Question about Garden
HARD STARTING ON COMMON RAIL - Garden
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,917 Answers
Check the compression you want a 100 lbs it takes 90 lbs to start any small engine if it is at 90 then you need valve job are ring job think before you do this maybe need new lawnmower
Posted on Jul 07, 2014
Toyota d4d 2.5diesel hardstarting?
reasons for hard starting are
air in the system
slow cranking speed
faulty injectors
faulty high pressure pump
blocked fuel filters
glow plugs not working
blocked air filter
if common rail unit , the fuel control module
Mar 21, 2018 | Toyota Cars & Trucks
2008 TOYOTA D4D HARD STARTING WHEM HOT
Check coolant level,could be a thermostat.
Jun 13, 2016 | Toyota Cars & Trucks
WHY DOES MY ISUZU 4HL1 ENGINE HAVE A HARD START ALWAYS?
no car stated, huge NPR truck no less.
no year stated
so no free book information on that engine,.
big diesel. 4HL1, no dash letter?
compression at spec.?
glow plugs work.,
filters clean. water in fuel,
does test fuel (spray'd) help? ???
injection problems
lack of startup air.(filter)
The 4HL1 is a common rail direct injection OHC 16V high-pressure fuel injection system diesel engine of 4.777 L capacity with electronic control system. Peak torque is 333 Nm, peak power is 140 PS (103 kW) at 3,000 rpm. Maximum torque is (34.0 kg m)'/1,500 rpm. Bore is 115 mm, stroke is 115 mm.
The 4HL1-N is a common rail direct injection OHC 16V high-pressure fuel injection system diesel engine of 4.777 L capacity with electronic control system. Peak torque is 333 Nm, peak power is 131 PS (96 kW) at 3,000 rpm. Maximum Torque is (34.0 kg m)'/1,500 rpm. Bore is 115 mm, stroke is 115 mm.
The 4HL1-TC is a common rail direct injection OHC 16 V turbocharged and intercooled high-pressure fuel injection system engine of 4.777 L capacity with electronic control system. Peak torque is 425 Nm, peak power is 160 PS (118 kW) at 2,700 rpm. Maximum torque is (43.3 kg m)'/1,500 rpm. Bore is 115 mm, stroke is 115 mm.
The 4HL1-TCS is a common rail direct injection OHC 16 V turbocharged and intercooled high-pressure fuel injection system diesel engine of 4.777 L capacity with electronic control system. Peak torque is 500 Nm, peak power is 179 PS (132 kW) at 2,700 rpm. Maximum torque is (51.0 kg m)'/1,500 rpm. Bore is 115 mm, stroke is 115 mm.
May 31, 2016 | Isuzu Cars & Trucks
I have a Honda crv (2007) starts first time when engine is cold but when it's hot it will crank but takes time to start. Was told it was low pressure caused by either the common rail or pressure...
Not really. If the problem was low fuel pressure it should take a long time to start cold also. Usually hard starting when the engine is warmed up is a coil or other electrical problem.
You can check fuel pressure before and after cranking with a special gauge hooked up to the port on the fuel rail.
Jul 02, 2013 | Cars & Trucks
I mean 6-7 times to start in summer
Some of your question or post must have got cut off...Hard starting? Check fuel pressure at the fuel rail. How long since your last gas filter change? How long since you changed spark plugs? If they are old and worn, it may be hard starting. Also check your air filter, and if dirty, replace it.
Good luck.
May 14, 2012 | 2000 Chevrolet Silverado 1500
I have a 2003 Hyundai Starex, CRDi. The problem is hard starting, even if the unit is already warm. The mechanic already replaced the fuel filter with new one, new common rail, and fuel pump (however not...
Instant starting when a volatile liquid is sprayed into the intake indicates three possibilities.
1. the compression pressure is low.
2. the preheat system (if fitted) is defective.
3. the injector spray patterns are defective.
I was once presented with a Renault diesel that was a bad starter. A so-called diesel specialist told me bad injectors would never affect starting but I went ahead and removed them and sent them to be tested and repaired - the result was an instant return to normality.
May 29, 2017 | Computers & Internet
Hi Gurus, My 4JX1 engine is vibrating on idle. Idle speed is about 750rpm. At hgher speed the engine runs smooth. The problem is the engine dies off in the middle of driving. Sometimes it will start again...
Are you running the recommended oil grade? As the injection system is operated by engine oil pressure using the wrong oil grade can prevent your car from starting, running smooth or hard starting! Ideally they require a 5W30 oil grade. Idle speed is controlled by the engine control unit! It's a common rail diesel engine so there's nothing to adjust! The Camshaft position sensor could also possibly be intermittently faulting causing similar symptoms! It's located on the front of the cambelt cover(gray coloured sensor)
Oct 08, 2010 | Isuzu Trooper Cars & Trucks
Mondeo 55 plate starting problems when the engine is warm
Hi Warren,,
These cars are fitted with a Delphi common rail system that is known for various faults including yours, you need to have a sealed rail test done on the injectors as they are probably leaking off to much causing low pressure in the common rail,when the car is warm,they also suffer with injector code loss ,no reason they get confused this normally gives poor performance and high fuel consumption ,if the injectors are fine check the system for air leaks in the fuel supply pipes and check the leak off pipes for leaks,even the smallest leak can let air in,if the engine light has come on get the codes read ,
Darren DCS
Aug 12, 2009 | 2005 Ford Focus
2002 chevy Blazer hard starting did change fuel pressure regulator and fuel filter when we spray starting fluid in throttle body it will start.
replace the fuel injectors, that is the likely cause......
to test the injector, take the power clip off the top of the injector, take one wire and ground it to the body of the car, and another form the battery, to the other post on the injector, if you do not hear a pulsing sound coming from the injector it is bad, if you do, then you have a wiring problem.
Nov 26, 2008 | 2002 Chevrolet Blazer
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
