Question about Brother SE-270D Computerized Sewing Machine
Top thread wraps around bobbin
When I am embroidering my top thread will wrap around bobbin and ruin entire design. Any ideas how to fix this?
  • 4 Answers
Re: top thread wraps around bobbin
Is it birdnesting under the bottom or it is actually getting tangled inside the bobbin case? I've had my machine for almost a year and don't think I've had your exact issue. Sometimes, when you do a stich over a already stitched portion, you may have a problem with the bobbin and I just generally stop and start it again. It is important that you use the correct needle and also use a good embroidery thread and stablizer. Another thing suggested is changing the needle after about every 5 designs. Also, check the bobbin case to make sure there's no fuzzies caught in it. I use "canned air" like you use on computer keyboards. I also only use 40 weight emboidery thread for the top and actual bobbin thread for the bottom. Other threads can really jam everything up. So it's been trial and error to find the right combinations. Good Luck!
Posted on Jan 16, 2008
0 characters
3 Points
Keep the thread from collecting on the arm that holds the bobbin case in? My Brother LB-6800 sews quilts, and embroiders great until yesterday, The thread wraps around this small arm every time now.
Try taking the bobbin case out and re-insert. It sounds like the case that holds the bobbin is not inserted correctly. You might also try checking to be sure that the needle is inserted properly. Sometimes the needle gets loose and drops down too low. unscrew, push the needle up as far as it will go, then tighten the screw.
Jan 24, 2015 | Brother LB-6800PRW Project Runway Limited...
Bobbin wraps around itself and jams up
You may have the wrong bobbin in the machine. If it sticks up out of the bobbin case the upper thread will wrap around it.
This would be for a top loading machine.
What model is it?
Oct 18, 2014 | Sewing Machines
Singer inspiration thread wraps around bobbin seat while sewing
it sounds like you need a new bobbin case. and it would be a good idea to have the machine serviced
Mar 30, 2012 | Singer Inspiration 4210 Mechanical Sewing...
The fabric is being ruined by the feeder under the fabric. It is not the needle.
It could be different things, the tread may not be locked in the top tension, you may have treads all wrapped up around the bottom bobbin. Take out the bobbin and look, re-thread the entire machine.
May 08, 2010 | Sewing Machines
When winding the bobbin, the thread keeps wrapping around the bottom of the bobbin post
Make sure the bobbin is pushed all the way onto the post and that the thread is running through the tensioner on top of the machine above the needle area.
Jan 16, 2010 | Bernina Sewing Machines
Top thread keeps getting wrapped around bobbin case on LX-3125
You should hold the end of the thread coming through the needle until the thread has grasped the bobbin thread.
Jun 30, 2009 | Sewing Machines
Thread tangles under throat plate while embroidering
Could the little hook that is stuck over the bobbin area be the thread cutter? My thread cutter gets stuck there and I have to turn my machine off and then try to use the cutter to reset it to its "resting" position.
Nov 23, 2008 | Brother SE-270D Computerized Sewing...
Upper thread wraps around bobbin mechanism, while sewing
Jul 29, 2008 | Singer Inspiration 4210 Mechanical Sewing...
White 2037 Bobbin Filling
turn your thread 3 turns to the right, clockwise,
then pass theend of the thread, under the coming thread and give it another 3 turns to the right.
For better results, always remove old thread from bobbin before filling it up.
Jun 14, 2008 | Sewing Machines
Brother SE-270D Computerized Sewing Machine Logo
571 people viewed this question
Top Brother Sewing Machines Experts
Bargain Box
Bargain Box
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
