Question about 2wire (1000-000005-002) 802.11g/b Wireless Adapter
How to connect a 3800HGV-B Gateway and dir 615
How to connect a 3800HGV-B Gateway and a Ntegear dir 615
2 Suggested Answers
elix0411
  • 3530 Answers
SOURCE: Cannot get a secure connection with 3800hgv-b
Welcome to Fixya
There should be no problem in setting up a passkey for this device. Try to restore the router to factory default first and try to setup again the passkey.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Posted on Nov 29, 2010
How can i fix dir 615 ssid stop broadcasting issue?
Step 1: Open your web browser and type in the IP address of the router (192.168.0.1 by default).
Step 2: Enter the username (admin) and password
Step 3: Under Setup Select the Wireless tab
Step 4: On Wireless Tab - Select Invisible if you do not want the SSID of your wireless network to be broadcasted by the DIR-615. If Invisible is selected, the SSID of the DIR-615 will not be seen by Site Survey utilities so your wireless clients will have to know the SSID of your DIR-615 in order to connect to it.
Sep 08, 2014 | D-Link DIR-615 Wireless Router
How to connect TP LINK TL-WA901ND with Dlink DIR 615
Have you set the TP Link TL-WA901ND IP to have 192.168.1.1 as the default gateway ?
Also DHCP server is where ?
IN the TP LINK TL-WA901ND or in DLINK DIR 615
Only have one Router running DHCP and set the default gateway in the leases as 192.168.1.1.
What subnet mask are you using is it the same through out all devices ?
Oct 30, 2017 | TP-LINK TP link TL-WA901ND 300 / 11n...
My instruction manual is in Chinese, i am using a mac and i cannot connect wirelessly to the internet, I have a DIR-605 router.
well here is a link to obtain the manual http://www.dlink.com/products/?pid=DIR-615
you need to select Support Resources Tab and choose the revision type you have. then you select product manual. One example is this one "DIR-615 no rev. http://www.dlink.com/products/?tab=3&pid=DIR-615&rev=DIR-615
GL
hope this helps
Don't forget to rate my answers
Thank You
Jammer
Sep 23, 2011 | D-Link DIR-615 Wireless Router
I am using DLink DIR-615 router and I want to secure my network but I could not log on to 192.168.0.1 Please help.
Try 192.168.1.1-it has to be whatever your default gateway is.
You have to enter your DEFAULT GATEWAY-and that may not be it--go to START>RUN and type "CMD" in the box-- at the command prompt type "MSCONFIG" and you will see your DEFAULT GATEWAY
If this was helpful, please indicate so, if not -comment back so we can dig further to resolve this.
Dec 31, 2010 | D-Link DIR-615 Wireless Router
D-Link DIR-615 seems to break very easily
i dont think your router has gone bad...
try these simple steps...
connect your computer to one of the LAN(wired) ports of router...
check the ip address and default gateway of your local area connection through control panel > network connections.... if you get the ip adress in the range of dlink router then try going to start > run > type "cmd" and hit enter >command prompt will appear... in command prompt type this
ping (default gateway address) and hit enter...if you get successful replies then your router is not gone bad...
Jul 16, 2010 | D-Link DIR-615 Wireless Router
Dir-615 router will not connect, on set up it
do a factory reset - theres a reset button button on the back hold that for 30secs until the device resets
does the ethernet cable and PC work if connected directly to the modem whats the make and model of modem
Mar 19, 2010 | D-Link DIR-615 Wireless Router
Connected to wireless router, not connected to the internet
Try setting up a new network connection in the Network and Sharing Center. You'll need your info from your router like:
router username:
router password:
network name (ssid):
network security type:
network security key:
connection type:
Some will also ask for a serial id(I've only ever come across one)
I've never used your particular brand of router but it ought to work the same way as far as the setup.
Aug 25, 2009 | D-Link DIR-615 Wireless Router
DIR-615 will not connect to internet. Followed step by step... doesnt recognize the internet connection... but I can wire in to the connection.
hii, i had the same problem, if you have a gateway (modem) you can join them together and turn the modem on and wait for it to finish starting then turn your dir-615 on, and you shouldnt even have to configure it, it should just work, it did for me.
Jul 17, 2009 | D-Link DIR-625 (790069292637) Wireless...
2wire (1000-000005-002) 802.11g/b Wireless Adapter Logo
706 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
