Tuning I have a Roland 1000s piano which I purchased approximately 20 years ago. Suddenly it is out of tune. In there an internal battery? Any other solutions would be appreciated.
  • 5603 Answers
SOURCE: It's a Roland HP-7e digital piano about three years old.
You may need to clean the contacts which are usually conductive rubber. I explained stuff for another Roland problem with two keys that were intermittent. I have an EP-7 that I had to do the cleaning of the key contacts. Use 91 or 99 % Isoprophyl alcohol to clean BOTH the conductive "pill" (Black under silicone rubber domes) AND the traces on the board where they press. Clean gently as the traces have a hard black coating.
Posted on Jul 29, 2009
SOURCE: Options to auto-tune or manual re-tune are greyed
Problem solved!!
According to the Sony website I needed to get a software download in order to fix this problem. I found out how to do this from the manual and realised that the re-tune menu I was looking at was for analogue only. The pictograms onmy remote control are a blurred but the manual helpfully provided a picture showing the correct program "info" button (next to 0) which has options to look at other things, including a "detailed set up" menu on the blue tab, which provides options for software download and re-tune of digital channels.
Incidentally, I discovered that my TV model was not quite as quoted above - it is KD-28DX200U, but expect the same process works for other oldish models.
Posted on Oct 03, 2009
  • 1138 Answers
SOURCE: I have just aquired a Roland E-20 synthesizer
They use pre-programed chips. You will have to use the midi out feature to control another midi capable sound module or midi in to a computer and use the internal sound card.
Posted on Oct 25, 2009
Testimonial: "Very informative. I will investigate further as my knowledge on MIDI is limited!!! Thanks for your response."
Prestopick
SOURCE: I need a service manual for Roland FP8 piano, or..
Did you ever get hold of an FP-8 service manual? The weight replacement is relatively simple: The case opens by removal of eight screws, four at each end on the underside. The top then hinges up. Keyboard assembly is removed by first unplugging the two white ribbon connectors at the center, then removing the screws at the front edge (underneath) and the screws (gold) at the back of the assembly (accessible from the top). Keys pop out by spreading the two "wings" at the pivot point, and then the weights (Roland calls them "hammers") lift out. Roland will sell you new ones, but I have no idea whether the replacements are any better than the originals. I've done two of these pianos so far, and have a third waiting to be worked on. I do have a service manual, but I think I downloaded it freebee somewhere.
The other failure mode on this piano is the electolytic coupling caps on the output board - I've replaced all of them on both pianos - don't remember the value offhand.
Paul Prestopino presto11@verizon.net
Posted on Nov 19, 2009
  • 74 Answers
SOURCE: roland hp550g digital piano has a couple of dropped keys
Power off the unit. Disconnect all cables that plug into the speaker base if you have one - It may be wise to document the individual wires to make their reinstallation easier. Remove the unit from the speaker stand and lay it on the floor on something like an old towel - you may get some dark colored grease on the rug. Remove the screws only for the bottom rear, not the front - you don't need to remove them. Do this by gently turning the unit upside down. Only remove the screws from the sides/rear bottom, and note which screw types you removed from where. Once all bottom rear screws are removed gently return the unit right side up. now pivot the top rear cover - the sides of the cover are attached to the rear - pivot it toward the back. No need to remove the ribbon cables - just let the top lay there or prop it up with something if the ribbon cables don't have enough slack for the top cover to lay flat on its back. You should now be looking at all of the keys uncovered. notice the rear of each key is where it hinges. You'll notice the grease at the hinge point. The keys are thin plastic so you must take care not to damage them. The way to remove a key is to spread the ears at the hinge point of the key you want to remove. I use a screwdriver sharpened to a point, but a large pair of needle nose pliers work good too. You insert the tapered point of the tool between the ears gently to spread them far enough to just clear the pins. Once they are spread wide enough you'll feel them disengage. Each key also has two hooks located side by side towards the front of the key on the bottom side - they are not visable until the hinge is released, but you must realise they are there or you'll either snap the key back onto the hinge or not be able to pull the key out once you've got it off the hinge. Pivot the key towards you to remove it. What you now have in your hand is not the defective part. You