Question about Carrier Heating & Cooling
Error code EF
48000BTU CARRIER CASSETTE UNIT AIR CONDITIONER SHOWING EF ERROR CODE
burzerko
  • 254 Answers
SOURCE: air-conditioning; error code: 425
Try Samsung.com
Posted on May 30, 2008
  • 400 Answers
SOURCE: LG Inverter Air Conditioner showing CH 02 what can I do?
The model number would be on the right hand side of the outdoor unit and same on the indoor unit if it is a midwall split. If it is a flat cassette cieling type you may need to open the grill, which is simply two little levers either side of the grill, and the grill will swing open. Without the model number it is difficult to give accurate info. However, I can offer the following. One, check the condensate drain. You can just blow into the drain pipe from the outside and this sometimes clears clogged mud in the drainpan. Or two, error reading can also come from phase failure (in the case of a three phase unit) or power related problem. This can be solved by switching off the mains and then switching on again to reset. If you have a phase failure you would need an electrician to confirm that the power supply is good. Unless you have a volt meter.
Posted on Mar 04, 2009
rylee_smith
  • 8619 Answers
SOURCE: E2 error code on Haier cprd12xh7 portable air conditioner
Hi! You need to check pump filter. It could be jammed with a coin or hair clip. Now take the machine outside and empty it then lay it on its side and you can access the pump. Take it off, stand up the machine and pour hot water into the soap draw and check water should run out of bottom freely taking any fluff or bits with it. Now take apart the pump and clean it and dry all components before re-assembly. If the machine still doesn?t work then you need to replace the pump. Please do rate this solution as FixYa and revert for further assistance. Thanks Rylee
Posted on Jun 13, 2009
SOURCE: Air Conditioner Error code?
I have a portable air conditioner by Airlux and todat an error code is on the display reading E5. What does this mean and how can it be fixed? thx
Posted on Jul 08, 2010
SOURCE: E4 code is showing on my GE room air conditioner APE07AHM1
There is a water holding tank on the right lower side (when u are looking at the front), empty it and the unit comes back on.
Posted on Jul 27, 2010
Tip
CARRIER WINDOW ELECTRONIC CONTROL
CONTROL PANEL ERROR CODE
PROBLEM
REMEDY
E4
Thermistor problem
Shutdown unit and restart
E3
Unrecoverable of E2RAM data
Shutdown and unit and restart
E2
Loss or corruption of stored data
Using remote control go to Cool mode and shutdown the system, and then restart.
E1
Code validation check fail
Shutdown and unit and restart.
FL
Filter check warning
Press the “MODE” and (DOWN) “▼” buttons together until error code disappear.
Note: If the problem persist replacement of control board is needed.
-Push arrow up and arrow down together for 5sec. the room temp. will show.
on Mar 02, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
CARRIER TRANSICOLD A/C SYSTEM
I can find no A27 fault code for this unit, what is it doing? You can call carrier and ask for the definition, I think they will give it to you, just have the specific model number in hand when you contact them.
Aug 18, 2016 | Carrier Transicold Division Heat/cool...
WHAT IS FAULT CODE 00 01 Ad on Teco LU160DHRA1 Air Con
Carrier Split Air Conditioner Error Codes - AC Error Code
acerrorcode.com/carrier-split-air-conditioner-error-codes.html
Jan 25, 2015 - REMOTE CONTROLLER FOR AIR CONDITIONER (SPLIT TYPE). Carrier Split Air Conditioner Error Codes. 00-01-02-03. 11-12-04-05.
Nov 25, 2015 | Heating & Cooling
Cf code error of carrier
description: cooling fail action is activated. Action: check compressor operation. turn off main power-restart the unit.
see more: Air Conditioning Fault Codes
Jun 09, 2014 | Carrier 38CKC036 Air Conditioner
EE error code
try looking at the manual. you might be able to find the manual here.
if that doesnt help then try leaving a message on the site with the manual you need and they will upload it for you.
Jan 09, 2014 | Carrier Heating & Cooling
O general cassette type air conditioner error code
what is the problum in ac if showing thermostate clock error.we already we replaced main pcb and filter board .
Mar 22, 2013 | Heating & Cooling
Dear i have a floor mounted 48000btu airconditioner(westpoint) when we o it it displays E6 on the screen. i want to know what is the problem with it
see the user manual what does it say about Error E6. If you doing have a user manual send me the model number of the unit and brand and i'll see if i can help.
Aug 14, 2011 | Heating & Cooling
Model 30gx faults code
Hi, the indoor chiller unit blower section will have a sheet glued to a panel on the unit that will tell you where and what the code 302 means on the unit. Then you will be able to make the repairs you kneed.
Shastalaker7
PS the numbers above show that this is a 3 ton unit, 38CKC036. The error code more than likely will be 3 flashes from the board followed by 02 flashes. I may be wrong on that , so correct me if I am.
Mar 16, 2010 | Carrier 38CKC036 Air Conditioner
Carrier spit type air conditioner 5 blinks
Hi, you should have a error chart on one of the panels of the unit that will tell you what the 5 blinks mean. It will be pasted on the unit inside some where. Let me know what you find and we will go from there. Merry Christmas,
Shastalaker7
Dec 25, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
79 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
