Question about Motorola Mobility H700 Wireless Headset
Motorola H700 Bluetooth won't stay connected
It seems like the slightest movement on the mouthpiece breaks the connection.
Conect to an other phone.What PIN# to use?Motorola H700
Use 0000 for the H700. If you are pairing with an Iphone, steps are as follows:
Headset is off, with mouthpiece closed
Open Iphone and select Bluetooth to ON
Hold down the center button (usually blue light) so it shows purple,
Open the mouthpiece.
The Iphone should merge.
Mine did not ask for a PIN, but if your does, it's 0000.
Thanks to the solutions above for guiding me thought this.
Feb 07, 2010 | Motorola Mobility H700 Wireless Headset
Won't stay connected.
check the batteries on the BT headset
May 15, 2009 | Motorola Mobility H700 Wireless Headset
Motorola H700 won't stay connected
Your bluetooth is defective. Contact Motorola to get a replacement. This is THEIR fault. I had the same problem. www.motorola.com Hope i've helped you!!!
Mar 19, 2009 | Motorola Mobility H700 Wireless Headset
I can't sync my motorola h700c with my blackberry
1. Bluetooth enabled?
2. Options -> Bluetooth -> Add Device
Hold down the connect button on headset until steady purple light comes on, then open the boom.
Search for Bluetooth devices on the blackberry. When asked for a pin, use "0000". Now the H700 will show up in the Bluetooth device list, but it will not connect. Put the headset in pairing mode again, this time go to the h700 listed on the blackberry and select connect. Now the devices will work as normal. When you open the boom on the h700, it will connect to the blackberry.
Dec 11, 2008 | Motorola Mobility H700 Headset
I can't pair my Motorola H700 to my Blackberry curve.
http://khaoohs.wordpress.com/2007/11/16/motorola-h700-bluetooth-blackberry-pairing/
this actually works.
Aug 09, 2008 | Motorola Mobility H700 Wireless Headset
Motorola bluetooth pairing
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H700 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Motorola H700 Bluetooth connection problem
Tips:
Apr 01, 2008 | Motorola Mobility Bluetooth...
H700 will pair, but won't connect.
To successfully pair the Motorola 700 with the Centro:
Select Bluetooth from the Home screen.
Select "On".
Under "Visibility", select "Visible".
Now click "Setup Devices".
Click "Hands-free Setup"
On the Motorola earpiece, with the flip-out mouthpiece in the closed position, press and hold the multi button until ring around it glows purple. Flip open the mouthpiece.
Now click "Next" on the Centro's screen.
The Centro should find the Motorola. Hold the Motorola to the right side of the phone if you have difficulty getting the Centro to find it.
Once found, click the Motorola H700 listed in the window and click "OK".
The Centro will ask for the device password. Enter 0000. Be sure that the checkbox for "Add to trusted device list" is checked. Click OK.
The two devices should now be paired to work together and the Motorola's multi button should rapidly blink blue; NOW click "Done".
You will be taken to the Trusted Devices screen.
You will see your Motorola in the list of Trusted Devices. Click on it to highlight it, if it is not already highlighted.
Click the menu drop-down key (located to the right of the ALT key).
You will now see a drop-down at the top of the screen that says "Connect". Click the "palm" center button on your Centro.
NOW the two devices are connected. The phone name will now be bold, and a small Bluetooth icon will appear to the right of it.
When you click the Phone key on your Centro, you will see a tiny blue headphone symbol now at the top right of the screen where the Bluetooth icon used to be.
To use the earpiece:
Flip it open and hang it on your ear.
Dial the number you want to call on the phone.
Press the multi button once and now you should be connected via the earpiece.
To receive a call, when your Centro rings, press the multi button once.
It took me a few hours to figure it out. Hopefully you can do it in a few seconds.
Dec 28, 2007 | Motorola Mobility H700 Wireless Headset
My H700 does not connect. When I attempt to connect it shows the disconnect option but it isn't connected
My bluetooth does not work at all. Have had it on charger for days. It does turn purple, but does not work when I put it in my ear. Have checked the connection. It just seems dead. Bought it last November, but first time I've had a problem. Can you help? Barbara
Jun 20, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
520 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
