Question about Whirlpool Duet GHW9150P Front Load Washer
Moldy smell in whirlpool duet washer
I heard or read that I can solve the problem by using bleach to clean it. But what do I do? Do I run it through a cycle with bleach right in the drum using hot water or what???
    President:
  • 1,136 Answers
Hi, Go to you local appliance store and they should carry a product for this issue. Most front load washers are having the same issue.
I hope this helps you.
Vic
Posted on Jun 14, 2009
Bleach getting dispensed during rinse cycle
Never heard of Bleach being used in wash cycle ! Are you putting the Bleach in the correct dispenser .
Jul 23, 2012 | Electrolux EWFLS70JSS Washer
I have a front loading washing machine that smells inside. Any suggestions ???
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
Jun 22, 2009 | Daewoo DW500M Top Load Washer
Washer smells bad
Whirlpool and Tide make a cleaner that you put into the washer and run it through a cycle. Front loaders get a build-up that cannot be cleaned by hand. Make sure you are using a detergent that is marked "HE". Do not overfill the detergent or softener cups. I've heard that other used a lot of bleach in a wash cycle to clear out the smell. Bleach is bad to use if you're on a septic system, though.
May 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Code lr appears on washer
use normal cycle instead of clean just follow say instructions ..lr is code for remove clothes from tub for clean cycle problem even with no clothes they still show code ..it's a program problem that whirpool is aware of last i heard they were working on solution but instructing cust to just use normal cycle instead
Nov 17, 2008 | Kenmore Elite 45986 Front Load Washer
Trom Front Load Washer
I have never heard of cooking oil but I have heard of vinegar. If you have had your washer for a while (over a year) it could take several times of cleaning to get rid of the odor. Also be aware that liquid softner actually builds up worse inside the tub then the soap does so only use 1 tablespoon of softner. If you run the washer with nothing in it and you see lots of bubbles in the water you still have the build up inside the tub. The last item I've heard of is something called "whirlout" (not sure on the spellng) that you can get from a hot tub dealer.
Aug 14, 2008 | LG WD-14124RD Front Load Washer / Dryer
Washing machine has a musty smell
Jul 29, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Smell coming from washing machine
Apr 18, 2008 | Hotpoint WMM39 Front Load Washer
Moldy odor
Try running it with just vinager and water no clothes.
Just put about a cup of vinager in it and wash cycle and another cup in rinse cycle.
Vinager is a better disinfectant and odor eliminator than bleach.
Mar 25, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
He4t - monthly bleach cleaning cycle
Washer Monthly Maintenance Procedure:
This cycle uses higher water volumes in combination with liquid chlorine bleach to thoroughly clean the inside of your washing machine.
  1. remove any clothing or items from washer
  2. CLOSE door (duh)
  3. open dispenser drawer and remove the detergent compartment and set aside. No laundry products will be added at this time. You will be required to add only liquid chlorine bleach at a later step.
  4. For Kenmore Elite HE products press a specific combo of buttons.
  • Select Rinse/Spin program
  • select low spin speed
  • select warm/cold water temp.
  • select 2nd rinse option
  • push the "end of cycle" signal button 4 times within 5 seconds to start the cycle
The machine will fill and run a short sensing cycle. This will take about 3 minutes.
Step 5
  1. The washer will provide 4 short tones. Check the: ESTIMATED TIME REMAINING display for the codes indicated below:
  • if "Ab" (add bleach) displayed in the estimated time remaining window (you'll hear 4 short tones) proceed to Step 6.
  • if "rL" (remove load) displayed in the Estimated Time Remaining window an error tone will sound. The door will unlock.
    -open the door and remove the items from the washer.
    -continue the cycle by pressing the START button.
    NOTE: The water in the unit will dispense for a moment, then the door will unlock, lock again, and then the cycle will continue with another check for items in the washer.
    The machine will fill and run a short cycle to determine whether any items have been left in the washer. This will take approx 3 minutes.
    the washer will repeat Step 5 until it can determine that there are NO items n the washer and will display "Ab" (add bleach).
6. Add liquid chlorine bleach.
  • If using the maintenance procedure for the first time, open the dispenser drawer and immediately add 1 cup liquid chlorine bleach to the Main Wash detergent compartment. The liquid bleach should immediately flow out of the dispenser.
  • If doing a monthly maintenance procedure, open the dispenser drawer and immediately add 1/3 cup bleach to the Main Wash detergent compartment. The liquid chlorine bleach should immediately flow out of the dispenser.
    NOTES:
  • Water will be flowing into the dispenser drawer when the bleach is added ... this is normal.
  • Do not add any detergent to this cleaning cycle. Use of more than 1 cup of bleachw ill cause product damage over time.
7. Once the cleaning cycle has begun, allow the cycle to complete. An est cycle time will appear on the display.
8. After the cleaning cycle is complete, leave the door open, clightly to allow for better ventilation and drying of washer interior.
9. Replace the detergent compartment divider.
Feb 04, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
White Clothes even with bleach and hot water don't get clean???
i have used everything to solve this exact problem!  I have to say the best detergent or bleach i have used in the lg..is the purex with bleach for colours it seems to work better than anything ive used...spent a fortune to have to soak my whites before putting them in this washer.  I must say im disappointed..
May 06, 2007 | LG WM1814CW Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
306 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
