Question about Microsoft Xbox 360 Console
3 red lights, but nothing turns on
I turn the power on and I get 3 red flashing lights, but nothing else seems to turn on. The fan in the inside doesnt turn on and I can't open the dvd drive.
  • 1 more comment
  • ps3_gamer18 Jun 14, 2009
    Well obviously its the red ring of death, I fix them. But this one, when turned on just shows the red lights, the fan doesn't come on and nothing heats up inside, without it heating up i can't fix it like normal. I need to know why?
  • ps3_gamer18 Jun 15, 2009
    It's not the power brick either, because I use it for my main xbox 360 and it works just fine.
  • ps3_gamer18 Jun 20, 2009
    Well Obviously whoever wrote not to open the xbox 360 did read my entire problem, as I mentioned I fix them, so of course I will open it Duh!!!
  • 4 Answers
Penny trick makes 3 red ring of death go to 074 then use towel trick (videos below)
Penny Trick:
http://www.youtube.com/watch?v=wsz0lNJ6JrQ
Towel Trick:
http://www.youtube.com/watch?v=31tvXu34T8Q
Posted on Jun 25, 2009
  • 3 Answers
Dont open the xbox 360 because microsoft will void the warranty that all xboxs 360 have and send it to microsoft
Posted on Jun 20, 2009
Needs a new power pack had exactly the same problem, you might find the power pack(plug and transformer),shows a red light as appose to green or yellow for a split second before turning green yellow,this would confirm my thoughts.i hope this has been of help to you.
Posted on Jun 15, 2009
  • 32 Answers
Sorry to say that is the Red ring of death your gonna have to send it to microsoft and they will repair it for free
Posted on Jun 14, 2009
I have a Plasma TV with black screen and 6 red light flashes.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 19, 2015 | Panasonic VIERA TC-P55VT50 55-Inch
It works intermittenly
3) The LED turns on or flashes red during initial boot up :
When the temperature inside the car is too high or too low, the red LED flashes. In this case,
follow the steps below.
Turn the product power off and ventilate the car to return to normal ambient temperature.
Turn the power on after a little while and observe the LED color.
If the red LED still flashes under normal temperature, contact customer service.
Ref: Plenio VXA3000 Users Manual Pg 5/6 1-4 Troubleshooting
DVSSynchrome_VXA-3000_UserManual.pdf
Download Files At MS Skydrive Email jeffreydrescher@Bellsouth.net For
Login and Password
Dec 23, 2013 | Digital Video Systems Plenio VXA-3000 GPS...
Hi, I have i Sony wega tv when i turn it on green and red lights flashes and nothing happens please help
The red light is key to your issue---is it blinking in a sequence--constant blink or for example 3 blinks, pause and 3 blinks?
Mar 20, 2012 | Televison & Video
I have KDS-50A2000 Sony SXRD Projection TV. Serial #9028985. It was working fine then a few days ago I went to turn it on and the red power light was blinking 4 times and repeat... I then opened the lamp...
hello, this can cause the red power light to flash 3 time also if the lamp cover is not fitted securely this can also cause the light to flash 3 times 4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped hope it helps
regards
shaun
Jan 03, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
Philips 42pf7621d/10 dead
One of the circuit boards should be replaced inside, probably the power supply, the good thing is that screen is ok and it's a most expansive part, you can take it to the local repair shop for diagnostic and repair.
Oct 10, 2009 | Philips Televison & Video
VT440K orange power flashing red status light, overheated.
Make sure all the air filter caps are all the way in and nothing is broken from it. that was my cause..i had the same problem
Apr 17, 2009 | NEC (50019497) Projector Lamp for VT440,...
Warning lights
Just so you know guys (and this procedure is not for the faint hearted!). I had the slow one second red warning light flash. I checked the bulb, which was find and I left it powered off for 48 hours. My projector is no longer under warranty and would have cost me over £300 to have it looked at. I ventured inside to inspect the boards, once I removed the main board to check the power supply I heard movement from one of the light ducts. It took me a while to removed enough to discover the fixing screw which holds the imaging cube in place (which is between the 3 light ducts and the projector lens) had come out (!?) and was rolling around inside the unit. This would also explain why sometimes I could not focus my unit properly. I remounted the imaging cube, put the whole thing back together and PRESTO! My projector is working again.
lee.read@gamil.com
Jun 21, 2008 | Epson EMP 720 Multimedia Projector
No Power with 3 red light
hmmm.. The Ring of Death.
The 4 rings mean power faliure.
The 3 rings mean the CPU has been melted.
The 2 rings mean there is a CPU overheat error.
The 1 ring means there is an internal error.
Hope this could of helped you.
Jun 05, 2008 | Microsoft Xbox 360 Console
360 issues
Two Red Lights
The two left quadrants of the Ring of Light flash red on the front of the Xbox 360 console
This behavior occurs when the internal temperature of the console exceeds the acceptable limits. You may think of this as too hot, overheating, and so on. Make sure the fans are operating and the system has adequate ventilation.
Since you've been inside it's possible that a heatsink or some other part of the cooling system is not working properly or is loose. Check all these!
Good Luck!
Nov 17, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
259 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
