Question about Yahoo Messenger
My yahoo messenger stop working and restart my explorer on Xp what can i do? i have uninstall and reintall agen but i still having same problem
SOURCE: my yahoo messenger has stopped working!!
can you help me about my problem? regards and god bless you
Posted on Nov 05, 2008
Murphybanton
  • 2004 Answers
SOURCE: CAN'T ACESS YAHOO MESSENGER, INTERNET EXPLORER CLOSES THE PROGRAM
Uninstal the software and uinstal an older version. This will work after which you can update.
rate this please
Posted on Apr 07, 2009
premlovesanj
  • 31 Answers
SOURCE: Yahoo messenger not working
Uninstall your yahoo from Your Uninstaller! 2008
and then tri.... to intsall ok
it works
Posted on Jul 23, 2009
  • 3015 Answers
SOURCE: yahoo messenger stop working everytime i install
You need the following OS to support Messenger
Windows 2000 / XP / 2003 / Vista / XP64 / Vista64 / Windows7
If that is not an issue read on.
The problem is probably due to a mal-function of the uninstall software.The Yahoo Messenger uninstall software is notorious for leaving files and fragments behind creating conflicts with the incoming software
Close all programs when uninstalling / downloading and uploading.
If you tried to uninstall the old Yahoo Messenger program from the Control Panel and failed to back it up with a visit to the 'C' drive, you may have old software conflicting with the incoming software trying to share the same folder.
If you have Vista the whole Messenger folder should have been removed during the uninstall.
Check
Start > Computer >> Local drive (C) >> Program Files >> Yahoo >> Messenger. - The Messenger folder should have been deleted and not seen. If the Messenger folder is still visible - delete it.
If you have a pre-Vista OS, the Messenger folder remains, and inside, only one sub-folder should be seen. This is the 'Profile' folder and contains all the message history. All other software should have been deleted.
Manually delete any other folders and files before moving on
Download 'ccleaner' and run it through a couple of times,using the factory settings and the 'Run Cleaner' control until 0 bytes are seen to be cleaned following a scan
Run the 'Registry' from the left hand toolbar but 'Save' any changes before repairing
http://www.filehippo.com/download_ccleaner/
Re-start your computer and download Yahoo Messenger from here.
FER19DB - Unable to sign in 81003004 Problem
Launch Internet Explorer > File - uncheck Work Offline.> Use IE to visit a random site. Close IE. Open Yahoo Messenger and log in.
http://www.filehippo.com/download_yahoo_messenger/
Posted on Jan 02, 2010
urbanhookupz
  • 213 Answers
SOURCE: I have installed yahoo messenger 10, had the older
Yes, it seems there must be some conflicting software issues between the old and new versions.
I have had a similar problem with a clients computer in the past. I was able to get everything running by:
hitting start menu, control panel, click programs/ features and find messenger in the list.
Completely uninstall anything found both old and new.
turn off your computer....
Restart it and then install the new messenger 10 again.
this should solve your problem.
if this does not help finally make sure your operating system can handle the requirements of messenger 10.
If it does not you need to run an older version.
This should help you.
please rate my service it helps me too. Thnaks!
Posted on Mar 26, 2010
My yahoo messenger screen is blank. I can't see my own messages nor the answers.
Hello!
First of all, what is your Operating System?
If on XP, having the most recent Java application will ensure proper communication between Internet Explorer and the Messenger application. Please follow these steps to uninstall and reinstall your Java runtime environment.
1. On your keyboard, hold down the Windows key and press the R key. This opens the "Run" command.
2. Type in appwiz.cpl and click OK. This opens "Add or Remove Programs"
3. Select Java and then click the Uninstall button. There may be multiple installed versions, so be sure to remove all of them.
4. Next, download and install the latest version of Java Runtime Environment.
5. To ensure the update is effective please Clear the Yahoo! Messenger Cache.
6. Restart your computer or laptop, restart your messenger to determine if the issue is resolved.
If you need further assistance, please let me know.
Regards,
fossildude
Feb 27, 2011 | Yahoo Messenger
No yahoo.massenger
The first step to resolve Messenger crashes on Windows XP is to uninstall runtime components:
  1. On your keyboard, hold the <Windows> key and press the <R> key. This opens the "Run" command.
  2. Type in "appwiz.cpl" and click "OK." This opens "Add or Remove Programs."
  3. Select each of the following items and click the "Remove" button. There may be multiple installed versions, so be sure to remove all of them.
  • Java
  • Microsoft .NET Framework
  • Microsoft Visual C++
  1. When uninstall is complete, please restart your computer.
  2. Next, download and install the following software updates to optimize your computer's compatibility with Yahoo! Messenger
  1. After installing these updates, restart your computer again, and then run Yahoo! Messenger.
Dec 04, 2010 | Yahoo Mail
Firewall stops me using yahoo messenger
Uninstall or disable any security software running on your computer. Try restarting your computer in safe mode with networking and then installing. If all of the above doesn't works and still you were getting message for firewall then either disable your Router's firewall by opening Router's page or Bypass router for a while and connect directly to Modem and then Install.
May 23, 2010 | Yahoo Messenger
My yahoo messenger won't open
I would reinstall it then restart your pc. I always keep the program after downloading it in case I need to do this. Best to uninstall it first. Switch off pc the restar-reintall-restart. It should then work.
Jun 13, 2009 | Yahoo Messenger
rate this please
Apr 06, 2009 | Yahoo Messenger
Yahoo messenger has stopped working
I have gotten this issue several times being a tech for the HP notebook division and I found a simple solution for it.
Right Click on the Yahoo! Messenger icon on the desktop and select properties.
Click on the Compatibility Mode tab
Check the box at the top to enable it and make sure the mode is Windows XP SP2.
Select ok.
Restart machine.
I hope this works for you all. =)
Oct 23, 2008 | Yahoo Messenger
Lifecam vx6000 not working with yahoo messenger
Normal 0 How much memory do you have installed in your computer? It may need to be increased as this is likely to be the cause of your computer freezing.
Hope this is of some help. Bud
Sep 13, 2008 | Microsoft LifeCam VX-6000 Webcam
"yahoo! messenger can't connect"
I cannot connect thru yahoo messenger yet I can connnect thru Mozilla Firefox, I also cannot connect to MSN Explorer- I could not get Expert Assistance here says I am not connected to internet thru Internet Explorer But my internet connection is fine thru Mozilla????????-
Oct 22, 2007 | Yahoo YHT-630 System
Yahoo Messenger Logo
127 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
Sunday Ojelabi
Sunday Ojelabi
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
