Question about Samsung CLX 3160fn All-In-One Printer
Black toner supply error - Samsung CLX 3160fn All-In-One Printer
    President:
  • Samsung Master
  • 1,447 Answers
Your printer black cartridge chip is disable you change black toner then solve it
Posted on Jun 14, 2009
Sharp code f2-64
The code refers to the black toner supply fault. This is usually caused by the toner compacting in the toner cartridge. There have been a couple of instances where the plastic strip remains when the cartridge is replaced. If this isn't the case then the solution is to remove the black toner cartridge & gently but firmly tapping the toner cartridge to break up the compacted toner. Re-installing the cartridge & turning the machine off & then on should reset the error code. If the code remains it may also indicate a faulty toner cartridge & this can be proven by replacing the black toner cartridge with another one. If, after replacing the toner cartridge with a replacement, the code re-occurs then this could indicate damaged toner supply gears which would require a technician to verify, but the most common cause tends to be the toner cartridge is at fault.
Hope this helps.
Dave.
Jun 05, 2015 | Sharp Office Equipment & Supplies
I had newly replace the black color toner cartridge into my hp cp1515 printer but the LCD still shown re-install the toner cartridge and 10.1000 supply memory error. Please advice. Thanks.
The error says that the black cartridge e-label is missing.
Pull the black toner and make sure packing tape isn't covering it up.
Compare the black toner to one of the other ones to make sure that it isn't missing the e-label.
If you put the old black back in the printer, does the error go away?
Feb 14, 2011 | HP LaserJet CP1515n Printer
I am getting error: 10,1000 supply memory error reinstall
You are using re manufactured toner and it has a bad chip. Replace the toner.
Jul 06, 2010 | HP Laserjet CM2320nf All-In-One Color...
On Initialization the following error appears 10.00.01 Supply Memory Error.
The printer cannot read the memory tag on the black toner catridge. Power the printer off, swop the black toner cartridge for another colour.ie put the cyan, magenta or the yellow in the place that the black should go and fit the black in to space left by the colour. Power the printer on and see if the error remains the same.If it's the same error then it could be the cartridge reader in the black position.If the error changes, then it's possibly down to the black cartridge.
Oct 14, 2009 | HP LaserJet 5550 Printer
DELL 5110CN 093-426? What error is this?
093-426 is a "black toner replace soon" error message. first make sure that you're using a dell-branded toner cartridge (you can order online here: www.dell.com/supplies) & you can try reseating the black toner cartridge.
Jul 13, 2009 | Dell 5110cn Laser Printer
HP 2840 *(Error Message) = replace supply using black only Will only print in black All color and black toner are 75% or more full The drum was low so I replaced it just in case but error message remains.
By repalce supplies, it means that you have to replace the other toner cartridges and that it is only going to print black only
Al
Eliteprintersolutions@gmail.com
Apr 14, 2009 | HP LaserJet 2840 Printer
BLACK TONER SUPPLY ERROR
For anyone with a similar issue viewing this page (like me), first take a look at this video: http://www.youtube.com/watch?v=Ipw1RjwzUDg
You want to follow those instructions and see if they work for you. If they don't, which they probably won't, take a look inside the black toner transfer unit (by removing the metal plate with the 5 screws, see video for further instructions), if the transfer unit is empty then this probably means the printer does not supply enough toner to the transfer unit. You could compare the amount of toner inside the transfer unit with that of another colour and you'll will probably find that there is comparatively barely any black toner in there. A temporary fix would be to manually add toner to the transfer unit by simply pouring it in there, after which the printer should print perfectly again. You might need to actually drill a hole in the black toner cartridge or buy a toner refill kit. Of course this is only a temporary fix and you'll have to do it again once you get the same error message. Unfortunately I'm not yet aware of a permanent solution.
Nov 20, 2008 | Samsung CLP 300 Laser Printer
Gestetner dsc38 error code
You have an improper black toner density. Likely your black toner suction mechanism is clogged or the black toner supply clutch is not working.
Feb 21, 2008 | DSC GESTETNER - DSc38u Color Printer
My printer is not printing
My printer at work kept saying it was low on black toner. I finally replaced when I got the message Black toner supply error. I gave it a minute or two to adjust itself and when that didn't work, I turned off for about ten seconds and then restarted it. I've only had two problems with this printer and I have had to turn it off both times before it would work perfectly, if that helps anyone.
Nov 05, 2007 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX 3160fn All-In-One Printer Logo
502 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
