Question about Hayward 2HP Pool Pump Motor A O Smith Electric Pool Motor for 56J Frame
I bought a new pump but the capaciter was missing, which wires go where? There was a orange one and a yellow one. Hayward super pump 230volt
    President:
  • 957 Answers
You should be hiring an electrician for this repair. If the motor is a 230 volt motor then both wires get hooked up to its own leg (power in). The electrician would make sure the power was off to that circuit, would verify that the motor was correct for that application, would see if the motor was spinning in the correct direction and if not then would switch the two wires onto the two legs that they were attached to. The motor should have some type of ground on it, look at the tag attached to the motor, there is a wiring diagram and a specification list, compare the two motors and make sure they sent you the correct motor.
Posted on Jun 14, 2009
Hayward super II wiring
move so both terminals are used sometimes they don't line up put on 220 then move to other position
Jul 24, 2012 | Hayward Super Pump 1 1/2 - Hp for In...
Just purchased a new super pump 1hp, but it is
Can you be more descriptive? My guesses are that the motor is wired wrong, the motor is defective, There is a leak in the supply line or the pump and air is getting into the pump, causing the pump to cavitate.
Jun 02, 2010 | Hayward 1HP Super Pump II Inground Pool...
Pump wont run
does it turn freely if not check pump impeller for debris or damage repair or replace if necessary--if good- check motor bearings if not turning may need to be lubed or motor replaced check amp draw if spiked or nothing than possible open winding and may need replacement
Apr 08, 2010 | Hayward 1 Hp Max - Flo Swimming Pool Pump
Need wiring diagram for Hayward dual Super 2 speed pump. Old unit had 3 wires and new unit has 5 wires.
You need 4 wires to wire the 2 speed pump. You will also need a 2 speed time clock.. Tightwatt or intermatic. The wiring diagram is on the motor.
Aug 29, 2009 | Hayward 1.5hp 230v 2 Speed Uprated Super...
Wire Hayward Super Pump for 115
If you look closely, you should see a small arrow on the black plastic piece on the terminal block(jumper). That arrow lines up with either the 115 or 230 mark on the white terminal board. Make sure it is aligned with the 115.
Then put you two line wires on. It does not matter which wire goes to line 1 and line 2, just be sure you DO NOT put them both on the same terminal. A plastic divider usually seperates the two line connection terminals.
Jun 13, 2009 | Hayward SUPERPUMP 2.0 HP, 115/230V
New 1.5 hp super pump hayward, blows circuit when turned on...
Recheck your wire connection on the motor. You likely put both your line wires on the same terminal. If not, try finding a local warranty center for a repair or replacement... http://www.haywardnet.com/locator/
Jun 11, 2009 | Hayward Pool Products HAYWARD 1.5 HP 2...
My new Hayward Super Pump is over Amping
Sounds like the wire gauge (thickness) is to small
Jun 04, 2009 | Hayward Pool Products Hayward Super Pump
Clicking noise in new Hayward Super Pump
It sounds like the wear ring on the impeller is hitting the diffuser. If it is new call Hayward to fix it under warrenty
Best of luck
Jun 04, 2009 | Hayward Pool Products HAYWARD 1.5 HP 2...
Hayward 2HP Pool Pump Motor A O Smith Electric Pool Motor  for 56J Frame Logo
173 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
