Question about Regal Lager Phil & Teds Sport Buggy Double Stroller
I cant unfold it, have never had a problem before.
It seems to be locked in the folded position, the two buttons in the sides i usually press are not unlocking it,
Are you sure you don't just have the two little straps on the side locked on?
Posted on Aug 04, 2009
How do I unfold and fold the eddie bauer trailmaker stroller
usually there is a lock button that needs depressed to FOLD .without seeing it I can not tell you where it is.
Feb 24, 2018 | Eddie Bauer Baby Gear
Right mirror over open when unfold?
check the open position stop sensor for a fault
Mar 18, 2014 | Lincoln Navigator Cars & Trucks
How to fold my afg 5.0 treadmill for storagae
Dear Sir: Hello , i hope everythign is o.k
Please do the following:
FOLDING Firmly grasp the back end of the treadmill. Carefully lift the end of the treadmill deck to the upright position until the foot lock latch engages and securely locks the deck into position. Make sure the deck is securely latched before letting go. To unfold, firmly grasp the back end of the treadmill. Gently press down on the foot lock latch with your foot until the lock latch disengages. Carefully lower the deck to the ground. NOTE: on some models the foot lock latch might be on the right hand side. NOTE: when folding the Horizon Fitness Treadmill the console assembly will tilt away from you, but will return when fully folded in the upright position. Please allow two additional feet from wall when folding.
Thank you in advance, sincerely. Blessing.
If you need additional help, please contact me.
e.cuadra Managua, Nicaragua C.A.
Sep 25, 2011 | Horizon AFG 5.0 AT Treadmill
I want to know if the side mirrors folds in
On my S Type I hold the 4 x way button on, in the down position and they fold - the same to unfold - Do you know if this option is fitted to your car?
Jan 30, 2011 | 2009 Jaguar XF
How do i fold this puschair up & how does it fold down? Can this done by one person? Thnk you for any help.
The Tracker is designed to be folded and unfolded easily, by one person.
To unfold: If your Tracker has an adjustable handle, ensure that it is in one of the middle positions. On the central twist grip, push in the red button and turn the grip in the direction of the "FOLD" arrow. The pushchair should now begin to open. Placing your hand on the side moulding, pull on the handle until the primary locks on both the left and right hand sides engage with a click. The secondary lock should automatically engage.
To fold: First of all, make sure that the front wheels have been locked into fixed, non-steering mode. Also, ensure that the adjustable handle is in one of the middle positions. Press the red button on the twist grip and simultaneously turn it in the direction of the "FOLD" arrow. At this point, the chair should start to close. Next, look for the secondary locking device. This plastic tab should be situated just below the handle grip on the left-hand side. Pull it upwards, whilst tilting the chassis forwards and continuing the folding action until it is fully closed. Align the front wheel with your foot, if necessary, and fold down the adjustable handle to store the chassis.
Find out more by obtaining an instruction manual from service@bebecar.co.uk
Aug 31, 2010 | Bebecar Tracker Urbano 1455-U Stroller
Once I've folded my phil & ted vibe (in single mode) the locking clips won't fold into place (I've used as much force as I dare -- worried I might break the clips if I try any harder). This makes it...
When folding the Vibe some important things to remember are that the handlebar must be in the most upright position (perpendicular to the ground), nothing can be below the rear axle level (ie. lift the basket up above this) and the front single wheel should have the side with the attachment bar on the outside.
The fold locks will not engage if everything is not in the correct position. If everything is in the correct position the fold locks will easily engage/disengage. If everything is NOT in the correct position the fold locks will not engage and should not be forced.
Folding:
  1. Put handle bar in upright position.
  2. Undo the side lock clips. Then you lift the red lever on the side to start the fold. Fold so that the pram front wheel and handle come together.
  3. As the pram folds ensure basket is above rear axle and the front wheel has the attachment bar on the outside.
  4. When the pram is fully folded you can fold the side lock clips back in place.
Nov 12, 2009 | Regal Lager Phil & Teds Vibe Jogger
I cannot unfold my Phil adn Teds Sport
Take off the front wheel, this allows the buggy to fold a bit tighter and lock. You now should be able to push the grey button to unlock it.
Aug 11, 2009 | Regal Lager Phil & Teds Sport Buggy Double...
How do you unfold and fold a quinny buzz
Hi to unfold undo the clip if there is 1, some don't have them. lift the handle slightly then it should unfold it self.
To fold you need to apply the brake, stand in frnt then the 2 large grey buttons either side of seat, 1 pushes in 1 comes forward, do this & pull down towards your feet this will fold it up. Don't mistake the small grey buttons on side of seat they are to lay seat back/forwrsd etc; the large buttons are on the frame.
Oct 08, 2008 | Quinny Buzz Jogger
Opening from folded position
i also found this annoying, the tracker chassis is similar to the ip-op chassis, which you can find instructions for online.
however when the chassis is folded, you first have to adjust the handle, to do this you push in the round black buttons either side of the handle, make sure the handle is in a strait line with the rest of the chassis. also check that the front wheels are in NON steering mode by pushing in the red button on the left hand side of the chassis.
once this is ok, you go back to the handle and push in the red button in the middle of the handle that confusingly says fold, as you push the button in, twist the black fold casing downwards, put your foot on the bottom crossbar and pull the handle towrds you. the chassis should start unfolding keep pulling the handle and pushing the bottom cross bar with your foot until the chassis clicks and locks on both sides.
da dah!!!!! there you go. now wait till want to fold it again bloody thing is a nightmare without instructions.
Aug 28, 2008 | Bebecar Tracker City U319 Stroller
How do i unfold a zooper tango double stroller?
There's a locking mechanism on the left hand side about mid-way down just under the armrest. You need to pull the plastic lock off of the pin and then unfold according to the "fold" instructions included in the manual.
Apr 18, 2008 | Zooper Tango Twin Stroller
Regal Lager Phil & Teds Sport Buggy Double Stroller Logo
207 people viewed this question
Top Regal Lager Baby Gear Experts
Jennifer Rock
Jennifer Rock
Marvin
Marvin
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Regal Lager Baby Gear Expert? Answer questions, earn points and help others
