Question about Surround Air Multi-Tech XJ-3000C Air Purifier Air Purifier
XJ 3000 PUSH POWER ON AND DOES NOT START. IS THERE A FUSE TO BE CHANGED OR RESET
  • petecastro Dec 03, 2008
    The unit will not stay on when button is pushed. If button is held for 5 sec onds, the unit will run for about 3 minutes then shut off. Any ideas?
Yes there is a fuse inside - its a T1.6AL250V that is hard wired in at both ends, and thus not designed for replacement. On my machine it was totally toast, and the board was blown out from a prolonged over voltage event (along with a bunch of other applicances in my home). Replacement is the only solution.
Posted on Feb 01, 2010
I changed filter on oreck airstream purifier 2 days ago but light remains solid red.
you have to check OM. Usually you'd have tu push something 10 times to reset
Jan 22, 2018 | Oreck Air Purifiers
Won't start
Check the fuse inside the unit, it is located where power cables hook up.
Aug 26, 2008 | Jet AFS-2000 Air Purifier
How do you change the station start times in a Hunter Pro-C?
The Airsource 3000 I have will power up and the fan runs. I did a new bulb replacement but it will not "light up" like it should in the front???
Jan 14, 2014 | Air Purifiers
I have no power to my Fresh Air by Ecoquest. I've taken it apart and all connections seem to be in place. Still nothing when pushing the reset or power buttons. Any advice?
Remove the filter on the back. On the outer edge of the filter frame, you will see a plastic tab. This tab is a safety switch and if it's not making proper contact with the trigger of the unit, it will not power up. Push the tab section of the filter frame snugly in first and then the remainder of the filter frame. That should solve your problem. It that doesn't solve the problem, check for a blown fuse, The fuse holder is on the back of the unit.
Mar 14, 2011 | Ecoquest Fresh Air Air Purifier
The fan stopped working on our Living air classic XL15 so we just changed the motor. The machine comes on but the fan doesn't. Is there a reset button that needs to be reset? Or something else to do?
Sometimes you have to give the fan a push with your finger. If that didn't work, check all connections, fuses, etc. Sometimes things get jarred. If you changed out the connections at the ends of the wires (they include new ones with the replacement motors) you may need to make sure that you connected and/or crimped them correctly.
Jan 21, 2011 | Ecoquest Living Air Classic Air Purifier
Does not turn on
Fuses often fail without appearing to be bad. Test the continuity of the fuse by using an ohmeter.
If, after testing your fuse, you continue to have a problem, let us know and we will dig deeper.
I hope you find this to be very helpful as a jumping off point, moving forward.
Please leave a rating. :-)
May 14, 2010 | Ecoquest Fresh Air Air Purifier
I have an Eagle 5000 air purifier. Stopped working
Just went thru this Tues. Get the top of screen in place and then push the plastic in on safety switch. I was having it push down and then slide screen in. That plastic piece is split like when you push it in, it hits 2 different heights. Instead of pushing it down get top in and push the plastic in, easy. Turned on then. Already had the switch on so it fired up soon as I pushed it in.
Jan 15, 2010 | Eagle Advantage Alpine Air Purifiers Eagle...
Not returning to 100%
Reset filter reminder:
Unplug power code.
Push and hold sleep button.
Plug power code while pushing sleep button.
LCD shows "P" than release the button.
Push sleep button and you can see 99% filter reminder.
Jul 09, 2008 | Bionaire BAP1300 Air Purifier
Metal grid cleaning
You must press both the timer and reset buttons together had same prob Ezio
Feb 26, 2007 | Surround Air XJ-3800 Air Purifier
Surround Air Multi-Tech XJ-3000C Air Purifier Air Purifier Logo
195 people viewed this question
Top Surround Air Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you a Surround Air Air Purifier Expert? Answer questions, earn points and help others