have the top that is touched when playing the keyboard. The defective part is still setting in the mechanism. What's actually happened is the keys are made of very thin plastic where they are glued around the weight and this plastic breaks leaving the weighted end down there somewhere. Examine where the key top came from and how it works. The key top is the part you took off of the hinge. You can see how the keys on each side work and you'll also see what is missing from the mechanism for the key you're working on. To make things easier I always remove one additional key top on each side of a key that I repair to make access easier. Just place the other keys you remove right behind the key area in the order you took them off so it'll be obvious how they go back on. Now the broken weighted mechanism you can lift right out. Actually you can lift it out easier with the weighted end broken off, but once you glue it back together you can still get it in there without to much trouble. You only need to remove the damaged weighted mechanism for the key you're repairing. I remove the key tops on each side of the damaged key for visability only. Take your pair of needle nose pliers and pick out the broken end. Now fit it onto the end of the weighted mechanism in preparation for glueing - just so you can see how it's going to go on there. I use a high quality modeling super glue. Before I came across this glue I used JB Weld, but it takes a few hours to dry. The high quality super glue allows you to put everything back together immediately. Installation is reverse of removal: Snake the weighted mechanism back in once you've repaired it - you can always examine those on each side if you get confused. Hook the key top front first then smoothly snap in place the hinge ears over the pins. Make sure to check the movement of the repaired key, and check also to see if anymore keys are setting lower as they may be in process of breaking off. Once all keys are repaired, carefull lower the top rear cover onto the key assembly. While holding the cover onto the key assembly/base, gently turn the unit over onto its back and reinstall the screws. Should be all washer headed screws - do not over tighten. Check the keys again. Set the keyboard onto its base (if it came with one) and you're done. A little practice and it'll take you less than a half hour to fix the key and get it back together
Posted on Sep 23, 2010
The number stamped on the back of my piano is 57866 don't know the maker? any clue?
Jacob Brothers from 1921 according to the link shown:
https://www.mypianofriends.com/i-have-a-jacob-brothers-piano-model-number-57866-but-i-cant-find-any-infor...-107545.html
Quoting:
I have a Jacob Brothers piano model number 57866 but I can't find any infor... by Guest 5 days ago
9
I have a Jacob Brothers piano model number 57866 but I can't find any infor... I have a Jacob Brothers piano model number 57866 but I can't find any information on it? Anyone know anything regarding this model?
Posted on Questions & Answers
Answer
4 days ago C. Anthony
Guru
Blogs: 48
Forum: 16,526
Votes: 420 What type of information do you want? you have the piano in front of you!
specifically what do you want to know?
the SN shows 1921 date.
Have you tuned it this year? If the piano will not hold tune to A=440hz, the value would be 0. However, I would think it would hold 440...but I may not.
Call your local piano technician to check it fully.
CAPReply
This Might Interest You
Jacob Brothers I am trying to find the year my Jacob Brothers Player Piano serial number 6... I've got an Emerson piano. Serial number 114689. I can't find a price on it... Links For Piano Serial Number/Dates What is year of manufacture of Jacob Brothers piano serial #... How much is my Jacob Brothers upright piano worth? And what estimaTed year ... I have just come into the possession of a Jacob Brothers Baby Grand piano S... Finding the serial number of your piano Where do I find the model and serial number of a young chang baby grand pia... Jacob brothers? Jacob Brothers Piano Jacob Brothers Piano I have Baldwin serial number 305931 how do I find te model number and when ... What is date of manufacture of Jacob Brothers piano serial #43470? Thanks! What would be the age of Jacob brothers upright piano serial number 28259? How do I find serial number and date of jacobs brothers upright piano? When was/by whom/ and where was my jacob brothers piano made and what is it... Where can I find piano's make and model?
Apr 28, 2018 | The Music
I was wondering if it is normal that my piano down-tunes while I am playing.
No, it's not normal.To determine if it's a setting glitch or a hardware problem, perform a factory reset and see if the problem continues. If it does, it's a hardware problem and needs to go to the shop. Here's the reset instructions-
https://www.youtube.com/watch?v=8Xavte8p3Qc
Nov 16, 2014 | Roland RD-700NX SuperNATURAL Stage Piano
How can I repair roland digital piano model ep 95?
