Question about GE (PSS26MSRSS) Side by Side Refrigerator
Noise high pitch noise from the freezer on my side by side
I have a GE refrigerator making a high pitch humming noise coming from the freezer on my side by side. I removed the Ice Cube container and the noise is coming from the freezer motor. I did dial down the freezer to zero and after waiting around 30 seconds I dialed the refrigerator back up and the noise went away for a short time (5 - 10 minutes) and then came back. What do I do to fix this problem.
    President:
  • 1,136 Answers
Hi, Remove the rear inside freezer panel and you will be able to see the evaporator fan motor. The fan motor is what is squeeling.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jun 14, 2009
  • patb Dec 07, 2012
    Hi Victor, I am not sure if I may have the same problem as this person did. Here is my post and would love your feedback. Thankshttp://www.fixya.com/support/t15255490-g...
Why would a brand new fridge make strange noises already?
Good Afternoon Friend,
I understand that your Frigidaire refrigerator, model# FFSS2614QS, is making a strange humming noise. Your new, high-efficiency refrigerator may introduce unfamiliar sounds. These sounds normally indicate your refrigerator is operating correctly. Some surfaces on floors, walls, and kitchen cabinets may make these sounds more noticeable. This could possibly be the compressor that you are hearing. Modern, high-efficiency compressors run much faster than in the past. The compressor may have a high-pitched hum or pulsating sound. Hope this is helpful.
-Best Regards-
WP
Jul 02, 2014 | Frigidaire FFSS2614QS FFSS2614QS 26 Cu....
Low hum or buzz in fridge/freezer (mostly from the freezer side)
Hello, the solution was the ASM control circuit board, ordered one online for around $100 and replaced it
Thanks
May 30, 2010 | Refrigerators
My Hotpoint makes a high pitched humming noise all the time.
This noise is most likely coming from the evaporator fan motor that is located behind the panel just below the ice maker. There is an air duct that the fan blows through to cool the ice maker that is why the sound is heard in the ice maker area more.
The noise does not hurt anything but the motor can be replaced if it gets too annoying, it is a fairly common complaint. The part number for the motor is WR60X10185 and runs about $60.00. It is a bit challenging to get to but can be done with a bit of patience by removing everything in the freezer and taking the back panel off the inside of the freezer.
Apr 18, 2010 | Hotpoint HSS25GFP Side by Side...
High pitched sound from fan
were is the fan making the noise if it in the freezer and making noise check for frost eany frost you may have defrost problem if it is in the refrigerator change fan if is the condenser fan change
Apr 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Noise
this fan is a variable speed and is controlled by a board in the rear of the unit. your bearings maybe going out. The fan will ramp up to speed depending on the call for cooling the Thermistors is asking for
May 20, 2008 | GE GSS22JFMWW Side by Side Refrigerator
GE GSS25SGRE
It is not the freon:
http://www.selfhelpforums.com/archive/index.php/t-11409.html
Jan 21, 2008 | GE GSS25SGSSS Stainless Steel Side by Side...
Ge side by side - high low humming noise from freezer section
Sounds like its the evap fan motor to me. Not very easy to axcess. I have had one GE make the same noises you are describing to me. Let me know if you are going to attempt it and need more assistance
Nov 19, 2007 | Hotpoint HSS25GFP Side by Side...
High-pitched noise
Could you specify if noise is coming from : - The freezer - The outside back of the refrigerator - The bottom of the refrigerator
Jun 13, 2006 | Smeg FAB28
GE (PSS26MSRSS) Side by Side Refrigerator Logo
810 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
