Question about Microsoft Windows 98 for PC
I can't uninstall windows 98 because of missing of uninstall files winundo.dat,winundo.ini. so please give me a solution to uninsatall windows 98.
  • dugiejob May 11, 2010
    Why uninstall? are you wanting to install another windows product? If so, that install will format your disk and erase everything.. Exactly what is it that you are doing?
  • 76 Answers
Please follow this link....This will help you..
http://support.microsoft.com/kb/186102
Posted on Jun 14, 2009
  • 25 Answers
There are two options a hard one and a easy one and the easy one is format it or the hard one that get a windows 98 cd and repare it[this will take a long time as windows 98 cd's are extint]
  • 1,555 Answers
First take backup of your existing drivers through a third party software in diff partition. Data also. then format the partition in which 98 is installed
Ibm Thinkpad
If you can boot into safe mode try, system restore. You can even load window on top of it's self (repairing).
Anything XP or newer does not require a system.ini file. Only Win 98 or older. Here is what I found. http://www.computerhope.com/issues/ch000211.htm
Aug 30, 2012 | IBM ThinkPad 600X Notebook
Windows vista - ZTE AC2726 wireless data modem HSD USB Card unins000.dat file
http://www.4shared.com/file/E2DmPGFU/unins000.html?refurl=d1url
same here . use this file and put to the missing folder. then try to install or uninstall
Apr 22, 2012 | Computers & Internet
Unable bootup & error prompt that HAL.dll file missing or corrupt
CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location. Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
Resolution
  1. Restart the PC. The hal.dll error could be a fluke.
  2. Check for proper boot order in BIOS. You might see the hal.dll error if the boot order in BIOS is first looking at a hard drive other than your main hard drive.
    Note: If you've recently changed your boot order or recently flashed your BIOS, this may be what's causing your problem.
  3. Run Windows XP System Restore from a command prompt. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
  4. Repair or replace the boot.ini file. This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
    Note: If repairing the boot.ini does correct the hal.dll issue but the problem reappears after a reboot and you've recently installed Internet Explorer 8 in Windows XP, uninstall IE8. In this specific situation, IE8 could be the root cause of your hal.dll problem.
Nov 09, 2010 | Acer Aspire 4720 Notebook
Ntldr is missing
These are the common causes for this error Computer is booting from a non-bootable source. Computer hard disk drive is not properly setup in BIOS. Corrupt NTLDR and/or NTDETECT.COM file. Misconfiguration with the boot.ini file. Attempting to upgrade from a Windows 95, 98, or ME computer that is usingFAT32. New hard disk drive being added. Corrupt boot sector / master boot record. Seriously corrupted version of Windows 2000 or Windows XP. Loose or Faulty IDE/EIDE hard disk drive cable. Failing to enable USB keyboard support in the BIOS.
Please checkout this link for fixing the same Ntldr is missing
Sep 19, 2010 | Computers & Internet
I have a Dell with Windows 98 2nd Edition which starts up OK except it looks as if it is in safe mode when my desktop appears. While starting up, however, I get a message: Cannot find a device file that...
Hi
Thank you for your query
Please can try the following
1) Click Start>Run
2) type in msconfig, and then click on the startup tab
3) Remove any ticks/checks which has the mention of mcafee in there
4) click OK and then restart
This will hopefully take the error message away
Regards
shauqat
Apr 28, 2010 | Dell Dimension XPS PC Desktop
My modem cant work
633 - The port is already in use or is not configured for Remote Access dialout
This error can occur if:
The modem is actually in use - make sure you don't have other applications that are using the modem. Applications that can use the modem include fax software, terminal software (like HyperTerminal), as well as voice software including software that can make your modem an answering machine or speakerphone.
One way of seeing all running applications is to press CTRL+ALT+DEL and look at the Task List or Task Manager. This will display the actual program names - it may be difficult to pinpoint which, if any, programs are accessing the modem. Terminating tasks are about the only way - however, if you terminate certain tasks, your system may crash or become unstable.
The telephone.ini file is missing or damaged - If the telephone.ini file is missing or damaged, you can create a new one by running Tapiini.exe - this file is in the \windows\system folder. Before you run this, rename the telephone.ini file and reboot your PC if it already exists. Then, run the tapiini.exe file. This program will run very quickly and may not appear to do anything. You can verify the program created the telephone.ini file by searching for it.
The telephone.ini file is a Microsoft Windows file that stores settings for all TAPI-enabled applications including DUNS.
Make sure the modem named in the DUNS entry matches the name of your installed modem - You can check the name of your modem in ControlPanel->Modems.
Windows 95/98 - Can occur if the Unimodem TAPI file (unimdm.tsp) is missing or damaged. See MS KB Q150619
Windows XP - Can occur if another device's driver has a conflict with the modem driver. MS KB 324760 indicates this can occur with older Palm Desktop HotSynch Software.
Apr 21, 2009 | Smartlink All 56K Modems: V.92 PCI Chipset...
MLANG DLL. IS MISSING
This happened with MS Windows some times if you don't want to say..it's often :)
Okay, this what you should do:
Download the missing file from here: http://www.dlldump.com/cgi-bin/testwrap/downloadcounts.cgi?rt=count&path=dllfiles/M/MLANG.DLL
Then, follow the instruction below:
How to install/uninstall MLANG.DLL? 1. Unarchive the package and use the files from Release folder if you're running windows 9x/Me or Release Unicode if you are running windows 2000/XP
2. Copy DLL files in system32 folder [C:\WINDOWS\system32]
3. Click on Start > Run
  • To install the dll files, type: regsvr32 MLANG.DLL
  • To uninstall the dll files, type: regsvr32 -u MLANG.DLL
  • run.gif 4. In the end, you should receive a message saying that your file was successfully installed/uninstalled
    P.S.: If this information was helpful, please rate this solution.
    Mar 23, 2009 | Microsoft Windows 98 for PC
    Win 98 se file trouble
    get hold of a win 98 boot disc (search the net) as it will have the files you are looking for, i am sure. copy them to your hard disc c:\windows or c:\windows\system
    put them in both as i cant remember what one they go in. (it will not hurt in both).
    good luck
    Terry
    Mar 26, 2008 | Computers & Internet
    Uninstalling Anti-virus Software
    To remove / reset the uninstall password for Trend Micro OfficeScan
    Edit Ofcscan.ini file.
    On Windows.95/98 machines it is usually in C:\Windows\Ofcscan.ini
    On Windows.NT/2K machines it is usually in C:\WINNT\Ofcscan.ini
    May also be in C:\Program Files\...
    Open the Ofcscan.ini file using notepad search for the [INI_CLIENT_SECTION]
    Find the line reading Uninstall_Pwd= and type a # at the beginning of the line to comment it out.
    Insert a new line saying Uninstall_Pwd=70
    Save the Ofcscan.ini file and retry the uninstall. When it prompts you for a password, enter a '1'.
    Nov 14, 2007 | Computers & Internet
    Microsoft Windows 98 for PC Logo
    55 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Alun Cox
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
