Question about Samsung Washing Machines
NEC NW425 washing machine - Drain Filter pops off and the water gushes out
I have a NEC NW425 and the Drain Filter on the back at the bottom falls out and water gushes everywhere...whats happend? Help!??!
eagle338
  • 4889 Answers
SOURCE: Miele leak when switched on for wash, from filter unit front LHS bottom of machince
The leaks in a washing machine could be coming from many different places in the washer.
The first place you need to check is behind the washer, check the two fill hoses and the water mixing valve.
The next thing to do is to remove the front panel, set the washer on the regular cycle and turn it on to start filling.
Use a drop light and check all the hoses under the washer as the washer is filling. Make sure to keep your hands away from any moving parts.
If the hoses are ok, check the pump for leaks. When the bearings in the pump wear out, that is when the pump will get noisy and that could cause your Maytag top load washing machine water leaks.
Another place that the washer could leak water from, is the stem & seal on the holding tank. When washer leaks water from the stem & seal, the water leaks down the center of the transmission.
When the stem & seal need to be replace, the tub bearing has to be replace at the same time. This is an expensive repair if you have to pay someone to do it. If you do it yourself it will cost you about $110
Posted on Aug 21, 2008
SOURCE: my washing machine is leaking water everywhere when rinsing
you are over filling it!!!!!!!!!!!!!!!!!!!! when you use the rinse cycle it just fills the washer up to get all the soap out of the clothes. try just rinsing less clothes then usual. if that is not the problem then on the bottom of your washer is either rusted out or there is a rubber seal that could be over used!
let me know if that helped at all
zac
Posted on Oct 31, 2008
SOURCE: maytag top load washing machine leaking water from bottom
The machine is leaking water from the bottom, I think the leak is in the area near where the motor is mounted. Before we noticed the water comes from underneath the washer, we smelled like burning rubber.
Al Bana
Posted on Jun 30, 2009
  • 25 Answers
SOURCE: beko washing machine wont drain or spin water stays in drum
the pump itself could be blocked or broken check inside pump first for any obstructions
Posted on Jul 16, 2009
  • 3741 Answers
SOURCE: washing machine will not drain. water wont drain
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Aug 20, 2009
The city turned off the water to fix a main line and then turned the water back on. The first time I started the washer after this happened, I heard a loud pop noise and the water began gushing into the...
After repairing the pipeline it's inevitable that some debris/stones/cement etc. would find it's way into your machine. Even though there is (or should be) a filter in the water input hose, I'd guess that the water pressure was so high that some debris damaged the electrically operated solenoid valve which controls the water input flow. A mechanical problem then, with possibly some associated electrical fault. If you can get the machine out, I suggest unscrewing the inlet hose and having a look at the valve - they're usually easy to get to. But please DISCONNECT THE ELECTRICAL SUPPLY AND WATER first.
May 25, 2014 | Asko W6661 Front Load Washer
The drain pump will not shut off and door remains locked
Clean the drain pump while the machine is off. There is a small door on the bottom front panel of the machine. Open this. You will see a jar cover like thing that you can unscrew. Unscrew this. A lot of water will gush out.... be careful..... Clean this and put the filter and cap back. If same thing happens again when you run the machine, you will have to replace the drain pump. Chances are, you are trying to run a 50 hertz machine on a 60 hertz line.
Jan 10, 2014 | Maytag MHWZ400T Front Load Washer
Avanti w797 does not drain. impeller keeps falling off.
Go to the following link:
http://www.avantiproducts.com/products/id/489
at the bottom of the page, click on the pdf "parts and accessories"
Nov 24, 2013 | Avanti W797 12 lbs Top Load Washer - White
Our LG WD1438RD washer/dryer is not drying properly and the the valve at the bottom gushes with water every time it is opened.
I am assuming that 'the valve at the bottom gushes with water every time it is opened' refers not to a valve but to the cover behind which is the drain filter and drain motor!
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside. The dryer will not stand a chance of removing all of this water
Here are my complete, general guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Apr 29, 2011 | LG Washing Machines
Washer will not drain TB displayed on panel any suggestions
Check pump filter. I have had this twice on my indesit washing machine. You have to take the front cover off the bottom and then unscrew the filter to check it. Be careful as it will gush with water if the drum isn't drained.
Check the drain pipe for blockage by disconnecting far end of it and lowering to floor level (in a bowl). If no blockage then water should drain out of the drum by gravity.
Apr 03, 2011 | Washing Machines
A load of wash got "stuck" at 22 minutes left on the wash cycle. I turned off the machine. I turned it back on. Now the door is locked. How can I unlock the door and restart the machine?
Try starting a cycle and then cancelling it. Could also be problem draining. Check pump filter. I have had this twice on my indesit washing machine. You have to take the front cover off the bottom and then unscrew the filter to check it. Be careful as it will gush with water if the drum isn't drained.
My Whirlpool washing machine has failed to rinse and spin due to the 'clean pump' light being on. Any advice on how to clean the pump? Thank you.
Apr 03, 2011 | Whirlpool Washing Machines
Wont drain the indicator says the hose or filter is clogged
You can drain it manually with the little trap at the bottom of the washer and verify if there is anything in that trap. Make sure you have a bucket or something underneath because water will gush out.
Mar 15, 2011 | LG WM2688HWM TROMM SteamWasher
My Zanussi ZWF1658W washing mashine will not spin and drain the water it has a E20 error message on the display
I believe E20 is a blocked filter.
There should be a small door on the front of the machine almost at floor level.
BECAUSE THE MACHINE IS, I PRESUME FULL..... do this:
Unplug from mains
Tip machine backwards at about 45% so the water is not going to come gushing out of the filter when you remove it
Open the little door
remove and clean the filter
replace it
close door
put machine flat on floor agin
plug back in
start a cycle
Pray
Feb 26, 2011 | Washing Machines
How do you clean pump on whirlpool. 6th sense
Hi
On the bottom right corner of the machine you will have a drain filter.
Flip open the door. It opens vertically from top down.
Please note if your pump is blocked there will be water in the machine which has not drained out. When you twist open the filter anti-clock wise, all the water will gush out. Be prepared for this with towls and mopps. Also open the filter dial, slightly at first and only allow the water to trickle out at first. Once the water is all out, open and pull out the filter. Clean out the flilter and the cavity. Look into the cavity with a torch and make sure everything is clear.
Put back the filter.
Start your machine on the "Drain" cycle only. Check to see if you can hear the water pump working. If there is no noise, then the pump needs further investigation. It may even be faulty.
Oct 26, 2009 | Fisher and Paykel Washing Machines
Washing Machines Logo
22 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
