Smelly towels I just bought an LG front loader in February 2009. It was wonderful at first but after 2 months, I noticed my towels had a very bad odor after using to dry off. I am so discouraged that I wish I never bought this expensive machine. I used to have a Kenmore top loader and never had any problems. After 18 years of use, I had to buy a new machine and I thought a front loader was the way to go. Was I ever wrong! I searched on the internet for answers but there are sooo many suggestions that I am overwhelmed. Today, I tried using vinegar in the pre-wash, no detergent for the main wash and vinegar in the rinse cycle. I washed them in hot water, added an extra rinse + extra water option to ensure that any soap residue would be taken care of. They still had a faint sour odor after I took them out of the dryer ( I set my dryer on high with the antibacterial option). I was hoping this would take care of the problem but it didn't. Perhaps I need to be more patient and wash them this way several times before noticing a difference? I always make sure to wipe the inside of the drum, door seal, rubber seal and leave the door open to ensure that it dries thoroughly. I never noticed any mold or gunk when I wipe under the rubber seal and my machine itself does not have an odor. I only have this stench with my towels. All my other clothes are fine. I use liquid Tide and now am wondering if I should switch to an HE Powder detergent? If so, which is the best one? I live in Canada. Please help!
  • 1,543 Answers
First do this: Start a normal cycle with no clothes in the washer. After the washer agitates (tumbles) a few minutes, pause the washer and look immediately if there are any suds in the machine. There should be no suds what so ever. If you see any, that means there is a build up of soap residue in your washer. That would be caused by an excessive amount of soap usage. You did not say how much soap you have been using. For a large load, use 1 to 2 tablespoons of soap at most (even less if it is 2X or 3X concentrate) and not more than 1 teaspoon of fabric softener if you use it. This is due to the fact that your machine is only using about 12 gallons of water, vs about 45 for your old top load machine. Your towels have soap residue left in them. Wash with no soap for at least one time. If you are doing only bath towels, and towels are used only to dry off your clean body after your shower, they are not dirty, just damp. They do not really need soap to clean them. (and remember to never use fabric softener with towels)
You did not state your model number, but I believe you have a tub clean cycle on it. Run that cycle with no clothes and a front load washer cleaner in it, such as 3 tables of Affresh, or a full bottle of Washer Magic, or Tide front load washer cleaner, or Whirlaway hot tub cleaner, or Smelly Washer Cleaner (smellywasher.com).
I have also heard some people have had better luck with powdered soap, but I think that the amount of soap being used is really your problem
Posted on Jun 14, 2009
MY newerfront load lg machine smells like mildew leaving clothes
Front load washers are very efficient but can create odors not common in top load machines. I would suggest running a cleaner such as Affresh or Smelly washer through the machine, there are instructions on the containers but basically you run a load without clothes on the hottest settings. This will help eliminate the mildew that gets caught between the tub and basket. A treatment once a month will do wonders!
You can purchase these at Target, Lowes or grocery stores near the laundry soaps.
Apr 19, 2010 | LG WM2487H Front Load Washer
Horrid smell in clothes - LG tromm front loader
Odors are caused by a variety of particulates, and each is neutralized by a specific formula.
I don't know what type of odor you are dealing with, so we'll start with first attacking any soap residues. Buy a gallon of white vinegar, and run a small laod wash cycle using hot water and add 1 quart of vinegar and 1 cup of baking soda, repeat a second time.
After the vinegar treatment, run another small load wash with hot water and 2 cups of bleach, and one cup of baking
Finally, dampen a rag with vanilla extract, and wipe down the the inside of the tub and door.
Write me at buffalonymann@yahoo.com with your results
Oct 02, 2009 | LG WM2688HWM TROMM SteamWasher
LG washing machine has AWFUL mildew smell
I have an LG washer that had the same problem. Go to the site www.nufreshnow.com and read all about why this is happening, how to fix it and how to keep it from comming back. A few different ways of cleaning the machine are explained.
The site sells a product that you may or may not need but the explanations are really good.
Nov 12, 2008 | Washing Machines
If you're not used to seeing water come down the front of the inner glass portion, then your return tube, and/or gasket drainage is most likely clogged. I have the LG WM2277HW front loader and this is what worked for me:
1. Locate water recirculating outlet at the top inside of the gray rubber door gasket- it will have a white plastic piece that directs the water flow inward.
