Question about Canon imageRUNNER 5000 Copier
If ir5000 parralel port can be use for printing from computer
Because my ir5000 copier doesnt have Lan capability and it has only have parralel port.
  • Anonymous May 11, 2010
    What is your question? It is not visible in the heading?
  • 1,555 Answers
If it has parallel port you must have connected it to your pc and would be using to give print cmd through pc. If not then you require installation cd to install printer driver. and enable file and printing sharing in your lan and you can give print cmd from any pc of your lan. What is your exact problem kindly let me know in detail so i can solve it.
Posted on Jun 14, 2009
Whether Canon IR5000 printer can be a tool, through the com settings (data). how do I to connect the cable to the machine copies com IR5000.butuh lan similar devices or other connector?
If I understand what you are ask???? You need to know where the ethernet cable goes in to the copier?? The conector is above the main power switch on the right side of the copier.... The print funcation is a option with a IR-5000...... Do you have a ether net PCB installed???? If you do not, you need to get a new boot rom & more ram & the ether port and lastly, you need to have your hard drive flashed to print...... Good Luck
May 18, 2011 | Canon imageRUNNER 5000 Copier
Can I do network scanning with hp laser jet 3055 printer
Yes you can print, fax & scan with HP Laser jet All-in-one through LAN port (wired or wireless). Un-install and re-Install driver and Check "Extended Capabilities" when prompted.
Feb 16, 2011 | HP LaserJet 3055 All-In-One Printer
User manual or User Guide of iR325s and iR5000/6000
give me your email and ill try to get some manual for you
Mar 11, 2010 | Canon imageRUNNER 5000 Copier
Reset password
you will need a dongle that plugs into your parralel port that will allow you to reset the bios password
you can find diagrams on the net of how to create a dongle for the password reset and the plugs are available from any good electronics supplies store
Regards AL "Alstech"
May 25, 2009 | Toshiba Portege 7200CT - PIII 600 MHz...
IR5000 bloque
this is a code for detection of no or faulty charge to the drum open front door remove toner hopper take out primary charge unit see if any wires are broke on grid , then see if the wires underneath the grid are still there... if all seems ok gently clean the grid with cloth and windex then clean wires underneath dont break grid wires . put it back in let me know
Dec 23, 2008 | Canon imageRUNNER 8500 Copier
Printing from PC to Copier with USB cable
The drivers might have a tough time recognizing a 250 as a usb device on your computer. There wasn't a USB interface created as an option on your copier. Does your copier have a network adaptor on it?
One idea that will work on your copier is a parallel print server either wired or wireless. I've done this for a few of my 220/250 customers.
Nov 05, 2008 | Ricoh Aficio 250 Copier
Cant print from pc
I was using a parralell port i ended up removing the network card and that solved my problem
Aug 11, 2008 | Tally Line Matrix T6215 Printer
Scan to e-mail using Canon ir5000
cant be done with the ir5000s, only the ir5000i. The 5000s only does whats called "pull scanning", where you put the document on the copier and then go to your computer and use an application to "pull" the scan from the copier to your desktop. You can then attach the image to an email and send it that way.
Jul 18, 2008 | Canon imageRUNNER 5000 Copier
What DHCP capability does the P310 support?
The Prestige 310 supports DHCP client on the WAN port and DHCP server on the LAN port. The Prestige's DHCP client allows it to get the Internet IP address from ISP automatically. The Prestige's DHCP server allows it to automatically assign IP and DNS addresses to the clients on the local LAN.
Feb 19, 2006 | Zyxel Prestige 310 (AM406100) Router
Canon imageRUNNER 5000 Copier Logo
192 people viewed this question
old marine
old marine
