Question about Ryobi Garden
Aeg ls 107 schemi have put oil in ..plug in motor is working but chain is not going round ..never used one before please advise thank you
    Sergeant:
  • 337 Answers
Jayne you might have the cutting break engaged. The black paddle at the front of the engine try pulling it back until it clicks. If this is ok check that the chain is on the sprockets behind the clutch and this may help.
Posted on Mar 19, 2014
5 Suggested Answers
  • 76 Answers
SOURCE: please advise oil/petrol ratio...air gap ...plug
Hi
follow the link there are several manuals there for Echo chain saws
http://lawnandgarden.owneriq.net/manuals/mfg/echo/echo_chainsaw_product_list.html
http://www.echo-usa.com/pdf/documentation/CS300034003450efT1E_060402_1.pdf
on page 4 it says the types of oil and petrol
hope it helps
appreciate some rating form you.
thanks
Posted on Jul 18, 2009
  • 4088 Answers
SOURCE: Relatively new (used once) 45cc petrol chainsaw
Make sure the chain oil is reaching the chain. Can you turn the chain by hand fairly easily? If not, then the chain tension should be adjusted--loosen the drive cover fasteners enough to allow the bar to move up and down somewhat. Turn the chain adjuster screw CCW so that the chain can be moved by hand, but the chain should not droop from the lower bar edge. Re-tighten the cover fasteners and recheck the chain tension. If ok, try to run the saw again--it should run at full speed, 4-stroking lightly, but immediately 2-stroking when cutting. Make sure the fuel mix is fresh using a modern synthetic saw oil and shaking the container thoroughly each time just before filling the tank to prevent oil starvation. Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other damage. Hope that some of this helps!
Posted on Jan 04, 2011
hunter19_46m
  • 7482 Answers
SOURCE: what kind of motor oil
Hi justariblake...
You did not say if your chain saw was 2 or 4 cycle...
If it is 2 cycle...you will mix 2 cylce oil with gas at a ratio of 50:1...one pint 2 cycle oil per 6 gallons of gasoline.
If it is 4 cycle then you will use 10w30
On the bar and chain you will use bar and chain oil (a special oil made for chain saws)
Please take time to rate me
Posted on Aug 20, 2011
  • 2239 Answers
SOURCE: motor runs but chain is static can get it to go if
Clutch slipping due to wear, or the sproket teeth have worn to the point that it is slipping in the drive links of the chain, i have seen the teeth/spline on the sprocket drum become unbonded, so the drum tuns but the teeth/rim does not.
Posted on Oct 11, 2011
Florabest fks 2200 b1.advise which kind of oil required
The oil is for the lubrication of the chain. You can purchase chainsaw chain oil in a hardware store, Home Depot, Lowes, etc. 30 weight engine oil can be used, but the chain oil has special additives for the oil to adhere to the chain, so I would recommend using the chain oil. It can be purchase in one gallon size.
May 26, 2014 | Computers & Internet
Audi a4 alt motor sounds like running on 3 cylinders
Robert your going have to check the oil pressure the oil pumps on these engines tend to let go. What happens the key way that drives the gear strips and at low rpms it doesn't pump oil to the top of the motor but when you rev it the gear spins a little faster that's why it makes less noise you will have to replace the oil pump. As for the missing the hydrolic lifters are no working properly because of the low oil pressure.
Jan 31, 2014 | 2006 Audi A4 2.0
Hi Where can I buy chainsaw oil ? - I tried homebase ... or will ordinary 3 in 1 oil be OK ? Dan
Home depot,lows any hardware store,call around first and if you mean bar oil 30 weight oil non detergent oil will work just fine.3 in one oil will burn the bar and chain because it's to light.Tighten chain so you can pull chain 1/8 inch from bottom of bar then pull spark plug cover off to the side and screw driver cross ways to pull chain to check for binding.Please use gloves for this.I have someone hold saw or sit on the motor after I sharpen the chain.Stay away from the end of the bar cause that's where kickbacks happen.Keep the saw off to the side of your body when cutting.One last thing when chain is sharp big chips,dull sawdust until you learn how to sharpen best let saw shop do it for you.
Thank You for choosing FixYa.com.......................Darryel
Jul 26, 2011 | Homelite ZR10926 16 Chain Saw
AEG oko-lavamat 72600 C2 error code, what does this mean please? Thanks
'C2' for AEG washers is reporting a 'pump blockage'.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 12, 2011 | AEG Lavamat 72640 Front Load Washer
OIL LEAK & COIL PROBLEMS-, 2004 lincoln LS 6 CYL. HAVE HAD OIL LEAKS SINCE NEW, DEALER FINALLY FIXED THEM AFTER I POINTED OUT THAT I NOTICED THE PVC VALVE TUBE LEAKING. I WAS THEN ADVISED THAT IT WAS A...
The oil leak will only cause a COP Coil Misfire---IF,the valve cover O'Ring is leaking oil,onto the spark plug.
If you have a PO304 Code with the check engine MIL Light on,then replace the COP Coil on #4.
Please DO NOT GO TO A DEALER. It is a WASTE OF MONEY
A 12 year old could change a coil, on your LS
All you need is a 7mm socket and wrench,for the coil cover and the one coil screw.
I just did one on my 2004 LS V8 in Feb. It was $59.00 at the local auto parts store
I don't dislike dealers,there is just no reason to go there ,except to buy parts,and only when the parts are dealer only.
Any repair shop can work on any vehicle.
If you ever have issues and you will have lots,I have all the shop manuals and wiring diagrams and Emission Diagnostic manual
May 13, 2010 | 2004 Lincoln LS
1997 Lexus LS 400 --Fan blower not getting voltage or signal from heater relay. (actually module and fan not seeing voltage). Without a scan tool, I cant read the computers' would be sine wave. Ive removed...
Change the fan resistor it should be located under dash near the glove box ther's a rectangular electrical plug going to it it should be located somewhere on the heater box. These usually go bad because of the constant condensation and temp. changes present.
Jul 24, 2009 | 1997 Lexus LS 400
Please advise oil/petrol ratio...air gap ...plug
Hi
hope it helps
thanks
Jul 18, 2009 | Echo Garden
CA Error Code - AEG OKO LAVAMAT 86700
c-a error message poped-up.washer stop working.............please help.
Sep 15, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Engine smoke
hi,i heard of this potential problem when asking an online lexus mecanic,about a p steering pump leak,he asked if i hald any white smoke from the tailpipe i didnt,but he said sometimes the power steering fluid can be sucked up through a tube or such and you could see white smoke from your car.maybe ask this question to a mecanic.
Jul 29, 2008 | 1995 Lexus LS 400
Garden Logo
27 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
