Re-wireing of plug cord
I stupidly dropped my air conditioner and the plug cord came completely out. All the connections are still there I am just unsure about how the wiring is hooked up. I have looked for a wiring diagram but have been unsuccesful.
  • jeremyprocto Jun 14, 2009
    The color wires I have are green, white and black. the green wire is abviosly my ground as I can see where it was stripped out of its place to the frame work. There is also a orange wire that I'm not sure if it was connected to anything it is not connected to the cord wire that was pulled out. Is there any way to get a wireing diagram this must be so confusing to you to have to explain to me. Thankyou
  • 378 Answers
Green color wire to the top center. then brown to the fuse, the rest is blue wire.
Posted on Jun 14, 2009
Voltage drops for 119 to 104 when the roof top unit is running, it will trip the 20 amp breaker occasionally.
You need a larger drop cord (heaver duty) from the service to the RV. You need to also check the Service plug in the side of your Rv for loose or corrosion in the socket. Then check the power connection to the A/c unit. Check these connections for loose wiring or getting hot. As the voltage drop means extra resistance along the path. Extra resistance means loose, dirty, or bad connections, and get hot, which can cause a fire.
Sep 12, 2011 | Dometic Rooftop RV Air Conditioner
My air conditioner fell out the window and pulled the power cord cord out. Could u please tell me where it connects. I have that area apart but can't see where it goes.
There should be two terminals on the switch. One will be marked L1 and the other L2. Doesn't matter which wire you plug on these terminals. If there is a green wire, it is ground and it will be screwed or clipped to the case
Jun 28, 2011 | Hampton Bay HBLG5004 Air Conditioner
When I installed my haier hwr08xc7 air conditioner this season I plugged it in and the plug light lit but the air conditioner would not come on no matter what i did on the unit or the remote. I then...
Hi, I would say you have a problem in the cord its self. Even though it lights up, its not getting power to the controls. I would go to a hardware store and get a new cord and take care of the problem. When you replaced the socket in the wall and the fan came on, you just got lucky and the cord moved in the right position to start the fan. I am sure the cord is either faulty, or the connections where the cord wires in are not very good. Please remember how the cord is wired, even if you have to draw a picture. It will hook to a capacitor if it is a 220 unit. Just draw you a diagram.
Shastalaker7
A/C Contractor
Jun 10, 2011 | Haier Heating & Cooling
I JUST PURCHASED FOR $500 AND HAD TO RUN A NEW DEDICATED 12/2 WIRE AND A DOUBLE POLE 20 AMP BREAKER, SO I SHOULD HAVE THE REQUIRED 240 VOLTS WITH MINIMAL AMPERAGE DROP(ONLY 35' FROM MAIN BREAKER BOX TO NEW...
I think your issue is the earth ground no neutral. You should run that to a neutral wire. All my 220V ACs can do a neutral (white) and 2 power (black) wires, but they aren't connected to a ground wire...
Oct 03, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Wiring for Goldstar R5050 window A/C
Yes I accidentally drop my Gold Star Model #R5050 out the window while installing it. I opened it up and the two(2) white wire are off and I don't know were they go. I try to connect the to the empty terminals and I got a spark out of the outlet. Can you please help me....
May 13, 2010 | Goldstar R5050 Air Conditioner
My dog chewed the cord to the haier air condiener can i replace the cord or fix it
You can go get a new cord make sure it is for window air conditioner has to be heavy duty for the amps that it draws. Or you can patch it making sure to get the right wires connected. And really the best way would be new cord but wrapping the wires and insulating them very well can get by. As long as you know how important it is to make the connections very good.
Aug 15, 2009 | Haier Mechanical Air Conditioner HWF05XC7
Roof top air won't come on
If you are running the AC on an extension cord it can cause such voltage drop that a fuse or breaker can blow, in extreme conditions it can damage electrical connections. Always use extension cords that are as short as possible and replace the cord ends (especially the female end) whenever they lose clamping force. A heavy duty cord end takes much more effort to plug in the male end and to plug things into the female end. Over the counter extension cords for your purpose should be no less than 12/3 with heavy duty (20 amp) ends and no more than 50' long, if you must go farther you should use a 10/3 cord.
May 26, 2009 | Dometic Rooftop RV Air Conditioner
Haier Air conditioner problems - e1 message
try turning it off holding buttons each individually in for 3 secs then in an hour plug back in ... the rep from Haier gave me this advice ... just waiting my hour now ... i also hear that the remote works for sure ...
Jul 15, 2008 | Sharp AF-S100FX Air Conditioner
Unit trips circuit breaker when plugged in
On AC current it really makes no difference to the operation of the unit which terminal the wires are connected to as long as the circuit is completed. A reason for the inverted wiring is that there will be a resistance between the hot wire and the control circuit. It makes for a reduced load on the contacts and switches minimizing arching.
Jun 08, 2008 | Maytag Portable Air Conditioner M6P09S2A
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
