Question about Dishwashers
Whirlpool Clothes Dryer AWZ 121
My old dryer won't tumble. It WAS tumbling but just stopped suddenly. It cooled down & tumbled a few more times, so I think the belt is ok. It makes the noise you hear between the drum reversing directions. It just doesn't tumble. In the past 6 months, I've replaced the thermostat & element. I'm on the verge of buying another dryer.....but...Thanks for your help. Suzy
    Scholar:
  • 67 Answers
It sounds like it is the belt. When the dryer heats up the belt expands a little and when it gets wore out, the tensioner doesn't have enough spring to keep it tight. It might work a little when it's cold before the belt expands.
This belt should work for your dryer but verify the length.
http://www.amazon.com/Whirlpool-341241-Dryer-Drum-Belt/dp/B00DM8J15C/ref=sr_1_fkmr0_2?ie=UTF8&qid=1395071968&sr=8-2-fkmr0&keywords=whirlpool+awz121+belt
Here is a helpful Youtube video on how to do the repair.
http://www.youtube.com/watch?v=GzYmoS9brMY
Here is a link to the Service Manual
http://elektrotanya.com/whirlpool_awz121.pdf/download.html
The bottom of this link shows some typical ways a belt runs past a tension wheel and links for your dryer. If you replace yours I would recommend taking a couple pictures before removing the old one so you can refer to them when installing the new one.
http://www.repairclinic.com/Dryer-Belt-Diagrams
Posted on Mar 17, 2014
Testimonial: "Thanks so much for your excellent information. Unfortunately the video, really informative, isn't about my particular model which has the lint trap in the door, etc. Whirlpool AWZ 121 I'll see if I can find a video for that model Thanks again! :-)"
3 Suggested Answers
SOURCE: Servis Tumble Dryer
Sounds like the wheel at the back of drum where belt goes has come loose should be allan key screw/nut to tighten up again.
Hopefully that is the end of your worries.
                Mick
Posted on Oct 14, 2007
  • 97 Answers
SOURCE: dryer tumbles but does not heat. We replaced
is the blower working and is lint chute cleaned out in the back of dryer?
Posted on Dec 01, 2009
Just purchased 2nd hand Miele novotronic w310. Does machine automatically stop? Cycle ends, anti crease light on and machine just tumbles clothes makes odd noise, then tumbles again. Is the normal?
NORMALLY WHEN A DRYER COMPLETES IT'S DRYING TIME IT WILL GO THROUGH A COOLING DOWN CYCLE,
DRYER WILL START TURNING WITH FAN ON ONLY FOR A FEW SECONDS THEN STOP, AFTER A SHORT PERIOD IT WILL DO IT AGAIN AND AGAIN UNTIL UNIT HAS COOLED DOWN, HOPE THIS IS WHAT YOU ARE EXPERIENCING
GOOD LUCK
Sep 22, 2016 | Miele Washing Machines
Whirlpool Tumbledryer AWZ-121/3 OVERHEATING PROBLEMS
When was the last you cleaned the hose leading off he back.
Pull the dryer out and remove the exhaust hose (probably held on with a hose clamp so you will need a flathead screwdriver.
Once it's off take the hose from a vacuum or shop ac and stuff it in there and get out everything you can. Do the same win exhaust hose, and from the front at the lint filter.
Jun 14, 2016 | Whirlpool Dryers
Awz 8676
Try this link http://tumble-dryers.tech-specs.com/whirlpool-awz-8676-n30037723
Aug 29, 2014 | Whirlpool Dryers
Whirlpool dryer awz 121 only tumbles counter clockwise. This is a dryer that briefly reverses direction, so the only tumbling is when it reverses. The rest of the time, the dryer makes a noise but d
You may want to contact a professional that will have the diagrams for your machine online. there are some here or you can go to another site. like (Just answer.) Be more specific about your problem. It can be fixed . There's no worries.
Are you saying that it does not heat up either ?In addition with not tumbling clockwise ?
Disconnect the dryer first. You can remove the top and front of the dryer to check to see what is happening. If it does not heat . You may need to replace the temperature control relay. If that does not work , the heating elements themselves may need to be replaced.
For the tumbling problem, they also have relay switches that go out.
BUT, if it is tumbling to one side and keeps tumbling then that will probably be enough to dry your clothes. As long as it is not too heavily loaded.
Mar 19, 2014 | Whirlpool Dryers
Whirlpool AWZ 410 washer dryer is not generating any hot air when drying. The dryer drum is tumbling but with cool air only.
Unplug the unit and take the top with the screws holding the lid on. Take a look at all of the wires on the top of the machine. You might notice broken/burnt wires on the safeties that are close to or that directly activate the heating element located in the blower housing located at the top of this washer/dryer condensing unit.
Nov 26, 2013 | Whirlpool LER4634J Electric Dryer
HOW DO I LOCATE THE HEATING ELEMENT ON THE 6TH SENSE DRYER
take the back panel off it is located in the rear.
Mar 19, 2010 | Whirlpool Dryers
How to clean a whirlpool awz7913 condenser tumble dryer heat exchanger
how do i clean my heat exchanger on the whirlpool awz 7913 condenser tumble dryer?
Jan 19, 2010 | Whirlpool Dryers
Whirlpool tumble dryer model NO- AWZ 121/3-belt replacement
how do i replace my belt on my tumble dryer
Jan 09, 2010 | Whirlpool Dryers
Whirlpool AWZ 7303 tumbling but not drying.
blower wheels will get loose in dryers. Sometimes they will get a whole lump of lint in them or you can hear a rattling noise in the dryer, this is the blower wheel, its worn out and it can cause the fuse to blow too,or it can half *** work and take fifty forever's to dry the clothes.Or it could be just that the dryer needs a good blowing out .I use a lawn blower to get all the lint out of the dryer as well as the vent pipe and vent to outside. I take the filter HOUSING out and wash it also. That is, I remove the housing and clean is good! Making sure that the dryer is properly flowing air is a good thing!
Sep 11, 2009 | Dryers
Dryer not heating, still tumbling
your heating element could be burned out...or a thermal switch could be stucknot allowing the element to turn on
May 25, 2009 | Dryers
Dishwashers Logo
110 people viewed this question
Top Dishwashers Experts
