Question about Car Audio & Video
I have a 1997 GEO Metro, 4 door, automatic trans, and I put in a AC Delco, GEO radio cassette and their is lot of line noise sound, can u tell me the problem of that radio, thx u.
  • 518 Answers
It will probably require some kind of in line supression which you can purchase from any car accessory store
Posted on Jun 14, 2009
Does 1996 geo metro 1.3 engine computor interchange with 1997
no transmission stated, and in many geos 1997 they moved the TCM to the ECU, so.... no tranny no help.
calif or FED car, ? what trans, how many doors.
the ECU is tuned for weight so you have full power WOT.
short answer, no
in most cases, no.
and what does interchange mean?
1: plugs in
2 : plugs in and runs.
3: plugs in and runs right
4: plugs in and runs right and passes smog. and is legal.?
each ECU has a huge list of options.
and you never stated any only liters?
like transmission type, engine type. G16,G13 or G10, all three are diffr. and smog type, and lots of others.
why not got cardon rebuilt page and look yours up, see what fits.
1996 , 26 ECU made
1997, 16 ECU made. only G13s made.
http://www.cardone.com/find-parts/vehicle-parts-listing?make=Geo&model=Metro&year=1996
ok , i looked at both lists NOT ONE MATCH.
you can send yours to CARDON and they will rebuild yours.
May 22, 2014 | 1996 Geo Metro
My geo metro egine have a ticking sound
If you have adjusted your valves and the ticking persists then try changing your exhaust manifold gasket. A leaking exhaust manifold gasket will often make a loud ticking sound.
Sep 19, 2011 | 1997 Geo Metro
My 97 geo metro started making noise that resembles a high pitch hiss, and it only starts making the noise above 30-40 mph and when i slow down it keeps on making the noise. I tried to put in neutral as I...
Could be Transmission related. Have you checked the Fluid level?
Also have you changed anything recently like new tires? Its not uncommon for some tires like (Hankook for example) to make road noise?
Aug 18, 2011 | 1997 Geo Metro
Locating camshaft sensor in 1996 geo metro
So what engine is in it? It always helps to state which engine you have, trans, 4 door ect. Should be near the harmonic balancer either attatched to ther front of the engine, or bolted to the engine block.
May 12, 2010 | 1996 Geo Metro
1997 geo tracker no drive but have reverse ,3 speed automatic
You may try putting the trans in 2 or 1, if this doesn't give you any movement check trans fluid levels hot on a level surface. If levels are correct your trans is probably bad.
Apr 30, 2010 | 1997 Geo Tracker 2 Door
97 Geo Metro will not start
it sounds like the battery charge battery and load test after you get it running check charging system
Aug 26, 2009 | 1997 Geo Metro
1996 Geo Metro factory Delco Radio not working
u can call any close delar to ur place and they will help u by phone they will give u the code for ur radio and they will tell u they way to enter it in its free from anydelar
Mar 15, 2009 | 1997 Geo Metro
Radio fuse on 1997 Geo Metro
the appropriate fuse is blue (15A) and is third or fourth from the side of the car (the narrow end). Look at the fuse box cover.
Mar 12, 2009 | 1997 Geo Metro
Delco radio code model 30015807 serial num 3017531
Go to this website and they'll get you the unlock code to your radio. Very nice people who help you out with every step of the way.
http://www.DelcoLockCodes.com
Sep 08, 2008 | 1997 Geo Metro
Car Audio & Video Logo
57 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
