Question about Whirlpool RBS305PDS Electric Single Oven
What does fP mean on a whirlpool accubake oven?
    Director Badge:
    Uploaded 100 video answers.
  • Whirlpool Master
  • 489 Answers
DO YOU MEAN "PF"? IF SO - THEN ITS POWER FAILURE.
Posted on Apr 27, 2014
aborcass
  • 2651 Answers
SOURCE: Whirlpool Gold Accubake oven
depress the broil button for 5 seconds it will revert back to Farenheit
Posted on Feb 24, 2008
Krazytech
  • 725 Answers
SOURCE: whirlpool accubake oven error code
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
It may just be a door switch
Posted on Jun 12, 2008
SOURCE: whirlpool accubake oven problem
I had the same problem and followed the process listed above....yes, I did unplug/turn off the circuit and am alive to share this update! Right off I noticed that the ribbon cable was loose. For those who have tinkered around with other electronics such as a PC, etc., note that this ribbon cable is not secured by the connector (atleast in my case). Reseated the cable and turned the power on. Voila- the bake option works. Tested it by turning it on for 20-30 seconds. Touched the bake element and got proof that it was working fine (via a singe of the ring finger ;-)).
About three minutes or so later, the display started to beep with an error code - E0 F2. A shorted keypad is what it stands for. The clock was still operable. I could still select the bake option, broil option, etc. Ran a test bake cycle but it turned off after a minute or so and started to display the E0 F2 code again.
Started the process all over ie turn power off, take panel off, reseat ribbon cable. Turn power on and test by holding the Cancel button for five seconds. Still displays the E0 F2 error. Waited for 10 minutes but this time no more beeping or error display. Ran a preheat cycle for 4+ minutes without any problems. The oven warms up and the bake element glows red. Hopefully, all is well. Will see what it does when we bake something the next time.
Thanks to PropHeadTwo and others for their contributions.
Posted on Dec 18, 2008
  • 22 Answers
SOURCE: whirlpool accubake oven door will
F5 fault codes are latch mechanism problems. One means the latch won't lock, the other means the latch won't unlock. Odd you're getting both...
Posted on Apr 25, 2009
blueextc3221
  • 15935 Answers
SOURCE: E2- F3 Error code, what does that mean??
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board.
If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe.
If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!^!^!
Posted on Sep 29, 2010
I have a whirlpool accubake wall unit oven Took out door to clean glass now I cannot put door back together
you have a couple of hinges you have to pull out at about 45 degrees then slide door down on them and shut door
May 05, 2016 | Whirlpool RBD245PRB 24-inch Double Wall...
I hav whirlpool accubake.oven wont stay lit.it ignites then flame goes right back out
Whirlpool oven won't light - Appliance Repair Forum
forum.appliancepartspros.com/oven.../225907-whirlpool-oven-wont-lig...
May 19, 2011 - 10 posts - ‎2 authors
I have a Whirlpool Accubake oven (SF362LXSS0) that doesn't seem to be consistently turning on, and the problem's getting worse. ... If I try to turn it on to bake, I hear several clicks, but not that "gas oven turning on" sound and no heat comes out (but a slight smell of gas is ... Whirlpool Gas Oven won't stay lit
1 post
Oct 25, 2012
whirlpool oven won't stay on
1 post
Aug 13, 2012
Whirlpool Gas Oven Will Not Stay Lit
Jun 20, 2012
whirlpool accubake oven will not stay lit
1 post
Nov 9, 2009
More results from forum.appliancepartspros.com
Whirlpool Accubake Model # GW395LEGQ4 - Oven won't Start ...
Dec 12, 2015 | Stoves Ovens
I have a whirlpool accubake duo, super capacity 465 and when I try to bake something the oven wont stay on...how do I get the oven to stay on
What do you mean that it wont stay on? Does it turn off and on during cooking? Does it just go off and wont come back on? The oven thermostat regulates the heat in the oven and the oven element and the oven indicator light will turn off and on during cooking. If it stayed on constantly on full oven element power everything would burn.
Mar 01, 2011 | Whirlpool Ovens
What does f5 mean on a whirlpool accubake oven?
It either means that the door lock is bad or there is a stuck key on the touch pad.
Jul 24, 2010 | Whirlpool RBS305PDS Electric Single Oven
Whirlpool Accubake instructions
I have lost my instruction manual and I need to know how to use the self-cleaning feature on my range
Oct 03, 2009 | Ovens
Whirlpool accubake rbd245pdb no power to control
Make sure there's power getting to your range, oven or cooktop. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
If all check out ok with all the above, replace the ERC
Jun 19, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Self cleaning oven wont work
On your model it should mean a defective door latch switch.
It will have to be replaced.
Feb 22, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool RBS305PDS Electric Single Oven Logo
71 people viewed this question
Top Whirlpool Ovens Experts
ashburton
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
