Question about DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder
Switch Toshiba projection tv to receive input from video-1?
How can I switch a Toshiba projection tv (model #TE55T...) to receive input from video-1 using the universal remote control (5.0 IR) for the DISH DVR 625?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 358 Answers
Jbrowne_usa
If your DISH remote is programmed to your Toshiba TV, you can press the TV button at the top left of the remote and then release. This will put the remote in TV mode. Press and release the TV/Video button just below the clear TV button. This will cycle through the inputs on your TV. Continue to press and release until you have Video-1 displayed on your TV screen. I hope this helps.
Ray Calo
DISH Network
Posted on Mar 01, 2011
Tv/video switch won't switch
The model indicated is a older Toshiba rear projection(if another brand/model let me know)
You should be able to select the rear inputs either via the remote (original one) or with the input (video) button on the set.
If in the menu they are grayed out--it means they have been locked out.
Failing that a serious problem exists in the set's microprocessor.
Hint: if you have not tried it UNPLUG THE SET FOR A WHILE TO SEE IF WHEN YOU PLUG IT BACK IT WILL RESET and restore the inputs.
Mar 23, 2012 | Toshiba 42H81 42" Rear Projection...
I have a Sony KP-53S35 53 inch Rear Projection TV connected to a Directv Receiver. The TV does turn on, but the screen goes blank and VIDEO 1 is displayed. It will stay on, but will continue to do this. ...
Press any channel button on tv remote to switch its input source as TV to watch tv channels.
As you said, screen shows Video-1 display that means tv is set on input-1 that need to be changed, press channel button on remote or tv front to shift it on tv channels mode.
Let me know if you have additional question.
Thanks.
May 03, 2010 | Sony KP-53S35 53" Rear Projection...
My Toshiba model number 51H83 has picture but no sound. I put a dvd in and the sound worked but when I went back to TV no sound. I dusted the back of my tv yesterday and since then have had no sound. Tv is...
Are you using the rf antenna input for TV or 1 of the VIDEO inputs from a cable box or sat receiver. If the latter check to see if you unplugged the audio fron the box White and red wires from box. If thats ok Plug that dvd player into that input using the cabes from the dvd player .If you now have sound change ables from box. if still no sound cable box bad. If still no sound from that input check for solder connection on input jacks. If antenna input is used replace the tunner intv.
Mar 25, 2010 | Toshiba 51H83 51" Rear Projection...
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
Trouble hooking up the Wii console
well, unhook everything from tv. hook up wii to video 1 input. turn on tv and with your remote, select video 1 input . have fun!
Nov 10, 2009 | Toshiba 42H81 42" Rear Projection...
I would like to know if I can connect a HDMI cable from My tv model WS-65315 to a Direct TV HD receiver?
NO> If your TV supports and have HDMI connections and your HD receiver has an HDMI output then you should have no problem displaying Video. Just make sure you change the input signal of your television to HDMI input. After looking at the spec's of this model these are the following inputs you have. your best picture quaity would be to use componet cables instead, which can show full screen 1080i format, your television does not show at 1080p whis is what HDMI is known for.
Connectors
Rear Input Connectors S-Video x 2 - Component x 3 - Composite x 2 - DVI x 1 - RF x 2 - 1 x RS-232C - Audio (RCA) x 6
Front Input Connectors S-Video x 1 - Composite x 1 - Audio (RCA) x 1
Rear Output Connectors Composite x 1 - Audio (RCA) x 1 - RF x 1
Another good option is use to use a DVI to HMDI connector and hook it up this way. But note: you will have to use audio cables for the DVI input.
Sep 28, 2009 | Mitsubishi WS-65315 65" Rear Projection...
PANASONIC DVD PLAYER CONNECTION TO A TOSHIBA PROJECTION TV
s-video input for a better picture , or yellow jack(RCA jack) for video, then red and white for audio
Nov 06, 2008 | Toshiba CZ27T31 27" TV
Toshiba TN55X Convergence problem.
You brought up an issue that we hadn't considered. Shortly after hooking up our TV to the receiver with a composite video, our convergence which wacko. My hubby replaced the 2 ICs, but now our power button just flashes red, with no picture. Not sure if new ICs are faulty or if it's another issue. He will replace old ICs to see if problem still exists with turning on the tube. And he'll try disconnecting the video signal to see if problem exists.
Ouch.. may have to consider another tv thanks to new technology ??????
Good luck solving your problem.
Jul 06, 2008 | Toshiba TN55X81 55" Rear Projection...
Need help connecting Receiver to TV, DVD, VCR players
Take the audio outputs on the TV set and connect up to the The video 1 inputs to the receiver, BUT use the audio part of the video 1 input and leave the yellow video input blank. Now turn on the TV set, put the TV set on a channel, turn on the receiver and select the video 1 input and you should have the TV audio coming from the receiver. Good Luck.
Jul 29, 2007 | Pioneer VSX-406 Receiver
40H80 Problem TV will not switch to non antenna inputs
Sounds like you have a bad tuner. It is not uncommon for solder joints to deteriorate over a period of time and loose continuity. If you are handy with a soldering iron, you can try to fix it yourself but I really recommend leaving it to a professional.
Dec 06, 2005 | Toshiba 40H80 40" Rear Projection...
DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder Logo
150 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
