Question about Baumatic Refrigerators
BAUMATIC BR27B FRIDGE FREEZER, freezer is only -8, fridge is working perfectly
SOURCE: Fridge of Fridge/Freezer keeps freezing contents.
all the food going to ice temperture at 2
Posted on Nov 25, 2007
  • 90 Answers
SOURCE: FRIDGE/FREEZER MODEL: SR42NMB Multi Frost
You have a clogged defrost drain tube. best way is to thaw unit out. Your vents are being blocked so no air flow is pushed down.
Posted on Jan 05, 2008
Trifect7
  • 57 Answers
SOURCE: refridgerator not very cold
It could be some many things, to save time let me give you this check list:
Do what you feel qualified to do.
If you found this helpful please Vote. Good Luck!
Posted on Mar 04, 2008
SOURCE: FREEZER WORKING - FRIDGE NOT WORKING
Ok, got it sussed! [well here's what I did anyway]...
Quite simply, I turned off the fridge-freezer at the mains overnight and in the morning, broke and chucked out the ice chunks that had lined up in the bottom of the freezer section and then turned it back on. I returned that night to see that it was working fine again! Hallelujah, I got my fridge back!!
So it seems that all it needed was a good long defrost, so far so good! I hope this solves your problem.
Posted on Jul 18, 2008
  • 6 Answers
SOURCE: Fridge freezer over heating and is not cooling fridge section
It is normal for the middle strip to be hot. Did you check the temp setting in the fridge section?
Also - you might check for blockage in the bottom. Excessive dirt/dog hair can block the air flow.
Good luck
Posted on Jan 18, 2009
Fridge temperature too warm
As you know this is very large fridge and try to find service manual for help and solve problem with using deduction method of step by step trouble shooting and eliminate possibilities
This might be compressor problem or evaporator problem or main controller problem or sensors or etc.
Baumatic TITAN 5 Stainless steel 4 door 607 Litre Frost Free Fridge/Freezer
Technical Details :
* Total gross/net capacity: 607/557 litres
* Gross capacity fridge/freezer: 428/179 litres
* Net capacity fridge/freezer: 397/160 litres
* Energy efficiency class:
Dec 06, 2013 | Refrigerators
New integrated baumatic fridge freezer installed yesterday but the door sensor alarm keeping going off..door is def shut. As baumatic gone into administration has anyone got any ideas plse?
It's telling you it has a fault, you have to find out who is doing the warranty work for Baumatic now, by law they have to honor the warranty.
Nov 30, 2013 | Baumatic Refrigerators
I have a Baumatic fridge/freezer the fridge is not cold even on maximum setting the model number is BRB2713 please can you suggest what the problem might be
First check the simple things. Check to condenser grill and make sure the air flow is not blocked by lint, etc. And then make sure that nothing is blocking the cooling tubes between the freezer and refrigerator. I think the Baumatic has a fan pulling the cold air up from the freezer compartment into the fridge, if that isn't working, the freezer would be fine, but the fridge would be to warm.
Jun 03, 2011 | Baumatic BR22 8A Bottom Freezer...
Where can I get a replacement thermostat that iscompatible with the one in my Baumatic bf230ss fridge/freezer?
Locate the model and serial number on the fridge/freezer write it down then look in the yellow pages for a refridgeration supply business in your area,they should be able to help you obtain a replacement thermostat.
Sep 21, 2009 | Baumatic BF230 Top Freezer Refrigerator
My freezer is working perfectly but the fridge is not
The channel in the back were the cool air comes down from the freezer to the fridge may be iced up. Try defrosting the fridge/freezer for much longer than usual, all day if necessary.
Aug 30, 2009 | LG LRTP1231W Top Freezer Refrigerator
Freezer building up lots of frost, but on lowest setting.
FREEZERS SHOULD BE TEMP AT O /REFRIGERATOR SHOULD BE 40/FOR PERFECT OPERATION.1ST IS THE FAN RUNNING IN THE FREEZER/IF YES UNPLUG FOR 6-8 HOURS AND RETRY/IF NO UNPLUG THE FRIDGE AND REMOVE THE BACK PANEL OF THE FREEZER MAKE SURE THE FAN IS PLUGGED IN.IF SO PLUG IN THE FRIDGE AND SEE IF THE FAN IS TURNING.IF NOT YOU NEED A NEW FAN IF THE FRIDGE IS NEW MAKE THEM BRING YOU A REPLACEMENT FOR FREE.
Jan 16, 2009 | Jenn-Air JCB2059G Bottom Freezer...
Baumatic fridge freezer
It's still under guarantee. Take it back now.
Aug 25, 2008 | Baumatic 23 in. BDW5 Built-in Dishwasher
I have a Baumatic American style fridge freezer. Problem is freezer door comes open when fridge door is shoot...
Re-level your unit and tilt it just a little toward the back. When you close the refrigerator door you in effect cause a compression affect which pushes the freezer door momentarily open. If it is leveled so that it is tilted toward the back the door would re-close under its own weight.
Jun 02, 2008 | Baumatic Refrigerators
Baumatic Fridge Freezer
Technical advice Phone for Baumatic +44 118 933 6933
E-mail "technical@baumatic.co.uk"
May 31, 2008 | Refrigerators
Refrigerators Logo
42 people viewed this question
Top Baumatic Refrigerators Experts
Sal DeAngelo
Colin Stickland
Colin Stickland
Electric Dime
Electric Dime
Are you a Baumatic Refrigerator Expert? Answer questions, earn points and help others
