Question about Dell Latitude E6330 Laptop Computer- 3rd gen Intel Core i5-3320M Processor 2.6GHz, 3M cache, Upgradable to Intel vPro technology
Dell e6330 when you plug in power cable its flashing on screen and not changing. Showing error saying power plag not compatible.
    Problem Solver:
  • 10 Answers
The Dell e6330 laptop requires a 63watt or higher power supply. You can search a marketplace of your choice (Amazon, e-bay, etc...) or google / bing "dell e6330 power supply" then compare the results with your power supply. If what you have is the same, then the power supply you have may be defective. If you have access to another Dell laptop (friend or co-worker) see if their power supply works with your laptop, and if your power supply works on their laptop. Do not force the connection into either laptop as you may damage the motherboard.
Posted on Mar 17, 2014
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
Aug 23, 2013 | Televison & Video
My laptop keeps saying pluged in not charging what can i do?
Yes, this is a common problem. Ther are two things that can cause this error.
1: The power supply is faulty, this is common, as they are used way more often than the typical power supply was intended.
2: The power jack inside your laptop could have broken solder on the power plug. This is also a coomon occurance, as laptops that are plugged in cause alot of stress on the plag jack on the laptop from moving the cord around. If you go to Fry's or Best Buy, they will test both the supply and the jack for you for free, and tell you which one is faulty. If it is the power supply, they may even supply you with a new one for free, as long as you are nice and polite to them. I was told this by a Best Buy tech.
Jan 23, 2011 | Dell Inspiron 1525 Notebook
Will not boot
Hi! try to check if the other memory module that you used is compatible with the system. Try to reseat ram again and check if it will help.try to power drain the system first before reseating ram(unplug power cable, press and hold power button and then plug the power cable back then restart the machine).Hope this helps.
May 26, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
When powering on the fans spin and yet I get no video. The LED under the PSU (CR9E1) flashes. What is the LED indicating?
This indicates power supply failure. PSU means Power Supply Unit.
Solution?
Replace the power supply.
MAKE SURE it is a compatible one!
What do I mean by that statement? In some years of Dell manufacturing, Dell made their computers "Proprietary".
This means only Dell parts could be used in a Dell computer.
The wires in the 20/24-pin ATX main (Motherboard) power cable, were put in different socket holes, than a standard 20/24-pin main power cable.
Yellow is 12 volts. Orange is 3.3 volts. Red is 5 volts. Black wires are Ground wires.
If an aftermarket power supply made by another manufacturer, were to be used in these type of computers, it will burn out the motherboard! Possibly the ram memory and processor also!
If you buy an aftermarket power supply, instead of a Dell unit, make SURE the colors of the wires are in the same place, as they are in the Dell 20/24-pin main power cable connector!
For more info about that last statement, I suggest you check out this page,
http://www.playtool.com/pages/psuconnectors/connectors.html
Apr 02, 2009 | Dell (E210882) Motherboard
LCD Monitor Blank/Non-Responsive - Dell E173FPC
Next thing I would check is the VGA cable between PC and monitor.
Make sure is in at both ends and if possible try another one.
Do the Dell Menus come up with no VGA cable plugged in? Is the light amber? Flashing or static?
Mar 18, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
2200 error on dell 962 all in one printer came on lighted screen. then i powered the printer off and it will not work at all. unlighted screen says power down error
1. Uninstall, and re-install the printer.
Else....
2. Error 2200 is a Scan Carrier Stall error... Maybe the scan carrier stalled during a scan job? Turn off the printer, wait a few seconds, and then turn on the printer.
else
3. If no result....Try this... turn off the printer then remove the power supply and press the power button for 15 seconds (it should clear info out of the printer). Then plug the power back in and press the power button.
Thanks for using FixYa - a FixYa rating is appreciated!!
Re-Post if additional help is required.
Jan 31, 2009 | Dell 962 Photo All-In-One InkJet Printer
Dell monitor problem
Disconnect and reconnect both ends of the video cable (while the computer and monitor are both off). Also disconnect and reconnect the power cable. Is the power cable plugged into the same surge protector as the computer? And also try a different outlet on the surge protector for the monitor.
Jul 22, 2008 | Dell E153FP 15" LCD Monitor
Powerbutton flashing yellow
If the main power button LED is flashing or solid yellow, this could indicate a hardware problem.
Was it running good before?
Are the diagnostic LED lights all green?
Here is what dell says:
If the power light is blinking amber  —
 The computer is receiving electrical power, but an internal power problem might exist.
  • Ensure that the voltage selection switch is set to match the AC power at your location (if applicable).
  • Ensure that the processor power cable is securely connected to the system board.
Do you remember what the BSOD said?
Oct 22, 2007 | Dell OptiPlex GX620 PC Desktop
Dell Latitude E6330 Laptop Computer- 3rd gen Intel Core i5-3320M Processor 2.6GHz, 3M cache, Upgradable to Intel vPro technology Logo
48 people viewed this question
Alun Cox
