Question about ViewSonic VA1912wb 19" LCD Monitor
The colors on my monitor are faded/bright always changing.
Its like the basic colors are there, and really bright. But just those. A light red next to a Dark red are almost indistinguishable. Red, Blue, and yellow are very distinct, but all other colors (like green) just seem to be very similar to the main three.
  • 53 Answers
Right click on your desktop (not an icon but a blank space), click "personalize", click on the tab on the far right(settings), click the drop-down menu on the left side above the colored banner, make sure it is set to the most colors(usually 32). If you need a walkthrough for Vista I can provide that as well.
Posted on Jun 14, 2009
Panasonic hdtv 1080i picture bright
It could be your main board going bad.
Jun 01, 2013 | Televison & Video
Colors not matching computer
It is possible your colour cartridge has cross contaminated the ink reservoirs. To check this take the colour cartridge out and turn it over to see the coloured pads. They should look red, dark blue, and orange ( the colours are actually Magenta, Cyan, and Yellow, but are concentrated). If any of the pads are pale or particularly green - change the cartridge.
If the colours look alright, your issue is probably that your monitor makes colour by emitting light frequencies so is bright, printed images make colour by absorbing light frequencies so will always be darker. There is always the issue of course that your monitor also has a colour "temperature" bias. Photo pros calibrate their monitors and printers to match.
Mar 25, 2012 | Canon PIXMA iP90v Printer
The colors on my monitor are faded!!!! i got a compaq q2009
Check the backlight settings on the monitor, Sometimes they are set too low and it looks like the color is faded. In the monitor settings (on the monitor Itself) play with the color and brightness until you find a setting you like. If you need reset the monitor to factory.
Jun 17, 2011 | Compaq Q2009 Monitor
LG 700E CRT 17" monitor,
problem with the monitor Display cable. it is damaged.
Normally monitor will receive 3 colors red, green, Blue signals from CPU. If one cable i.e Red wire connection is missing in display cable which is connected to monitor, Red color image on monitor wil be replaced with other fade color.
So, need the replace the display cable or display connector!
Dec 09, 2010 | LG Studioworks 700S 17" CRT Monitor
Still, bright images on my PS3 change the color of my TV in areas
hi verifies if you are connecting good the video cable i mean the red, the yellow, and the white, if this dont serve you, is because your tv is to old.
Sep 19, 2009 | RCA TruFlat 27F520T 27" TV
Brightness of monitor changes itself to quite dim
YOu can go to the monitor settings to make sure nothing's been changed. It could be an energy saver issue where the display dims after a certain period of time, and you can reset it to longer period of time so it would stay bright for you
Dec 12, 2008 | CTX PV 700B 17" LCD Monitor
Monitor resolution
Sounds like either the trapazoidal is off or the pincushion is set improperly. You should be able to find those settings via the monitors onboard menu. Either one can create such a problem.
You might also check into finding the factory defaults selection. This will reset all of the resolutions and refresh rate settings.
When you adjust your screen follow these steps in order...
Pincushion : Makes the screen look like ( ) or ) (
Trapazoidal : Makes the screen look like / \ or \ /
Horizontal : Basically stretches the screen wider or skinnier to fit the monitor
Vertical : Basically the same as Horizontal, only with the up and down properties
Contrast / Brightness : Use this to find the perfect white and blacks
Color : Finish your setup with adjusting to the perfect color.
This way you can always have your monitor set like you want it.
Sep 12, 2008 | Gateway FPD2275W LCD Monitor
Colour fade of my 793s
rainbow colour is normally due to magenatic effect on monitor
see that any magnetic thing is near monitor
 if it is there remove it
.after that put off monitor for 15 minutes & then put on.see if any change is there
 if there is any change is there wait for 2 or 3 days it will be ok.
if brightness is also less along with fad color then
 check for video output section & crt electrodes for normal voltage.
it that is also ok then crt is getting weak,
please be in touch with me unless it is solved.
hope this will help.
Oct 11, 2007 | Samsung 793S 17" CRT Monitor
Colors flashing no picture
Did you have another monitor to verify the problem whether it is related with the Video card or the monitor itself?
Jul 29, 2007 | Xerox XG-71D 17" Flat Panel LCD Monitor
Monitor Coloring
Well most monitors come with 2 preset color temperatures and the option to customize it(the rgb setting). Your monitor has them as well 6500K or 9300K. 6500 is more reddish(like outdoors) and 9300 is more a bluish white(like a tv, i like the 9300 more). How u said its red and bright, what i would do is set the 9300 preset and if its still too red the customize the RGB by lowering the red. and If too bright then Lower the brightness(Press down on BRIGHTNESS CONTRAST page). If you don't have the manual you can download the full manual from LG's download site here: http://www.lge.com/support/manual. If you see that you can't get it just right,then the monitor might need adjustment from inside and you should make a qualified technician open the monitor and adjust that for you. Hope this was helpful.
Apr 26, 2007 | LG Studioworks EZ-FLAT E700B 17 in.CRT...
ViewSonic VA1912wb 19" LCD Monitor Logo
511 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
