Question about Durabrand DVD-1002 DVD Player
Dvd player not working
When i put a dvd into the player it will start to play but then the spinning slows down and it stops playing and won't start back up. it also will spin the disc loudly and sounds like it's too big for theĀ  dvd also it says reading disc then says disc error.
  • Anonymous Dec 09, 2007
    yes I have the same problem with mine it sounds like griding nose when it starts to spin then it stops I had this DVD for 6 months I need to replace it I got it from Walmarts don't know if I can exchange it or not
  • natashar20 Aug 16, 2008
    i insert the dvd it starts to spin like if it was going to play, then slows down and stop completely and say there no disc
Buy new one then replace it with the old one and take it back for refund
Posted on Feb 10, 2008
Portable dvd player slows or stops
The pladder motor that spins the dvd disc is failing, or the 5volts to the motor is flutuating, usually the whole assembly is replaced and is expensive.
Jul 18, 2012 | Zenith DVP615 Portable DVD Player
My toshiba BDXK100 won't play DVDs other than Blu-Ray
There may be a issue with the assembly, blu-ray plays with more precision and speed, for some reason it is not slowing down to play the regular DVD's may be a padder motor problem.
Mar 19, 2012 | Toshiba BDX2000 Blu-Ray Player
When i put in a dvd into my player, it says no disc, and won't play, when it does accept the disc, it doesn't play it, then a "C:13:00" starts blinking. I should be able to just put in a...
It's most likely dirty, though it could be failing. The lasers have an average life span of 3 years, under normal use.
Several companies make CD/DVD laser lens cleaners. You want the kind with optical quality brushes on the bottom side. You simply put it in, let is spin up and play, then take it out. It may not play the first couple times you put it in, but it will be cleaning the lens and pickups.
If that doesn't do it, I'd start looking at sales for a new player.
Jul 05, 2011 | Sony Televison & Video
After 10 min. of play time the dvd stops working
This is most likely a problem with the power supply to the drive motor. A component is breaking down and the supply voltage is dropping below operational levels after warming up.This is a problem that needs service in a service center or someone who is a experienced electronic technician to take apart the unit and test it for bad components.Hope this help you with your problems.
Mar 18, 2009 | Polaroid PDM-0742 Portable DVD Player
My Sony DVP-cx995v stopped playing DVD's
I had the same "Cannot play" problem - happened suddenly, I don't think I was doing anything unruly at the time.
After checking repair (exchange) prices in excess of $250 from Sony, I decided to open the cover to see if I could see anything wrong - normally a futile exercise with electronics except that in the past I have cleared errant disks that have lodged themselves near the drive/player at the rear of the library.
Upon opening and watching the library try to load and play I noticed the drive itself was not spinning the disk once loaded. It would sit for awhile, thinking about it I'm sure, then would unload and load the next dvd, again failing to spin.
I thought okay, maybe try to spin the dvd while in the player to see if it's jammed or otherwise hard to turn. It was not hard to turn and spun freely. In fact, when I put my finger through the hole at the exposed side of the player at the hub to spin the dvd, clockwise, it suddenly started to spin - and play!
I put the whole thing back together to test and all seems to be working fine at this point. Not sure what would cause the motor to stop spinning and remain in that state through poweroff/on cycles etc. but I'm sure this is not the last time I will have trouble of this kind.
I would note that when replacing the library back in its home on the shelf, be careful not to tip the library, especially toward the player area because the disks will spill out of the carousel near the player and become jammed when you power it on and attempt to load. A final tip of the library away from the player area may clear this if you hear the disks rolling out of their slots and you don't want to open the top again (it's a darned heavy box when fully loaded).
Jan 05, 2009 | Sony DVP-CX995V Multi-disc DVD Player
DVD stopped playing all DVDs
Reset you player by doing the following:
With the player on, hooked properly to your television, and on the correct station:
Open the tray
Close the tray (with no DVD inserted)
Hold the stop button down for a full 5 seconds
The CyberHome screen should appear. You should be able to play your dvd's now.
Feb 20, 2008 | Cyberhome CH-DVD 300 DVD Player
Samsung 3650 dvd/vcr player loading problem
Sorry, no suggestion other than don't buy Samsung. That's my conclusion after owning the same model. It worked fine for a while, but now won't load any DVD... usually. Sometimes it will play one, but more often it won't. Mine tries to load ("Loading") for a long time, I hear the DVD spinning, then ultimately the screen displays "This disc cannot be played" or something to that effect.
Nov 25, 2007 | Televison & Video
Reads all but DVD-Help PLEASE
When you say it won?t read are you trying to play commercial DVD movies or read DVD data disks? If you're trying to play movies then you need a couple of things the first being some type of player program. Real player works as does Windows media player but usually DVD drives come with a striped down version of PowerDVD or WinDVD. If you in fact have a player installed and when a DVD is inserted in your drive it doesn't play it may not be configured to automatically play DVDs. Try opening your player program and trying to manually play your DVD. Let us know if you have any success or if you need more assisted. If you do let us know what player program and operating system you have and any error messages that may appear.
Jan 01, 2007 | LG GCC 4320B CD-RW/DVD-ROM Burner
The laser has become damaged/worn-out. There is no fix for it as replacement parts are not made for it.
Nov 27, 2006 | Insignia IS-PDO40922 Portable DVD Player
Durabrand DVD-1002 DVD Player Logo
173 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