Sounds like something is on the board and is causing the problem. Try cleaning it with rubbing alcohol on a cotton swab, or spray clean it with electric contact cleaner spray. Let it dry and give it a try. Be sure to unplug the piano when you're in there working on it. Also, check for loose resistors, diodes, etc. Re-solder them if they're loose.
Sep 03, 2014 | Music
Tune up
You need to study or research info on tune-ups
Basically it is a sales pitch, as only spark plugs are left
& tune-ups stopped 25 years ago from a technical perspective
Your not actually tuning anything
You replacing old spark plugs,gas & air filter etc,that has been
called preventative maintenance for over 20 years
For the last 30 years the vehicles Computer does all the
engine tuning
Jul 02, 2013 | Cars & Trucks
Bernina 1010 (approximately 20 years old): the bobbin winder has stopped rotating- only a turn or so and then stops
Hello, from one sewer to another, a machine that is 20 years old does need a professional tune up from time to time. If you can, take it to a sewing machine store or a sew/vac store to get a professional cleaning and tuning. There are manuals on how to do this, but it is best to leave it to a pro. I own a number of vintage machines and I can tell you, I have wasted countless hours trying to do it myself until I found a pro in my area who sell vacuum cleaners and sewing machine. I found out that machines, like cars, need tune ups. Happy Sewing!
Aug 07, 2011 | Bernina BERNETTE 65 Mechanical Sewing...
Need to be tuned.
Unless there is damage you should only have to clean them. Do NOT compare pitch to piano since on a piano the high notes are stretched up to 22 cents sharp and at the low end they are about 20 centts flat. If any of the tubes are cracked, it is fatal. Also do not be confused by worn or deteriorated hammers that may appear to be out of tune.
Jul 22, 2011 | Suzuki 25Note Chromatic Tone Chime Set
I know that a Clavinova cannot get out of tune, but - in the lowest two octaves - my mom's CLP-115 sounds as if it is. Might this be a problem with memory, speakers or circuitry? Any idea how we might fix...
Realize that it MAY be stretch tuned like a real piano. A real piano is tuned increasingly sharp above middle C and increasingly flat below middle C. At the ends, the the off tuning is about 20 to 22 cents sharp and flat. The Clavinova should emulate this. In a real piano this makes it sound better and prevents some cross coupling of harmonics. Read up about stretch tuning on the internet. The Clavinova gets its reference from a quartz crytal oscillator and they just dont' get out of tune.
Mar 28, 2011 | Music
I have just aquired a Roland E-20 synthesizer which I am very pleased with, however, it doesn't have acoustic piano in the tone settings. Is it therefore possible to programme 'acoustic piano' onto the...
Oct 24, 2009 | Music
Roland E-20 tuning problems...
keyboard has internal battery. change it and it will retain memory of all settings + tuning. should'nt be too hard to dissasemble and get inside.
Apr 14, 2009 | Music
Tuning
If you are marginally interested in the process of tuning the piano, and your main motivation is to save the cost of a professional tuning, bite the bullet and engage the services of a qualified tuner. Trying to do it yourself will become overwhelming very quickly. If, however, you are genuinely interested in the skill of tuning, and willing to invest the time and effort to become good at it, then get yourself a star tipped tuning hammer and some mutes (eBay will do) and start to see what you can do to make your piano sound better. Begin by getting the whine out of individual notes by tuning the strings to each other. Search out the "Every which way you can" tuning article by Kent Swafford on your favorite search engine for an introduction to aural tuning. If you're inclined to start out with an electronic tuning aid, check out Tunelab Pro - a free, fully functional demo is available for download to your laptop. Remember, however, that an electronic aid only shows you whether you've hit your target for any given string. Learning how to finess the physical motions of tuning so that the string stays on target for more than a few minutes is another process altogether. If your first couple of forays into trying to tune don't drive you around the bend, then consider finding a qualified piano technician who would be willing to provide lessons for a fee. If your interest holds up, investigate the resources for learning that are available through the Piano Technicians Guild. Their source books and monthly journals are second to none, but unless you are committed enough to the process to become an associate member, the non-member prices for materials are pretty high. "Piano Servicing" by Reblitz is another excellent source of knowledge. It might be in your local library.
Mar 15, 2009 | Music
14 people viewed this question
k24674
jasbo
jasbo
