Question about Sony Cyber-shot DSC-S650 Digital Camera
Camera wont switch on
New battries but camera wont start
    Problem Solver:
  • 5 Answers
Well assuming the camera hasn't been damaged, make sure of the polarity of the batteries when installing them. Also make sure they are all fresh and of the same kind. If one battery is bad, it will prevent the camera from turning on. If still a problem, use a "Q" tip dipped in alcohol to clean the battery contacts in the camera. If this doesn't solve your problem, contact the mfg about downloading new firmware for the camera... Hope this helps.
Posted on Jun 14, 2009
Olympus VR-310 wont turn on?
Is there sufficiand battery power ? in the battery? is the switch working try a ohm meter on it to see if the switch works that will give you a idea how the battry is.
Dec 18, 2014 | Olympus Cameras
Phone full battery but wont turn back on
may be battry is outdated or extra fully charged thats why sometimes it react like this or the size also bigger than normal battry so try new battry or check the PIN which is connected to battry when u put battry in mobile...thank you
Nov 03, 2013 | Samsung Galaxy Pocket
I have a canon camera and it wont turn on i bought brand new battries for it and still nothing!
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Sep 28, 2011 | Canon PowerShot SD780 IS / IXUS 100 IS...
Coolpix L18 LCD Freezes
If you are using the NiMH batteries they may be getting hot causing condensation. Try regular battries or wait for the camera to stabalise in the new tempature. If the regular battries work then buy the replacement rechargebal battries because the voltage will vary with tempature also causing errors to the sensors.
Aug 17, 2009 | Nikon COOLPIX L18 Digital Camera
Suddenly the camera is not working !!!
You have to try format the memory card in your camera ?
You write, that "setup" is working
Might be the need of memory updating - computer does mainly harms to the camera if used to operate inside of camera ;-(
Own experience and twice - is, that the camera had lost all pictures from memorycard.
Happily enough a program downloaded from the net was helping.
Wish good luck!
murtomaa
Jul 16, 2008 | Olympus MJU 300 Digital Camera
My camera is not starting at all
try and hold down the battery cover and see if it is loose lots of times digital cameras will do that.
Jul 05, 2008 | Nikon Coolpix L1 Digital Camera
Camera wont turn on even with new batteries
In order to narrow down the issue, I suggest you the following steps. 1) First of all we have to power drain the Camera. Take out the battries and unplug adaptor, now hold the power on putton ( Click Button) for a minute this will clear the static power on Camera. If this doesn't fix the issue, Than.... 2) As cam is working fine with Ac adaport and batterys are not working you have to check the cam with the new battries. If you store battries for a long time with out using them, they may result in battery drain. If this doesn't work. 3) Then it need a Physical check, where we can track if Power suply from battries are reaching till its destination or not. This is the way to narrow down the issue. Thanks you.
Apr 08, 2007 | Konica Minolta DiMAGE Z1 Digital Camera
DCR pc55e
hi no need to disassemble the device all you need is long thin tweezers take the battry out look inside the socket (with light) and find the silver\gold connection battry tabs with the tweezers elevate the tabs for better connection on the lid is a spring like (push the battry in place) elevate it too if this wont work buy a new battry before taking apart the device good luck
Apr 05, 2006 | Sony DCR-PC55 Mini DV Digital Camcorder
Sony Cyber-shot DSC-S650 Digital Camera Logo
194 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
