Question about Sony STR-DA2800ES 7.2 Ch. Home Theater AV Receiver
Str-da2800es has power shortage need the electrical map to fix it could you provide me with it
    Problem Solver:
  • 4 Answers
Go for Home Electric Generator and Power Stabilizer
Posted on Mar 21, 2014
Power voltage requirement
Wrong site. I fix home appliances, But you can buy them cheaper than I would fix them for.
Dec 26, 2015 | Cars & Trucks
Water leak into drivers' side
the rubber weather gasket around the door needs to be replaced its held in by adhesive then replace power window switch panel on door or clean the contacts on the switch after you take it out of the door
Feb 26, 2013 | 2005 Chevrolet Equinox
Power steering problem is hard and dont find the power steering pomp
These vehicles have electric power steering. There is an electric motor under the steering column that provides the power steering assist. GM also had a special policy coverage on this motor as it has been notorious for causing the problems you are describing. Read on:
Some customers of 2004-2007 model year Saturn ION vehicles, equipped with electric power steering, may experience a sudden loss of power steering assist, which could occur at any time while driving the vehicle. If the power steering assist is lost, a chime will be heard and the Message Center will display a "PWR STR" warning message. The vehicle can still be steered in a safe manner but will require greater driver effort at low vehicle speeds or when stopped. Typically, the next time the vehicle is started, the power steering assist will return and the "PWR STR" message would no longer be displayed..................
This special coverage covers the condition described above for a period of 10 years or 100,000 miles (160,000 km), whichever occurs first, from the date the vehicle was originally placed in service, regardless of ownership.
Retailers are to replace the power steering motor. The repairs will be made at no charge to the customer.
Aug 05, 2011 | 2004 Saturn ION
I have a Citizen C802DVD, that is dead, no power at all, what can be the problem? thanks for your help.
Instructions
    • 1. Press the power button on the TV and not the remote control. It is possible the remote control's batteries are dead. If the TV does turn on, you know you need to replace the remote's batteries.
    • 2 . Disconnect the power cable from the TV, then insert it into a different electrical outlet. On occasion outlets are damaged, and do not provide a power current. If this is the case, changing the electrical outlet connection corrects the problem.
    • 3 . Switch the television's input to a different connection. It may be possible you have the wrong input selected, causing the TV to give off a black screen.
    • 4 . Connect a different source device (such as a DVD player or cable receiver) to the television. If the source equipment is damaged, you will not receive an image from the hardware. If the TV still does not display an image, there is an electrical shortage in the interior of the TV. To see if there is any way to fix this issue, you need to take it into a local TV repair shop.
Feb 02, 2011 | Vizio 42 in. LCD TV
Tv powers up but will not turn on
A flat screen television is any TV with a flat glass front (instead of the older, rounded televisions). These televisions do not necessarily need to be thin--projection TVs have a flat screen but are still a foot or two deep. If you find your television does not power up properly, you need to troubleshoot the problem. The exact reason may vary, and hopefully you are able to correct the problem. (If the TV has shorted due to an electrical surge, you can't do anything about it).
Difficulty:Moderately Easy Instructions
    • Press the power button on the TV and not the remote control. It is possible the remote control's batteries are dead. If the TV does turn on, you know you need to replace the remote's batteries.
    • Disconnect the power cable from the TV, then insert it into a different electrical outlet. On occasion outlets are damaged, and do not provide a power current. If this is the case, changing the electrical outlet connection corrects the problem.
    • Switch the television's input to a different connection. It may be possible you have the wrong input selected, causing the TV to give off a black screen.
    • Connect a different source device (such as a DVD player or cable receiver) to the television. If the source equipment is damaged, you will not receive an image from the hardware. If the TV still does not display an image, there is an electrical shortage in the interior of the TV. To see if there is any way to fix this issue, you need to take it into a local TV repair shop.
Jan 09, 2011 | LG Televison & Video
Why does the water boiled in this kettle smell and taste chemically? Any boiled in a plastic kettle in my home is fine.
hello,
the chemical taste of smell from your kettle means that the element in the kettle which provide heat to boiled the water has gone bad due to over heating
this occur when there is shortage of water level in the kettle when the power supply is on
to fix up this problem of smell and chemical taste in your boiled water you will have to make a change of the element (heater)because it has gone bad you can get a replacement of it in the store .
thank you and thanks for using fixya.
Jun 01, 2010 | Morphy Richards 43072 Cordless Electric...
My Sony STR-DA4400ES turns off when their is a loud noise on tv. How do I fix this problem
disconnect battery-or electric power for one hour.
watch a clock in the kitchen.
Nov 04, 2009 | Sony STR-DA4400ES 7.1 Channels Receiver
Light blinking problem in LG 775N ( White ) 17'' CRT monitor
any shortage in secondry side of monitor ..
plz check shoting.
Feb 25, 2009 | Computers & Internet
Sony STR-DA2800ES 7.2 Ch. Home Theater AV Receiver Logo
54 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
