Question about HP 49g+ Calculator
My HP 49g+ was off for the last 3years. I tried to put it on again but is doe'nt want to go on. I've replaced all the batteries, pressed the reset but still nothing?
2 Suggested Answers
SOURCE:
rolltape
  • 58 Answers
SOURCE: Lying ipaq H5550!
It's a problem with either the memory board or the button board. With my h5550, the bottom buttons started to stop working and eventualy the PPC stoped charging all together. You can find parts for it online. If all the buttons are working fine, then it's most likely the motherboard. Otherwise it should be the button board.
Posted on Feb 05, 2008
Stuck sleep mode
The solution to no post on a computer is to remove everything that you can, take out the hdd, the ram, and optical disk and see if it boots. If it does, put the RAM back, then try again, if it does, put the hdd back and try again. It is a process of elimination. If everything is removed and it wont boot, it may be the motherboard. I have also seen bad batteries do this. There is a chip inside the battery that wont let the machine boot when the life of the battery is expired.
Aug 19, 2017 | Toshiba Computers & Internet
My 12.5 hp 40 in cut murray won't start worked fine last winter when i put it up i've replaced the battery n plug an still won't make a sound
Check the ignition coil for spark if it does not make sure the ground wire that runs to the brake is releasingn if it is replace coil
Apr 01, 2013 | Murray Garden
I have a 2004 Chevy Cavalier. A couple of months ago, just after starting the car one day, the 'check engine' and 'trac off' lights both came on. I immediately shut off the car, waited approximately 5...
Well it's temping to put in biggfer fuses as the problem gets worse but the size of the fuses are to keep you from burning things up so you've from your probem with a 30 amp smoke test. The raditor fan wire is melted somewhere in the wire harnes to the wire for the trck lock or even key on circirts. the likly place to look is inside the stering collum. It takes the skills of removing the steering whel and the lcok plate and even then thats does'nt have to be where the problem is. You need to look under the dash after you remove the covers and use you nose to smeel for the burnt wiring and open up any thing the smells like it's been hot and anything the appers melted together. once a harness is found melted you need to seragete all the wires in the loom but don't cut the wires justy seaparte them. once you think you've got then all pulled apart so no bear wires touch each other or any meal parts put in the correct size fuses and see if you can connect the battery with out a spark. if you can you may then start checking to see what works and what does'nt.. This all sounds like too much work or too hard to do then you'll need to pay someone theat knows alot about car wiring problems to do it for you. I'll been doing this kind of work for the last 20 years and a'm alawys finding new things that are fried and burnt up. We all charge by the hour to do this work so the most experieced mechanic that works on cars like yours will probly find and fix the problem the fastest. therefore they may charge more per hour but their likly to get it right quicker and it'll stay fixed after they fix it.. This is the most likly kind of work to go sour after it's fixed cause they might miss a circuit that you use and they did'nt try. and as soon as it burns again it's back to the drawing board and if big fuses are use the fire can take the whole car.
Apr 26, 2011 | 2004 Chevrolet Cavalier
Does not charge when the charger is plugged. The Red light does not turn on.
Just wait for the battery to be completely drained-I did that to mine just now.after the battery is completely drained, I charged it, and it began functioning again.
Oct 05, 2010 | Nokia BH-503 Bluetooth Headset
Reset button ?
Sometimes there is a reset button and sometimes you have to reset it through a menu. Of course, if it won't turn on, then you can't get to the menus.
May I ask, what is you Toshiba camcorder's model #?
Jul 31, 2010 | Toshiba Video Cameras
I´ve a pda hp h5455 that don´t start , i´ve tried to do a hard reset and charge it via USB and nothing hapens
To do the hard reset, while on battery (NOT A/C) power, hold down the two outside front-panel buttons (Calendar and iTask), While holding them, press the reset button with the stylus. Keep these buttons all pressed until the image on the screen begins to fade (about 4 seconds), then you can release the reset and application buttons. To restart your iPAQ, you must then plug the unit into A/C power, or do a Soft Reset by again, pressing the reset button with the stylus.
Nov 21, 2009 | HP iPAQ H5455 Pocket PC
I have an HP computer with an optical mouse and keyboard. Last night we lost power. When I rebooted the pc, the keyboard works;but the mouse does not. I replaced the mouse batteries;but no change.After...
There should be reset / resync instructions on back side of wireless keyboard. Basically, press reset button on keyboard, then press reset button on mouse. this should resyncronize both to PC.
Aug 18, 2009 | Computers & Internet
HP48SX Battery drain
I suggest you use rechargeable batteries. They usually drain faster than the alcaline ones anyway.So have 2 sets of rechargeable batteries. Evaluate the number of days a set lasts. Insert the charged batteries before the old ones are thourougly drained.
The life of your batteries in the calculator depends on the usage.
About repairs: I am convinced that it will cost you more to have it fixed than to buy a new HP calculator (HP 49g*'s, HP 50g* 's).
Hope it helps.
Nov 13, 2008 | HP 19BII Calculator
Lying ipaq H5550!
Dec 29, 2007 | HP iPAQ H5550 Pocket PC
HP 49g+ Calculator Logo
52 people viewed this question
Clive
Clive
Thomas F. Schneider
