Question about Lexmark X4270 All-In-One InkJet Printer
My printer will not print. the ink is brand new,
My printer will not print. the ink is brand new, printed one time and then nothing? any trouble shooting ideas?
  • 32 Answers
Sounds to me like your inkjets are clogged get a q tip gently run a disc cleaner solution on them
Posted on Jun 14, 2009
I took the same cartridge had it refilled put it back in the printer keeps saying troubleshooting print cartridge what do do
when u put in a refilled cartage the reset will not engage ,so it will always read out of ink, check printer, etc.reset you printer manually everytime u print is the only thing u can do or buy brand new ink.and install new ink then remove this will let u print once,u will have to do this every time try xing out of prompt several times on youre computer if u r printing through it and that will work,but if u r printing on straight printer u half to reset it every time. hope this helps.
Jan 04, 2015 | HP J4680 Office Jet All-In-One Printer
Brand new printer with brand new ink prints BLANK pages
Hi Mike This is an odd one. If it prints the bars then ir should print everything else - cleaning is just wasting ink in this case.
I'm guessing that this is still under warranty, so I would take it back and get it replaced.
Mar 06, 2013 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
HP 7780 suddenly stopped printing in red. I have changed the cartridges several times. I am using brand new HP cartridges. Have cleaned the print heads, aligned several times, nothing has heled. The...
Hi Good day!!!
Maybe your print head is clooged (red)
Then most about 98% are more likely to be an ink clog which just needs to be unclogged using something like print head cleaning solution
Basically, if a print head has been left unused for some time... moisture inside the ink begins to evaporate and instead of liquid ink, a thick inky jelly begins to form inside the print head.
When this occurs white lines appear in prints and most people not realizing the problem, will replace their inks... But when that does not work. Some assume they have an electrical fault, and replace their print head, others will replace their printer !
But provided there is no obvious print head damage? In 98% of cases it simply needs a little patience and print head cleaning solution injecting directly into the print head to dissolve the dried ink trapped inside. This will dissolve the clog and allow your expensive ink to flow once again. Most will then print as new.
Thank you for using fixya
Jan 03, 2011 | HP Office Equipment & Supplies
Trouble with my epson stylus c45 printer. PLEASE HELP!?
this is usually caused by clogged print heads, unfortunately epson is still one of few brands that still manufactures most of their printers with the heads built into the machine and thus upon print head clogging the printer must be taken in to be serviced or buy a new printer that does not have the print heads built in but rather built into the ink cartridges. hope this helps.
Sep 30, 2009 | Office Equipment & Supplies
Brother 665cw wont print has new ink acts like it is printing but nothing on paper
There is always a protective film on the print nozzles of the cartridge. Have you removed it? DO so now and print again. If you have and the prob still persists, then clean the contacts on the cartridge and the printer. Prob still persists, then go to printer settings and in trouble shootin option, clean the print nozzles. It will print an ink intensive page and the nozzles will be cleaned.
Aug 17, 2009 | Office Equipment & Supplies
No ink on page
Clean the contact in the housing area and on the ink cartriage. If that does not work buy a new cartriage. The ink probably dried up in the nozzles. You can place the ink cartriage on a wet paper towel water or alcohal and press the cartriage into the towel. If you see no ing replace.
Jun 11, 2008 | Office Equipment & Supplies
Lexmark x6170 alignment problems
Is the ink generic brand or lexmark brand?
Nov 13, 2007 | Lexmark X6170 All-In-One InkJet Printer
Printer won't print in black
This could be to several reasons:
1#  The black cart contains blue ink-> Change to a brand new cart.
2# The cart assy has a bottom that is a foil. Sometimes this foil leaks.
Ink will mingle: You need a new cart assy.
Run the cleaning cycle twice after inserting a brand new bk ink cart and print out a test print. If you still see blue instead of bk the assy is leaking.
BTW the bk is darker than blue (or better cyan). You must see bk! So it seems to be the prob with the right ink....
Nov 11, 2007 | Brother Multi-Function Center® MFC-215C...
Nothing Prints on the page
the print head needs servicing or you can try checking out this link : How to Unclog Epson Print Heads
Nov 07, 2007 | Epson 1000 ICS All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
49 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
