Question about Chi Mei Corporation 221A Monitor
I'm having problem with my 16 inch CHIMEI LCD monitor flat screen, first when i booted up my computer it was fine, then i just defrozted my computer(because my computer has a deep freeze program)and then restarted it, when it was restarting THE NO INPUT SIGNAL APPEARED and the light on the monitor turn to orange, i tried restarting the pc but its the same, i check the cables and still the NO SIGNAL input wont go, and my monitor wont wake up.. NEED HELP PLS.. thanks..
    Sergeant:
  • 361 Answers
In my opion deep freeze (pige head)is not good progrram .itt creat big problem. we should know well how can be use it. once a time u should reinstale it or formate ur computer,i hae facing many problem from my custmer. -----thanks
Posted on Jun 14, 2009
Can I purchase a replacement stand for my chimei 222H monitor? If so where?
I have broken the mounting arm of my Chimei CMV 222H ...
www.fixya.com/.../t14977283-broken_mounting_arm_chimei_cmv_222...
Nov 12, 2012 - ... the mounting arm of my Chimei CMV 222H monitor, can you getreplacement arms? The locking mechanism - Chi Mei Corporation CMV-222H 22 inch LCD Monitor question. ... Video; Photos; Link; Replacement Parts. Add.
Repair Kit, Chimei CMV 221D, LCD Monitor, Capacitors ...
www.amazon.com > ... > Capacitors
Amazon.com, Inc.
Dec 15, 2015 | Computers & Internet
I have A Chimei CMV 221D LCD monitor. I am thinking from memory it is a 17 or 19in monitor. It's black in colour. It worked well, loved it but one day I booted the computer up and the light went from...
boot your computer into safe mode that eliminates any special resolutions from your normal windows if your display is good in safe mode then your computer resolution is set at a level the monitor cannot use you then will need to reset your normal resolution to a lower level
Mar 25, 2017 | Chi Mei Corporation CMV-221D LCD Monitor
LCD SCREEN STAYS BLACK
Get a quotation on how much it will cost to repair according to where u live... if it's 10 to 20% the LCD, so get it fixed otherwise ...
Sometimes bad capacitors can cause these probs
Feb 05, 2010 | Microsoft ChiMei CMV938D 19" Widescreen...
Monitor won't start when I boot up - without a lot of fiddling!
First try to do monitor self test.Disconnected the blue cable VGA or white colour connector from monitor to the computer. Turn on the monitor and check if you are able to see colours or line on the monitor.Indicating self test monitor is working fine. If you are using Video card on computer connect monitor directly to onboard video and check. Good Luck.
Aug 19, 2009 | Computers & Internet
19"chimei Lcd. Screen stays black.
probably power supply, dac-19m015, 2200uf bad capacitor.
Apr 26, 2009 | Microsoft ChiMei CMV938D 19" Widescreen...
Chimei Monitor
my monitor chimei tco3 is black and will not show sceen
Jul 30, 2008 | Microsoft ChiMei CMV938D 19" Widescreen...
Monitor
Monitor sizes are measured on the diagonal from corner to corner.
A 17" LCD may have a screen width of 12 inches measured from side to side.
If you are measuring a old style CRT monitor (Cathode Ray tube) the visible screen area will be about an inch less as there is about 1/2 inch of plastic frame holding the CRT in the chassis. The manufacturer can advertise the actual size of the screen regardless of how much is actually visible to display information.
If you are talking about software not utilizing all the available screen area to display the image, that is an issue with the people writing the software code not keeping up with the changes in hardware.
In the past year or two, most displays have switched to the 16:9 and 16:10 wide aspect ratios while most web content is still written for the 4:3 old style aspect ratio. Eventually, software developers will catch up with cusrrent hardware.
Jul 25, 2008 | Gateway FPD2275W LCD Monitor
Chimei CMV 938D 'Out of range' error message only when using DVI Connector on specific resolution and color depth
I know this sounds obvious but- I had the same problem, and turns out the cord want plugged in quite properly at the back of the monitor. This may not fix every problem, but, I suggest you check the cord pligged in at the back of the monitor is firmly in there and restart, then if you still get the problem, contact the company.
Jul 21, 2008 | Envision EN-7100e 17" Flat Panel LCD...
CHIMEI CMV938D 19 WIDE SCREEN LCD volt
I have the exact same monitor and it is 220v. But seeing as i bought it in Australia that makes sense. If yours was purchased in North America then it is almost definitively 110v. It is likely that it is written on the actual monitor. If in doubt you could always try it with 110v. If that works then theres your answer. If it doesn't then its probably 220v.
Oct 17, 2007 | Microsoft ChiMei CMV938D 19" Widescreen...
Chi Mei Corporation 221A Monitor Logo
171 people viewed this question
Top Chi Mei Corporation Computers & Internet Experts
giarcnameloc
Level 1 Expert
Jax Planet
Jax Planet
Are you a Chi Mei Corporation Computer and Internet Expert? Answer questions, earn points and help others