2. Check for blockage at that outlet. Mine had one about 2 inches long. Pull it out with your fingers or tweezers.
3. Check the 3 small rectangular drain holes at the bottom of the gasket; make sure they're not plugged up as well. This is where the smelly water pools from bacterial growth
4. Run through a sanitizing cycle- no detergent, just bleach and watch for more blockage that might come out the tube from the top...it collects on the glass before falling all the way in. Don't wash any clothes before this step, or the gunk will end up in your load.
Hope that helps...pictures posted.
Nov 08, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Same here. We bought ours January 2005. Love the machines and take great care of them, too. Then the smell in the washer which seemed to affect certain clothes, like thick sweat pants and t-shirts (they smelled really "sour"). After doing some searches I found on this site where someone had recommended using a product called Affresh. I figured I might as well try it since my other attempts failed. This really worked for me. I bought it at Home Depot for $7 for a pkg of 3. I used 3 tablets per their directions, as this was my first time using it (afterwards they recommend using only 1 tablet per month). I was totally amazed as the smell was gone. I hope it works for you, too!
Oct 05, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Laundry
Interesting article explaining the problem associated with Front Loader Washing Machines and new products to combat the mold/fungus build up inside them.. Check it out....------------------------------------------------------------
Consumers who own front-loading washing machines should use only about one-quarter of the recommended amount of high-efficiency, or HE, low-sudsing detergent. Standard, non-HE detergents in front-loaders are too sudsy.
Why don't top-loading machines have this problem? Less efficient top-loaders that use more water typically flush out excess suds, soil, detergent and fabric softener.
Class-action lawsuits against manufacturers such as LG, Whirlpool and
Maytag have been filed, alleging mold and mildew problems in front-loading washers.
Some suits have been settled while others are pending, affecting hundreds of thousands of consumers, said Rob Shelquist, a partner at the Lockridge Grindal Nauen firm in Minneapolis.
According to Whirlpool, the low water use and airtight seals on HE front-loaders create the potential for odor-causing mold and mildew. Whirlpool has its own anti-odor product, Affresh, which sells for $7 for three treatments. SmellyWasher is more expensive than Affresh initially ($16 for 24 treatments), but Flynn's product lasts a year.
SmellyWasher can be used as a preventive monthly or less often if smaller amounts of detergent are used. Affresh is also used monthly, but a $7 packet of three tablets lasts only three months. Flynn's product will remove musty odors from towels or clothing, which Affresh does not claim to do.
Getting rid of problem
To eliminate odors, Smellywasher users should put a capful of Flynn's product in the detergent dispenser, select the hottest water temperature and the extra-large load to fill the empty washer with the largest amount of water. Let the water agitation start and then stop the washer and allow the solution to soak for two to four hours. Repeat as necessary and allow to soak overnight if needed.
Flynn said that the product works best in hot water. Consumers might want to run the faucet closest to the washing machine until the water is hot before starting the process or turn up their water heater temperature until the load is finished. (Remember to turn the temp back down to avoid scalding.) Flynn offers a money-back guarantee. Stubborn cases of mold and mildew might require five to seven treatments.
Susie Thymian is such a believer that she now sells SmellyWasher in her own store, McGinnis Appliance in Morris, Minn. Thymian had blamed the musty smell from her towels on her teenagers, who often leave wet towels in a pile in their bedrooms. Her kids' solution to the stink was to use more towels. Thymian's answer was to use more bleach in the laundry, but nothing got rid of the mystery mold odor until she found Flynn's product.
Only a few of Flynn's customers are from
Minnesota so far. Most come from regions with higher humidity. Sharon Turner, who lives in steamy San Antonio, said SmellyWasher worked after several cycles. "I was ready to throw out my plush towels and my front washer. It saved my sanity."
Link to this article..http://www.chicagotribune.com/business/chi-smelly-washer_chomes_0912sep12,0,7369054.story
Sep 14, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Stinky towels
Mildew odor in towels in almost invariably being transferred from the washing machine. The clothes washer must be cleaned first then clean the smelly towels and laundry. To compare washer cleaners watch this video of Affresh and Smelly Washer...
http://www.youtube.com/watch?v=Ua6OJPn0-fU
Apr 19, 2008 | Washing Machines
Foul smell
More then likely you're still using too much detergent and liquid softner. Front load washers use about 1/10 the water of a top load so all you need to use is about 1 tablespoon per load of soap and softner. If you use any more then that it builds up inside the tub behind the drum where you can't see it and starts to smell. Running the machine empty about once a month with just bleach will help stop the build up. If you do this and see soap suds that's left over soap coming out. If you see suds run it again and again until the water stays clear and you odor problem should be gone. You can go back to colored towels.
Feb 19, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
388 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
