Question about Cobra 150 GTL DX Base CB Radio
Transmit cuting out
I,ve had this 150 in the shop for this problam each time they say its working fine .
put it in the truck run down the road and it breaks up when i talk
the mike is new
the antenna system is new also swrs are below 1.5
radio ground is hooked to the cab
power is straight off the battery
  • Anonymous Jan 07, 2008
    i bought a 150 new after it warms up it cuts out on hight power and not on low power what is the problem?
Normally when the power drops the driver transistor needs to be heated with the proper soldering iron (poor soldering at the factory). The 150 also needs a factory mod (a 1 microfared 50 v cap installed) which prevents the receive from getting into the transmit causing flutter. Don't take your unit into a CB shop unless they are highly qualified. Best to return to the warranty station (no charge except for one way shipping). No other problems that we are aware of. Great value for the buck.
Posted on Feb 12, 2008
It requires a 50 capacitor ........go to cb tricks .com for pictures and info
Posted on Feb 10, 2008
I had the same problem when I had the radio set down to 2 watts. When I turned it up to 5 watts on low the problem went away never to return.
Posted on Jan 16, 2008
Sounds like the finals are tore up, maybe 1 of the dual finals is working and the high power side is out. You said it puts out just 2 watts and that is what it would put out on low side. Do you especially break-up after it warms up a little. If it works better cold and when it warms up then your finals might be shot.
Posted on Nov 20, 2007
Engine-Battery
Alternator tested 'On Vehicle' of 'Bench Tested' ??
I recommend begining with a scan,followed by our shop's standard fault tracing procedure....
INSPECT BATTERY ELECTROLYTE LEVEL
INSPECT BATTERY RESTRAINT
INSPECT BATTERY CABLES/TERMINALS
****LOAD TEST BATTERY,_______VOLTS @ 150 AMPS (Min SPEC 10.2 VOLTS @ 150 AMPS.)
TEST STARTER AMP DRAW,______AMPS INITAL,_____
AMPS SUSTAINED.
****INSPECT BELT(s),
****TEST ALTERNATOR OUTPUT,_____AMPS @ 12 VOLTS @ 2500 RPM (SPEC ______ AMPS.]
****TEST FOR DRAW,______(MAX ALLOWABLE 350 Ma),
Jan 18, 2014 | 1998 Ford Mustang
1989 Ford 150 4cly truck will run fine then starts cuting off and dies out . . no one can fix it. in shop now. shop owner pay labor can not fix. in shop 50 days
Hi, Check fuel pump that it is running properly. Sounds like an electrical problem with the pump. Good luck.
Oct 29, 2012 | 1996 Dodge Ram
With having 215 55r16 in the front and 215 60r16 in the back is that going to cause a loud humming noise?
Tires with a more aggressive tread pattern will transmit more road noise, 215 60r16 has a greater outside dia than 215 55r16, which means the front tires will rotate slightly faster than the rear, apart from road noise there is a possibility of setting an ABS code over time, or if your vehicle has AWD it could wreck your transfer case, you should never mix tire sizes for road use, hope this helps.
Oct 25, 2017 | Ford Taurus Cars & Trucks
Starts fine runs good most of the time but sometimes surges when you are going down the road
Im having same problem try this youll throw a code though remove your mass air flow sensor and try it if it runs good you need to clean it or reman or new one
Aug 25, 2012 | 1989 Ford F 150
My radio transmits fine. Until recently it received fine. Now it transmits but it does not receive. I've played with the squelch and volume. No luck. Can you advise.
Your finals are fried. Take it to a shop and they will fix the finals. Before you do that be sure to put in an extension speaker just to be sure. Most CB shops are inexpensive.
Aug 29, 2011 | Uniden Solara DSC VHF Marine Radio
99 Tiburon wont start.
first check to see if you have spark if you do try the cam sensor that tells you injectors when to work
Aug 20, 2009 | 2004 Hyundai Tiburon
1988 Cavalier z24 transmition problems
try this :
with the car in park start it, then from park move it down one. if it is reverse move it down another one, now that should be neutral, then the next one should always be drive
Sep 03, 2008 | 1988 Chevrolet Cavalier Z24
Cobra 150 GTL DX Base CB Radio Logo
110 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
