Question about HP Compaq nx5000 Notebook
Problem with the power switch /motherboard
Hi
my not been able to switch on my laptop, it is showing the charging light, but when i press the power button to switch it on, then the light goes off and starts blinking!!
the power light is not working, the laptop processor fan runs for 3-4 sec and then goes off
i dont know wat is the problem with it, i recharged my battery , bu tnothing happened, the problem is same!!!
pls help me
  • 3 more comments
  • rachit28 Oct 31, 2007
    it isnt working, i hv tried everything, removed the battery, checked the RAM, checked the video cable everything, m not able to get the solution...
  • tarin Dec 19, 2007
    Tried everything. Disassembled and reseated everything but still the problem is on. When I switch the power on, the fan starts running for almost 3 seconds.
    I only can start the laptop early in the morning, when it has been off the whole night. It turns on and works perfect. But when I switch off and try to restart again, it fails. Maybe a motherboard problem?
  • Anonymous Dec 22, 2007
    Hi;
    I Have same problem for HP NX5000 Laptop;
    After I pushed on the power button, fans started spinning and were active for a few seconds and laptop just turned itself off. The video never came on. I tried to power it on for a few times with the same result.
  • nabarunl Feb 02, 2008
    hi did anyine figure out the solution. i face same issue of laptop shutting down and nnot restarting for many tries. th eorange light flickers..fan is on a for a couple of seconds and it dies down..then it suddenly starts up at some moment...could it be a potential heat issue ?
  • Anonymous Mar 04, 2008
    hi guys, iam happy to hear all u hav got the same pronlem as i have. plz dont mind. earlier, when i press the power button fan spins for 3 to 5 seconds and yellow light blinks for a while and laptop is dead . if i keep on doing the same it works normally. but now it has completely stopped working.just spin the fan and dies out. is there any hp tech who can help us?
Had the same problem, Removed the Hard Disk, Battery, and DVD combo drive. Reconnected the Hard Drive, Connected the power cable and booted up fine. Whilst computer still on put back the battery and DVD combo drive. Worked perfectly since.
Posted on Nov 29, 2007
Your problem is that a video cable has to be reseated in the connector:
http://www.laptoprepair101.com/laptop/2006/07/05/laptop-turns-on-and-shuts-down/
Posted on Nov 08, 2007
Remove the battery, plug it in and and try to turn it on. If it turns on without the battery, the most probable cause is battery worn out.
Posted on Oct 30, 2007
I have a Toshiba satellite L655 - SW5096. went to turn it on but will not start. No fan, no screen. Only the power light indicator and a steady orange light . The orange light goes off if I remove the...
The orange light shows the battery is charging. It will turn green when the battery is fully charged. The white light shows there is power entering the computer.
The usual problem with a computer when there is no response to pressing the power button is that the motherboard has failed requiring the replacement of the motherboard.
If the computer is still under warranty there should be a free motherboard replacement, if not, and you are able to do the replacement, you can find motherboards for sale on various websites. Be aware that motherboard replacement for laptops can be expensive if done by computer repair shops.
Oct 20, 2013 | Intel Motherboard
Blackout
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
Apr 23, 2012 | ASUS Computers & Internet
Power light comes on but nothing happens
What type of laptop? What operating system?
Laptops don't boot for the following reasons: 1) Bad Power Cord. 2) Bad DC Power Jack where the power cord plugs into the laptop. 3) Static Charge Buildup. 4) Bad Motherboard.
The above 4 reasons are when you press the power button and absolutely nothing happens. You hear no fans running, no disk drive running, no one time clicking sound on the CD Drive and No light for a second or two when the CD drives click. In the case of a motherboard issue sometimes you will hear beep sounds or see blinking lights. Those beep sounds and blinking lights tells the technician what is going on with your motherboard and why it will not boot. If you see the blinking lights or hear beeps count them.
So you have a power light which means your power cord and dc power jack is good. So lets see if you have a static charge buildup.
Remove the Power Cord and the Battery from the laptop, then Press and Hold the Power Button for 30 seconds. After 30 seconds put the power cord back into the laptop, but leave the battery out. Press the power button to see if it boots. If it does you had a Static Charge Buildup and it's ok to put your battery back in. If it does not you more than likely have an issue with your motherboard.
Mar 22, 2012 | Computers & Internet
Acer 2480 2247 won't power up -no lights no nothing, pwr supply is not the problem,lid close switch isn't stuck ,pwr. on switch seems fine and power supply jack on motherboard is not broken
Remove the main battery and the power supply, allow several minutes to get rid of any residual charge, now plug the power supply adapter back in and press power "leave battery out" is there any change? if not! remove power supply, now! press and hold power for 60 seconds to reset the laptop. Next install main battery back in and the power supply adapter, power up! if no change, the motherboard is the problem.
Mar 07, 2011 | Acer TravelMate 2480-2779 Notebook
My Acer aspire 4935 is not recognizing the AC adapter. When ever I shutdown the system and connects the AC adapter, it works and the charging LED lights up. Once I press the power button to boot the...
Problem description:The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause:1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution:1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
http://www.chargerbuy.com/replacement-acer-aspire-9400-ac-adapter-19v-3-42a.html
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
Feb 09, 2011 | Acer Aspire 4730-4947 Notebook
Laptop won't switch on although blue power light on is showing power is getting to the machine
Check the power adaptor led is not flashing. Flashing Adaptor LED indicates fault with laptop charging circuit / powerboard
If it will not boot on battery, and you know the adaptor to be good, the issue lies with the motherboard.
Sometimes, removing the battery, and unplugging, pressing the power button and holding it for 30 secs, replacing the adaptor only will allow it to boot up, but this will only work if the motherboard is not damaged r the CPU fan has not failed.
Jan 27, 2011 | Toshiba Satellite P200-13Z Laptop AC Power...
I cannot switch on my laptop. it was working fine last night, but in the morning, my laptop refused to get switched on. nothing happens even if I press the on button, no blinking of anything, no booting,...
You might try to remove and reseat the battery. Jiggle the plug for your charger just to make sure that it can deliver charge to your computer.
You may be needing a new battery for your laptop, especially if the laptop seemed to require more frequent charging.
Look for guidance on your manufacturer's web site about care and charging of your laptop's battery.
Sep 06, 2010 | Computers & Internet
Presario v2000 Laptop dead.
Its may be the problem on ur psu or ur motherboard
Jul 28, 2010 | HP Compaq Presario V2000 Notebook
I have a Patriot 3070 laptop, when power supply is plugged in the charging light stays on for 10 seconds then goes out. Pressing the on button switches the ight on the keyboard (with the pic of a plug on...
10 seconds shows that one component from laptop's motherboard is defect. Try to remove RAM memory, harddisk and dvd (If available) and put them back one by one to see which component is defect.
Feb 05, 2018 | Computers & Internet
HP Compaq nx5000 Notebook Logo
291 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
