programming
olivetti ECR-6920F User Programming
Jun 20, 2008 | Olivetti Office Equipment & Supplies
14 people viewed this question
jasbo
jasbo
