Usb not recognized - Office Equipment & Supplies
USB DEVICE NOT RECOGNIZED One of the USB devices
This may cause if your USB port is out of order. Or your pen drive is not in good condition.
Think this is helpful !
Aug 11, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Tip
How To Fix Usb Device Not Recognized in Windows
Sometimes, when you plug a USB device to your computer you may receive a Usb Device not recognized or usb port not working pop up message. If your USB device is not detected, then we will show you how you can troubleshoot usb not recognized error.
Follow Quick Steps To Resolve Usb Not Recognized Error Windows:
Press "Windows" + "R",a run window will open
In the "Open" box of the run window type "devmgmt.msc" and press "Enter"
This will open theDevice manager
Click on the arrow besides "Universal Serial Bus controllers"
Right click on each USB port and then click on "Uninstall"
Restart your computer and wait for Windows to re-installs USB controllers.
Try to connect yourUSB deviceagain.
How To Fix Usb Device Not Recognized In Windows 7 8 1
on Jan 28, 2015 | Computers & Internet
I have problem with my usb not recognized.
go to the website and locate where you can download drivers/software, once you have done that look for the specific area and download the driver, or you can go to device manager and make sure the driver is working properly
Jul 16, 2010 | Dell Inspiron 8200 Notebook
Usb flash memory not recognize and become hot temperature malfunctioned
At first attempt in plug in your usb flash memory didn't recognized you may plug out. And plug in again until it recognized you may see that theres an icon in the task bar at right below. Thanx
May 09, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Usb device not recognized
I suggest you power off you printer and restart it after some minutes.
You could try another usb to see if it will recognize it.
If the usb is not still recognized, I advice you uninstall the printer driver on your system and reinstall after a while.
If it is not still recognizing it, it means the usb might be bad, you may need to get another usb.
Take care.
Apr 19, 2010 | HP DeskJet F380 All-In-One Printer
You mentioned that you uninstalled the unknown device from the Device manager. If you uninstall it then connected your usb flash drive you will see an error again on your device manager. This means that the driver for your usb port is not properly installed.
To install it, visit dell website, look for the model of your machine and locate the driver, download it then install from your machine.
Jun 02, 2009 | Dell Inspiron 6400 Notebook
USB device not recognized
This solution worked for me when I got the USB device not recognized message:
http://www.infobarrel.com/USB_Port_Repair
It can be quite frustrating. I've heard that older computers are more likely to have the USB device not recognized message.
May 31, 2009 | Dell Inspiron 6400 Notebook
Usb is not recognizing plug-in
may the usb device in your bios is disable. you must enable the usb device in your bios to recgnice your usb. you must enter to the bios setup to config. the usb configuration.
Apr 30, 2009 | Computers & Internet
My computer dont recognized my mp3 m-230 what can i do ???
mostly, mp3 devices comes with a software.
if u have the software, and the usb dont recognize your mp3 device. most probably the problem is in you usb drive or usb connector.
Feb 27, 2009 | SanDisk Sansa m230 MP3 Player
Computer doesn't recognize usb device...
do not use Front usb connector. put your device in backside of CPU usb port. it wil work fine.
Mar 05, 2008 | Belkin BLKF5U201 USB Peripheral...
15 people viewed this question
jasbo
jasbo
